  2. VOXL SDK and Software
  3. QGC Actuators metadata unavailable with SDK 1.8 / PX4 1.18 through voxl-mavlink-server
Scheduled Pinned Locked Moved Solved VOXL SDK and Software
4 Posts 2 Posters 292 Views 1 Watching
  • S Offline
    S Offline
    simiken1234
    wrote last edited by
    Title: QGC Actuators metadata unavailable with SDK 1.8 / PX4 1.18 through voxl-mavlink-server
    Hardware: Custom drone, VOXL 2 M0054
    SKU: TF-M0054-4-V1-C11
    Software version:
    system-image: 1.8.09-M0054-14.1a-perf-20261009
    hw platform:  M0054
    voxl-suite:   1.8.0
    Relevant packages:
    voxl-px4            1.18.0-1.0.9
    voxl-mavlink-server 1.4.20
    voxl-px4-params     0.9.35
    I can provide the full voxl-version output if needed.
    Configuration / services:
    voxl-px4 and voxl-mavlink-server are both enabled and running.
    voxl-mavlink-server | Enabled | Running
    voxl-px4            | Enabled | Running
    What I am trying to do:
    Configure the vehicle in QGroundControl and access the PX4 Actuators setup page.
    What actually happens:
    The Actuators page is absent in both our QGC 5.1.5 build and stock QGC 5.2.0; QGC shows the legacy Motors page instead.
    PX4 accepts the component-metadata request and these files exist:
    /data/px4/etc/extras/component_general.json.xz
    /data/px4/etc/extras/actuators.json.xz
    PX4 is started with MAVLink FTP enabled (mavlink start -x).
    However, voxl-mavlink-server receives MAVLink FTP open requests for the PX4 metadata files, but no file data is returned to the GCS:
    [INFO] FTP opcode: 4
    [INFO] FTP seq_number: 1
    [INFO] FTP session: 0
    [INFO] path request?
    Offset: 0
    The same occurs for etc/extras/actuators.json.xz. QGC's component-metadata cache remains empty, so it cannot create the Actuators page.
    Steps to reproduce:
    1. Boot VOXL with the versions above.
    2. Connect QGroundControl to voxl-mavlink-server on UDP port 14550.
    3. Open Vehicle Setup.
    4. Observe that Actuators is absent.
    5. Run journalctl -b -u voxl-mavlink-server and observe FTP opcode 4 requests for etc/extras/component_general.json.xz.
    Logs / pictures:
    I can attach full voxl-version, voxl-inspect-services, and relevant voxl-mavlink-server journal output.
    Could you confirm whether voxl-mavlink-server 1.4.20 is expected to forward PX4-targeted FILE_TRANSFER_PROTOCOL requests for component metadata, or whether there is a newer package/fix for PX4 1.18 component metadata support?
    • Eric KatzfeyE Online
      Thanks! Looking at some possible resolutions now.
        voxl-mavlink-server v1.4.21 has a quick fix for this issue. http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mavlink-server_1.4.21-202610161525_arm64.deb
        • S Offline
          S Offline
          simiken1234
          Fix verified working, thank you Eric!
          • S simiken1234 has marked this topic as solved
