Feasibility check: 5x M0166 (AR0144) tracking cameras on a single VOXL 2
We are planning to connect five M0166 (AR0144, micro-coax) tracking cameras to a single VOXL 2 (not VOXL 2 Mini), and would like to confirm feasibility before ordering hardware.
- Use case: 360° coverage
- Frame sync across all five cameras: required
- Target: 1280x800 @ 30 fps
From the docs and forum threads (topics 5010, 4491, 5130), our understanding is:
- VOXL 2 has only 4 unique CCI buses, so with five AR0144s at least one must use the alternate slave address (0x20) via the resistor change plus an alt-address sensormodule.
- The confirmed 4x AR0144 setup is C27 on M0173 plus one alt-address AR0144 on J8 via M0155.
- Adding a fifth AR0144 on J8 lower (ID4) would put a third AR0144 on CCI1, so we are considering J8 upper (ID5, CCI3) via M0172 J2U instead.
Proposed layout (no ToF):
Sensor ID Connection CCI Slave address 0 M0173 J1 (J6 lower) CCI0 default 1 M0173 J4 (J6 upper) CCI1 alt (0x20) 6 M0173 J2 CCI1 default 2 M0173 J5 (J7 lower) CCI2 default 5 M0172 J2U on VOXL 2 J8 (upper) CCI3 default Questions:
- Is this layout supported, or at least expected to work, with the M0173 kernel config (platform config 1)? In particular, is sensor ID 5 (J8 upper) enabled in that kernel and usable with an AR0144 through M0172 J2U?
- Is an alt-address (0x20) sensormodule for slot 1 included in the current SDK, or only in the zip shared in topic 5010? Is there an alt-address + fsin variant?
- Frame sync: can all five cameras be synchronized on GPIO 109? Is the sync line routed to M0172 J2U, and does M0173 J4 (ID1) need any resistor changes (similar to R10/R11 on M0188)? Is an ar0144_fsin_5 sensormodule available?
- Can ModalAI supply an M0166 with the alternate slave address pre-configured, so we don't have to modify the module ourselves and void the warranty?
- Are there known throughput limits (CSI / ISP / camera server CPU) for 5x AR0144 at 1280x800 @ 30 fps on VOXL 2?
- If this layout is not recommended, what is the recommended way to run five AR0144s on VOXL 2 (e.g. M0226 or other adapters)?
Hello @박민솔 ,
Your analysis is spot on. Let me provide answers to your questions:
Yes, this layout should work. For platform config , J8U slot is enabled for either full 4-lane hi-res camera or a tracking camera is just fine. M0172 or M0181 can be used (upper slot for both) and both patch through the common sync signal (GPIO 109 from voxl2).
we will include into the SDK / camera server (the sensormodules will be maintained here https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/tree/master/chi-cdk/qrb5165 ) and shipped with SDK soon.
sync is routed to M0172 JU and M0181 JU. However, M0173 J4 (ID1) is missing a resistor (R5) connecting the sync to the camera. Note that M0226 has this resistor installed : https://docs.modalai.com/M0226/#image-sensor-synchronization. We will make fsin sensormodules available for all IDs. If you need to enable M0173, we can provide location of R5 for manual installation.
Depends on how many you need. We have a small quantity in stock.
No limits that would prevent you from running 5x AR0144 at 1280x800 30fps. Up to 7 cameras is possible on voxl2, but unfortunately the limit is in the available interposer combinations - in this config two other slots are taken by TOF / Thermal camera (TOF has a different connector and Thermal cameras have different ucoax pinout, incompatible with regular cameras).This should be pretty quick to test, let me know if you want me to run the test, I can do it later this week.
Any other questions?
Thank you for the detailed answers, this is very helpful.
Yes, we would really appreciate it if you could run the test. Based on your answers, we plan to use M0226 instead of M0173 so no R5 rework is needed. We would also like to add one thermal camera. Since we haven't decided between Lepton and Boson yet, could you test both variants, one thermal camera at a time?
Common: 5x M0166 (AR0144), all frame-synced on GPIO 109, 1280x800 @ 30 fps
Sensor ID Connection Camera Slave address 0 M0226 J1 M0166 default 6 M0226 J2 M0166 default 1 M0226 J4 M0166 alt (0x20) 2 M0226 J5 M0166 default 5 VOXL 2 J8 upper (M0172 J2U or M0181 J2) M0166 default Test A: + FLIR Lepton 3.5 on the M0226 Lepton connector (J6), using voxl-lepton-server.
Test B: + FLIR Boson+ 640 on VOXL 2 J8 lower via M0181 J1, with the fifth M0166 on M0181 J2 (J8 upper).
What we'd like to confirm in each test:
- All five AR0144 streams running at 1280x800 @ 30 fps with synchronized timestamps (e.g. voxl-check-cam-sync)
- The thermal camera streaming at the same time
- Approximate CPU load and any dropped frames
A few related questions:
- The M0153 page says a second camera on M0181 J2 is only compatible with VOXL 2 J7. Is that still the case, or can M0181 J2 on VOXL 2 J8 be used for an AR0144 as in Test B?
- In Test B, the Boson (ID4) shares CCI1 with ID1 (alt address) and ID6. Is that expected to be fine?
- We'd like to purchase 2 pre-configured alt-address M0166 units (one for ID1, one spare). How can we place the order?
- Is there an estimated SDK release for the alt-address and fsin sensormodules for all IDs?
Thanks again!
Alright, i will try to get this done by end of this week.
A few notes:
- Lepton and Boson can actually run together, so i will try that (since Lepton uses SPI, not MIPI protocol)
- I will be testing with M0173 with resistor fix due to availability on my end
- M0153 note about Voxl2 J7 is outdated. It works on Voxl2 J8 as well, in fact M0181 best fits into J8 and mounting hole aligns, see image below
- Boson and AR0144 have different CCI slave addresses, so they will not conflict
- i will double check how to purchace the ALT address AR0144
- will try to release the AR0144 drivers at the same time as i test, hopefully by end of this week
Hi @박민솔 ,
There is a way to change the AR0144 slave address in software (after camera hardware reset) so that to identical modules can coexist on the same CCI bus. In short, since the sensors are powered on one by one, during the AR0144 power on, the slave address can be changed (by the kernel) from the default address (0x30) to a new value, so that the camera no longer responds to the default value. So, the two conflicting AR0144 sensors would have their slave addresses changed to a different non-default value, then used as usual.
We already tested this in another setup, but I am going to test this feature. A kernel change is required, but it is not significant. This would simplify things if it works. However, we do have the modified AR0144 cameras to order if you still wanted to go that route.
@박민솔 , i also wanted to double check. Is there a reason why you want 5x AR0144 and not a combination of AR0144 and IMX412? IMX412 is a very nice camera and has a good lens and provides much higher resoution image (up to 4040x3040). Is it the extra weight or rolling shutter the reason to choose all AR0144 ?
Hi @alex-kushleyev ,
Thank you, the software slave-address change sounds great. If it works, we would prefer that approach, since all five cameras could then be standard M0166 units (easier spares and no warranty issue). A few follow-ups:
- Does the changed address persist across a camera server restart or a sensor reset, or only until reboot? (We noticed the OV7251 runtime address swap skips sensor resets for this reason.)
- Will the kernel change be included in an upcoming SDK / system image release, and does it work together with the fsin (sync) sensormodules?
- We will keep the pre-modified M0166 as a fallback. Please let us know the result of your test.
Regarding AR0144 vs IMX412, the reasons we chose AR0144 for all five visual cameras:
- Same-instant 360° capture: Our goal is to capture like a 360° camera, where every direction is captured at exactly the same moment. Global shutter plus hardware sync on all five cameras is the key requirement. With rolling shutter, each row is exposed at a different time, so motion causes skew and the frames from different cameras would not truly match.
- Stability over resolution: Reliably getting synchronized frames from all directions, quickly and without drops, matters more to us than image resolution. The 162° fisheye also gives five cameras enough overlap to cover 360°.
- Portable device: The system is meant to be portable (handheld), so weight matters, and hand motion makes rolling shutter artifacts more likely.
So our target configuration remains 5x AR0144 for 360° capture plus one thermal camera, as in our test request (Test A: Lepton 3.5, Test B: Boson+ 640). We will choose the thermal camera based on your test results, so it would be great if both variants could be covered in the test.
One more question: we may need color images. Is the color AR0144 variant (M0166-2) available, and would 5x color AR0144 with sync and CPU debayering at 1280x800 @ 30 fps be feasible on VOXL 2?
