voxl-mapper local planner: "Cannot insert trajectory. Total segments = 20, Max segments = 20" — replanning never reaches the drone during Follow Path
We flew our first mapper-based path flight on a Starling 2 Max and the drone did follow the planned path. However, the local planner was unable to deliver a single trajectory for the entire flight, so the drone was flying on the one path computed before departure, with no replanning.
What happened
Global planning succeeded:
05:13:38 Client requested plan to location 05:13:38 Using start pose of: x: 1.67, y: -0.80, z: -1.46 05:13:38 Using goal pose of: x: 5.16, y: -1.34, z: -0.89 05:13:38 Starting RRTConnect planner 05:13:38 Immediate collision free path found!Then, from the instant we pressed Follow Path, this repeated continuously for 2 min 16 s until we took manual control:
05:14:10 Client requested to follow last path 05:14:10 Local Planner failed to send trajectory 05:14:10 ERROR: Cannot insert trajectory. Total segments = 20, Max segments = 20 ... (repeats at roughly 1-2 s intervals through 05:16:26)Throughout those 2 min 16 s the planner itself was running normally —
A* took = 0.07-0.14 ms for 13 iterationsandSmoother took = 6-12 mswere interleaved with every failure. So it computes a trajectory and then cannot insert it.The drone moved 2.68 m straight-line / 8.79 m total path at up to 1.04 m/s, which matches the pre-computed path. It stopped 0.81 m short of the goal only because the pilot intervened.
What we ruled out
- Not a planning failure — the global path was found and reported collision-free.
- Not a VIO problem — dt held at 33.3 ms for all 44 samples in flight, features 15-30,
cs_ev_pos/cs_ev_yaw/cs_ev_hgtall True. - Not a map problem —
voxl_mapper_aligned_ptcloudwas producing 1,489-2,925 points at ~10 Hz before and during the flight. - Not CPU load — load average dropped from 7.75 on the ground to 4.5 in flight; governor was
performance. - Not thermal throttling — 94-96 C, but
scaling_cur_freqequalledcpuinfo_max_freqon all cores anddmesgshowed no throttle events. - Not a config we changed —
voxl-mapper.confis stock;loco_num_segmentsis 10.
What we could not find
The limit of 20 does not appear in
voxl-mapper.conf.loco_num_segmentsis 10, which is not the number in the error. We could not locate a setting that exposesMax segments.One thing we suspect, but have not tested
Before the successful
Go, we had two failed ones — both rejected withERROR: End point is in collisionbecause the goal came in atz: 0.00(we were clicking in the 2D view, which puts the point at ground level). TheMax segments = 20error appeared immediately on the first Follow Path, which makes us wonder whether failed plans leave segments behind. We have not yet tested whether pressing Clear Paths first avoids it.Questions
- Where is the 20-segment limit set, and is it configurable?
- What normally fills the segment buffer, and what clears it? Does a failed
Goleave segments allocated? - Is
Clear Pathsthe correct way to reset this state beforeFollow Path? - Is there a way to detect this condition other than reading the mapper journal? From the Portal UI everything looked correct — the path was drawn and
Immediate collision free path found!was reported — so an operator has no indication that obstacle avoidance is not active.
Environment
- Hardware: Starling 2 Max, SKU
MRB-D0012-4-V4-C29-T8-M36 voxl-version: system-image1.8.08-M0054-14.1a-perf, voxl-suite1.6.4~beta5voxl-mapper0.2.4,voxl-vision-hubwithoffboard_mode: "trajectory"- Services active at the time:
voxl-vision-hub,voxl-open-vins-server,voxl-mapper,voxl-px4,voxl-portal
We have the full mapper journal and the PX4
.ulgfrom this flight and can share either. -
안영하세요 진혁씨,
Apologies for the late response. We are currently configuring a Starling Max 2 to replicate your setup and will get back to you with more information by the end of this week. Thanks!
