    Unbricking fails due to "protocol error"
    VOXL
    • NirgeN
      Nirge
      I have bricked a voxl in dev, trying to restore using the debug expansion, but the process fails:
      ~/Downloads/modalai-3-1-0$ sudo ./install.sh
      [INFO] adb installed
      [INFO] fastboot installed
      This process will completely wipe your VOXL
      Would you like to preserve the /data/ partition which contains
      things like calibration, wifi config, and docker images
      To preserve files in /data/ answer Y
      To wipe /data/ for a full factory flash answer N
      Enter Y or N:
      n
      [INFO] Rebooting into fastboot...
      error: no devices/emulators found
      [INFO] Waiting for fastboot...
      target reported max download size of 536870912 bytes
      sending 'aboot' (494 KB)...
      OKAY [  0.047s]
      writing 'aboot'...
      OKAY [  0.444s]
      finished. total time: 0.492s
      sending 'boot' (56066 KB)...
      OKAY [  2.140s]
      writing 'boot'...
      OKAY [  0.745s]
      finished. total time: 2.885s
      erasing 'system'...
      OKAY [  0.004s]
      sending sparse 'system' 1/3 (523027 KB)...
      FAILED (data write failure (Protocol error))
      finished. total time: 9.678s
      Would appreciate any insights and help I can get.
      • Chad SweetC
        Chad Sweet ModalAI Team
        Are you flipping the fastboot switch back? Your symptom is consistent with leaving the fastboot switch engaged instead of setting it back to normal after a few seconds
        Might be worth watching the tutorial here if you're unsure
        • NirgeN
          Nirge
          Missed that part, thank you, it seems to do the trick.
