  2. Software Development
  3. VOXL SDK
  4. voxl-mavcam-manager in differnt versions
Scheduled Pinned Locked Moved VOXL SDK
6 Posts 3 Posters 342 Views
  • A Offline
    arvind_g3aero
    wrote last edited by
    Hi team,
    We are working on voxl2 board.In mavcam manager we have encountered issue .With 1.3.5 and 1.4.0 sdk multiple cameras switching through mavcam manager is not happening,working for one camera and snapshot is saved in GCS QGC and also in /data/snapshots folder.
    With 1.6.2 sdk multiple cameras switching through mavcam manager is happening but while we are trying for snapshot voxl-camera serveris disconnecting and connecting again.We have verified by running voxl-camera-server -d in terminal it is giving no buffer space available .If we disable snapshot in voxl-camera-server then it is not crashing and no buffer space error is also not seen .
    Our requirement is we have two camera switching and snapshot is also required.Please suggest which sdk to use
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @arvind_g3aero - how many cameras are you running? Can you paste the logs exactly - it is hard to understand the issue without the logs.
      As for snapshot - when you change the stream in qgc, the snapshot is probably not tied to the new rtsp steam, causing a fault on the backend - I can look into this at somepoint in the next fwe days.
      As for 1.3.5 and 1.4.0 those SDK's do NOT support multi camera streaming into qgc.
      Zach
      • A Offline
        arvind_g3aero
        Hi Zach,
        Thanks for your quick reply.
        We are having total 3 cameras,hires imx214,tracking ov7251and usb camera lepton.
        SDK we are using is 1.6.2
        voxl2 (M0054):/$ voxl-camera-server -d 2
        detected system image 1.8.6
        using new imx214 defaults
        configuration for 2 cameras:
        cam #0
        type: ov7251
        bayer_type: 0
        enabled: 1
        camera_id: 0
        camera_id_second: -1
        fps: 30
        en_rotate: 1
        en_rotate2: 0
        en_preview:          1
        en_raw_preview:      1
        preview_width:       640
        preview_height:      480
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
        cam #1
        type: imx214
        bayer_type: 2
        enabled: 1
        camera_id: 1
        fps: 15
        en_rotate: 0
        en_rotate2: 0
        en_preview:          0
        en_raw_preview:      0
        preview_width:       1920
        preview_height:      1080
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_small_video:      1
        small_video_width:   640
        small_video_height:  480
        en_large_video:      0
        large_video_width:   4208
        large_video_height:  3120
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        fsync_en: 0
        fsync_gpio: 109
        connected to mavlink pipe
        Connected to cpu-monitor
        Starting Camera: tracking (id #0)
        setting ov7251 BLC register for cam id 0
        Starting Camera: hires (id #1)
        Estimated imu dt = 0.000976s
        ------ voxl-camera-server: Started 2 of 2 cameras
        Camera: hires taking snapshot (destination: /data/snapshots/hires-2026-08-04_06:55:02.474.jpg)
        ERROR: bufferGetBufferInfo wan't able to successfully find the requested buffer
        Segmentation fault:
        Fault thread: cam1-result(tid: 20257)
        Segmentation fault
        voxl-mavcam-manager
        input #0:
        snapshot_pipe_name: hires_snapshot
        video_record_pipe_name: hires_small_encoded
        default_uri: rtsp://192.168.168.156:8900/live
        enable_auto_ip: 1
        mavlink_sys_id: 1
        input #1:
        snapshot_pipe_name: uvc
        video_record_pipe_name: uvc
        default_uri: rtsp://192.168.168.156:8901/live
        enable_auto_ip: 1
        mavlink_sys_id: 1
        existing instance of voxl-mavcam-manager found, attempting to stop it
        COMPID: 100
        Mavlink server Connected
        COMPID: 100
        Error trying to send control command to pipe ch2 /run/mpa/mavlink_to_gcs/, not connected
        auto-detected RTSP URI: rtsp://192.168.168.156:8900/live
        Sending stream info to gcs: rtsp://192.168.168.156:8900/live
        auto-detected RTSP URI: rtsp://192.168.168.156:8901/live
        Sending stream info to gcs: rtsp://192.168.168.156:8901/live
        Unable to find valid pipe that accepts control commands at: uvc
        Successfully sent command to /run/mpa/hires_snapshot/control
        Sending camera_settings with mode VIDEO to gcs
        Sending camera_settings with mode IMAGE to gcs
        root@arvind-Victus-by-HP-Gaming-Laptop-15-fa0xxx:/home/arvind# adb shell
        kernel: #1 SMP PREEMPT Wed Oct 22 03:21:50 UTC 2025 4.19.125
        hw platform: M0054
        mach.var: 1.0.0
        SKU: MCCA-M0054-CC-T0-M0-X0
        voxl-suite: 1.6.2
        current IP: usb0: 192.168.168.156
        voxl2 (M0054):/$
        voxl2 (M0054):/$ cat /home/root/voxl-thermal-streamer_bkp1.sh
        #!/bin/bash
        sleep 3
        echo "uvc camera feed on 192.168.168.156:8901 "
        voxl-streamer --standalone --port 8901 -i uvc -b 200000
        We have 2 camera streams one with voxl-streamer----hires_small_encoded on 8900 port
        other with voxl-streamer standalone with one service ---uvc on 8901 port
        Through mavcam manager (0.6.0) we are able to switch the camera streams in QGC .But while taking snapshot,snapshot is saving in GCS QGC with resolution of GCS Display and snapshot not saving in /data/snapshots folder
        while we are trying with command line also snapshot is not saving meanwhile camera server crashing:
        voxl-send-command hires_snapshot snapshot
        voxl2 (M0054):/data/snapshots$ ls -ltr
        total 0
        voxl-camera-server crashed:
        Camera: hires taking snapshot (destination: /data/snapshots/hires-2026-08-04_07:09:12.701.jpg)
        Segmentation fault:
        Fault thread: cam1-result(tid: 16326)
        Segmentation fault
        voxl2 (M0054):/$
        While we are trying in old sdk 1.3.5 and 1.4.0 snapshot is saving in /data/snapshots folder but 2 cmaera switching is not happening through mavcam manager
        Our requirement is to switch two streams and also screenshot need to be saved in /data/snapshots folder
        Please suggest us which SDK to use for both purpose(camera switching and also snapshot) ,and what is that buffer issue in 1.6.2 SDK
        Thank you
        • A Offline
          ApoorvThapliyal
          Hey Arvind,
          Could you try using this version of voxl-camera-server: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-camera-server_2.2.32-202607291154_arm64.deb
          Im able to get 2 camera streams, and every time I click the save picture button on QGC I see the snapshots saved without any issues.
          Heres some versions of my packages I am using:
          voxl-camera-server 2.2.32
          voxl-mavcam-manager 0.6.1-202601081558
          voxl-streamer 0.8.1
          • A Offline
            arvind_g3aero
            Hi,Apoorv Thapliyal,
            Thanks for the suggestions made.
            We have tried 1.4.5 SDK on Voxl2 board and we are able to get snapshot in both QGC and also in /data/snapshots folder in the board .If we try to change resolution of snapshot in voxl-camera-server ,it is applied to resolution of snapshot saved in /data/snapshot folder in voxl2 board.
            • A Offline
              arvind_g3aero
              Hi Dev Team ,
              Any update regarding snapshots through voxl-mavcam-manager in 1.6.2 SDK on VOXL2 board.
              Please suggest us which SDK to use for snapshot usage on VOXL2 .
              S.Arvind
