  3. Unable to execute autonomous waypoint mission using QGroundControl
1 Posts 1 Posters 794 Views
  • S Offline
    S Offline
    scruz1088
    I am using a starling2 max with a voxl 2. I am using wifi for telemetry and successfully uploaded a waypoint mission in QGroundControl. When I try to execute the mission, the drone arms but never takes off. Below is the voxl-version and voxl-inspect-services output:
    voxl-version:
    system-image: 1.8.04-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          MRB-D0012-4-V2-C29-T7-M28-X0
    voxl-suite:   1.5.0
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.5/binary-arm64/
    Last Updated: 2026-06-18 19:39:25
    List:
    libfc-sensor                1.0.7
    libmodal-cv                 0.5.18
    libmodal-exposure           0.1.4
    libmodal-journal            0.2.6
    libmodal-json               0.4.7
    libmodal-pipe               2.13.2
    libqrb5165-io               0.5.0
    libvoxl-cci-direct          0.3.3
    libvoxl-cutils              0.1.5
    modalai-slpi                1.2.0
    mv-voxl                     0.1-r0
    qrb5165-bind                0.1-r0
    qrb5165-dfs-server          0.2.0
    qrb5165-imu-server          1.1.3
    qrb5165-mini-tof-server     0.2.2
    qrb5165-rangefinder-server  0.1.5
    qrb5165-slpi-test-sig       01-r0
    qrb5165-system-tweaks       0.3.6
    qrb5165-tflite              2.8.0-2
    voxl-bind-spektrum          0.1.1
    voxl-camera-calibration     0.6.0
    voxl-camera-server          2.2.4
    voxl-ceres-solver           2:1.14.0-10
    voxl-configurator           1.0.2
    voxl-cpu-monitor            0.6.0
    voxl-docker-support         1.3.1
    voxl-elrs                   0.4.7
    voxl-esc                    1.5.4
    voxl-feature-tracker        0.5.2
    voxl-flow-server            0.3.6
    voxl-gphoto2-server         0.0.10
    voxl-joystick-server        0.0.6
    voxl-jpeg-turbo             2.1.3-7
    voxl-lepton-server          1.3.3
    voxl-lepton-tracker         0.0.4
    voxl-libgphoto2             0.0.4
    voxl-libuvc                 1.0.7
    voxl-logger                 0.5.3
    voxl-mavcam-manager         0.6.0
    voxl-mavlink                0.1.5
    voxl-mavlink-server         1.4.9
    voxl-microdds-agent         3.0.0-0
    voxl-modem                  1.1.8
    voxl-mongoose               7.7.0-2
    voxl-mpa-to-ros             0.3.9
    voxl-mpa-to-ros2            0.0.7
    voxl-mpa-tools              1.4.0
    voxl-open-vins              0.4.19
    voxl-open-vins-server       0.3.12
    voxl-opencv                 4.5.5-3
    voxl-osd                    0.1.8
    voxl-portal                 0.7.11
    voxl-px4                    1.14.0-2.0.105
    voxl-px4-params             0.7.5
    voxl-qvio-server            1.2.0
    voxl-remote-id              0.0.9
    voxl-reset-slpi             0.0.1
    voxl-ros2-foxy              0.0.1
    voxl-state-estimator        0.0.5
    voxl-streamer               0.7.5
    voxl-suite                  1.5.0
    voxl-tag-detector           0.0.5
    voxl-tflite-server          0.4.1
    voxl-utils                  1.4.8
    voxl-uvc-server             0.1.7
    voxl-vision-hub             1.8.23
    voxl-vtx                    1.4.7
    voxl-wavemux                0.0.1
    voxl2-io                    0.0.3
    voxl2-system-image          1.8.04-r0
    voxl2-wlan                  1.0-r0
    voxl-inspect-services :
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           |  Enabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |    80.7%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     3.5%
     voxl-joystick-server     | Disabled  | Not Running |
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |     3.5%
     voxl-microdds-agent      |  Enabled  |   Running   |
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-modem               | Disabled  | Not Running |
     voxl-mpa-ros2            | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |     1.8%
     voxl-portal              |  Enabled  |   Running   |    24.6%
     voxl-px4                 |  Enabled  |   Running   |
     voxl-qvio-server         | Disabled  | Not Running |     0.0%
     voxl-rangefinder-server  |  Enabled  |   Running   |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-seek-server         | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-static-ip           | Disabled  | Not Running |     1.8%
     voxl-streamer            |  Enabled  |   Running   |
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |     0.0%
     voxl-vision-hub          |  Enabled  |   Running   |
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    I have 3 logs from recent flights:
    https://logs.px4.io/plot_app?log=ef58c5c5-b105-41e0-bd12-202e5ff7f206
    https://logs.px4.io/plot_app?log=e6654338-39fb-4429-b242-224fa468a522
    The following image shows the intended waypoint mission.
    https://drive.google.com/file/d/1FKFF4qVOXKiCqwCgiltWpe0bm_KrqHKj/view?usp=sharing
    Please let me know if there is any advice about how I can get it to correctly execute the waypoint mission.
