  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 37.8k Views 3 Watching
  • wilkinsafW wilkinsaf
    Yes, let me try one at a time now.
    Here are the two cameras
    4de39b51-2708-4707-a1fe-d67161270aa3-image.png ![0_1640728100493_PXL_20211228_214717072.jpg](Uploading 100%)
    1. Banggood URL
    2. Blue Robotics URL
    @wilkinsaf Thanks! I'm going to order them so that I can have them as part of our normal USB UVC camera test suite.
    wilkinsafW 1 Reply Last reply
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @Eric-Katzfey Thanks Eric!
      I switched to dev branch (slightly embarrassing as you told me to switch to dev) and pull
      voxl:~/voxl-uvc-server(dev)$ git pull origin dev
      From https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
       * branch            dev        -> FETCH_HEAD
      Already up-to-date.
      I made sure to install the correct libuvc ipk
      voxl:~$ opkg install libuvc_1.0.2_202112182223.ipk
      Collected errors:
      * opkg_prepare_file_for_install: Refusing to load file 'libuvc_1.0.2_202112182223.ipk' as it matches the installed version of libuvc (1.0.2).
      I then built the voxl-uvc-server, ran Makefile, and tried to run
        Already up-to-date.
        Collected errors:
        @wilkinsaf Okay, interesting. Let's go back to the original camera with the incorrect size. Can you add the patch I suggested and see if you can make that camera work?
        wilkinsafW 3 Replies Last reply
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @Eric-Katzfey ope, almost forgot. Yes, let me do that now
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            For some reason now it is still struggling to find any device. I tried both cameras
              wilkinsafW Offline
              wilkinsafW Offline
              wilkinsaf
              I know that it is there as ffmpeg picks up on it
                @wilkinsaf Unfortunately, it's hard to debug this without actually having the camera in my test setup. I've never seen a camera stop being detected like that. I did order the cameras but won't have them in my possession until the 9th of January.
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  @Eric-Katzfey My apologies. I thought I sent a response to this.
                  Totally get it. Debugging over a message board is really hard. I believe my associate is getting some of the cameras to your offices sooner than the 9th.
                  I have been continuing to try different things on our end.
                    #54
                    @wilkinsaf I have both of the cameras now. I have updated libuvc to version 1.0.3 (http://voxl-packages.modalai.com/dev/) and voxl-uvc-server to version 0.0.6 (http://voxl-packages.modalai.com/dev/). The voxl-uvc-server update isn't really necessary but I cleaned up a little bit of the debug logic. There was a check that was failing in libuvc for the Blue Robotics camera (USB 32e4:9422, "H264 USB Camera") so I removed that check and then it started working. So far it has been reliable. The other camera (USB 337b:090c, "HBVCAM 5M-AF") was coming up without these changes. However, it isn't reliable. Sometimes uvc_open will fail, other times it will pass. If it passes then sometimes it will successfully start streaming and other times it will think it was successful but gets no frames. Not sure why it is having these issues so need to debug more.
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      @Eric-Katzfey Awesome!
                      Thank you Eric. Will try that out and report back
                        #56
                        @wilkinsaf A new version of voxl-uvc-server was just posted here: http://voxl-packages.modalai.com/dev/. Documentation has been updated accordingly: https://docs.modalai.com/voxl-uvc-server/. Seems to be working pretty well with your cameras but one of them will fail occasionally. The program will fail and you can try again when that happens. Still not sure why it isn't reliable on all cameras.
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          @Eric-Katzfey Nice! Thank you for putting the time in to get that for us.
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @Eric-Katzfey the uvc-server appears to be working. however, the voxl-streamer does not seem to be able to connect to the pipe. is there a different voxl-streamer command than what was mentioned above?
                            voxl-streamer -f /usr/share/modalai/voxl-streamer/voxl-streamer.conf -c uvc-server
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              #59
                                @wilkinsaf Yes, there is a newer version of voxl-streamer available that has some new configurations defined. See documenation here: https://docs.modalai.com/voxl-streamer/#streaming-uvc-cameras-from-voxl-uvc-server
                                  wilkinsafW Offline
                                  wilkinsafW Offline
                                  wilkinsaf
                                  #61
                                  @Eric-Katzfey I am not seeing the uvc-generic in my /etc/modalai/voxl-streamer.conf file after my install of voxl-streamer_0.2.7_202111272338.ipk
                                  Is there a repo online of these .conf files?
                                  I found the voxl-streamer.conf file in the gitlab repo, however I do not see the uvc-generic tag in any of the branches I looked through
                                    @wilkinsaf Sorry, forgot to deploy the latest one. It is there now.
                                      wilkinsafW Offline
                                      wilkinsafW Offline
                                      wilkinsaf
                                      @Eric-Katzfey Got it working about 50% of the time. It seems like most of the time it is just the uvc server trying to connect. I am going to see if I can create a service file around it. Maybe restarting on fail will get it to work with a bit of delay in between.
                                      A bandaid for the issue, but at least it will work
