<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to execute autonomous waypoint mission using QGroundControl]]></title><description><![CDATA[<p dir="auto">I am using a starling2 max with a voxl 2. I am using wifi for telemetry and successfully uploaded a waypoint mission in QGroundControl. When I try to execute the mission, the drone arms but never takes off.  Below is the voxl-version and voxl-inspect-services output:</p>
<p dir="auto"><code>voxl-version</code>:</p>
<pre><code class="language-────────────────────────────────────────────────────────────────────────────────">system-image: 1.8.04-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
hw platform:  M0054
mach.var:     1.0.1
SKU:          MRB-D0012-4-V2-C29-T7-M28-X0
voxl-suite:   1.5.0
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.5/binary-arm64/
Last Updated: 2026-06-18 19:39:25
List:
libfc-sensor                1.0.7
libmodal-cv                 0.5.18
libmodal-exposure           0.1.4
libmodal-journal            0.2.6
libmodal-json               0.4.7
libmodal-pipe               2.13.2
libqrb5165-io               0.5.0
libvoxl-cci-direct          0.3.3
libvoxl-cutils              0.1.5
modalai-slpi                1.2.0
mv-voxl                     0.1-r0
qrb5165-bind                0.1-r0
qrb5165-dfs-server          0.2.0
qrb5165-imu-server          1.1.3
qrb5165-mini-tof-server     0.2.2
qrb5165-rangefinder-server  0.1.5
qrb5165-slpi-test-sig       01-r0
qrb5165-system-tweaks       0.3.6
qrb5165-tflite              2.8.0-2
voxl-bind-spektrum          0.1.1
voxl-camera-calibration     0.6.0
voxl-camera-server          2.2.4
voxl-ceres-solver           2:1.14.0-10
voxl-configurator           1.0.2
voxl-cpu-monitor            0.6.0
voxl-docker-support         1.3.1
voxl-elrs                   0.4.7
voxl-esc                    1.5.4
voxl-feature-tracker        0.5.2
voxl-flow-server            0.3.6
voxl-joystick-server        0.0.6
voxl-jpeg-turbo             2.1.3-7
voxl-lepton-server          1.3.3
voxl-lepton-tracker         0.0.4
voxl-logger                 0.5.3
voxl-mavcam-manager         0.6.0
voxl-mavlink                0.1.5
voxl-mavlink-server         1.4.9
voxl-microdds-agent         3.0.0-0
voxl-modem                  1.1.8
voxl-mongoose               7.7.0-2
voxl-mpa-to-ros             0.3.9
voxl-mpa-to-ros2            0.0.7
voxl-mpa-tools              1.4.0
voxl-open-vins              0.4.19
voxl-open-vins-server       0.3.12
voxl-opencv                 4.5.5-3
voxl-osd                    0.1.8
voxl-portal                 0.7.11
voxl-px4                    1.14.0-2.0.105
voxl-px4-params             0.7.5
voxl-qvio-server            1.2.0
voxl-reset-slpi             0.0.1
voxl-ros2-foxy              0.0.1
voxl-state-estimator        0.0.5
voxl-streamer               0.7.5
voxl-suite                  1.5.0
voxl-tag-detector           0.0.5
voxl-tflite-server          0.4.1
voxl-utils                  1.4.8
voxl-uvc-server             0.1.7
voxl-vision-hub             1.8.23
voxl-vtx                    1.4.7
voxl-wavemux                0.0.1
voxl2-io                    0.0.3
voxl2-system-image          1.8.04-r0
voxl2-wlan                  1.0-r0
<p dir="auto"><code>voxl-inspect-services</code> :</p>
<pre><code>Scanning services...
 docker-autorun           |  Enabled  | Not Running |
 voxl-camera-server       |  Enabled  |   Running   |    80.7%
 voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
 voxl-elrs-startup        | Disabled  | Not Running |
 voxl-imu-server          |  Enabled  |   Running   |     3.5%
 voxl-joystick-server     | Disabled  | Not Running |
 voxl-lepton-tracker      | Disabled  | Not Running |
 voxl-logger              | Disabled  | Not Running |
 voxl-mavlink-server      |  Enabled  |   Running   |     3.5%
 voxl-microdds-agent      |  Enabled  |   Running   |
 voxl-mini-tof-server     | Disabled  | Not Running |
 voxl-modem-doodle        | Disabled  | Not Running |
 voxl-mpa-ros2            | Disabled  | Not Running |
 voxl-open-vins-server    | Disabled  | Not Running |
 voxl-osd                 | Disabled  | Not Running |     1.8%
 voxl-portal              |  Enabled  |   Running   |    24.6%
 voxl-px4                 |  Enabled  |   Running   |
 voxl-qvio-server         | Disabled  | Not Running |     0.0%
 voxl-rangefinder-server  |  Enabled  |   Running   |
 voxl-seek-server         | Disabled  | Not Running |
 voxl-state-estimator     | Disabled  | Not Running |
 voxl-static-ip           | Disabled  | Not Running |     1.8%
 voxl-streamer            |  Enabled  |   Running   |
 voxl-uvc-server          | Disabled  | Not Running |     0.0%
 voxl-vision-hub          |  Enabled  |   Running   |
 voxl-vrx                 | Disabled  | Not Running |
 voxl-vtx                 | Disabled  | Not Running |
<p dir="auto">I have 3 logs from recent flights:<br />
<a href="https://logs.px4.io/plot_app?log=ef58c5c5-b105-41e0-bd12-202e5ff7f206" rel="nofollow ugc">https://logs.px4.io/plot_app?log=ef58c5c5-b105-41e0-bd12-202e5ff7f206</a><br />
<a href="https://logs.px4.io/plot_app?log=e6654338-39fb-4429-b242-224fa468a522" rel="nofollow ugc">https://logs.px4.io/plot_app?log=e6654338-39fb-4429-b242-224fa468a522</a><br />
<a href="https://logs.px4.io/plot_app?log=e6654338-39fb-4429-b242-224fa468a522" rel="nofollow ugc">https://logs.px4.io/plot_app?log=e6654338-39fb-4429-b242-224fa468a522</a></p>
<p dir="auto">The following image shows the intended waypoint mission.</p>
<div class="card-body">
<h5 class="card-title">
<a class="text-decoration-none" href="https://drive.google.com/file/d/1FKFF4qVOXKiCqwCgiltWpe0bm_KrqHKj/view?usp=sharing">
</a>
</h5>
<p class="card-text line-clamp-3"></p>
</div>
<a href="https://drive.google.com/file/d/1FKFF4qVOXKiCqwCgiltWpe0bm_KrqHKj/view?usp=sharing" class="card-footer text-body-secondary small d-flex gap-2 align-items-center lh-2">
<img src="https://ssl.gstatic.com/docs/doclist/images/drive_favicon_2026_32dp.png" alt="favicon" class="not-responsive overflow-hiddden" style="max-width:21px;max-height:21px" />
<p class="d-inline-block text-truncate mb-0">Google Docs <span class="text-secondary">(drive.google.com)</span></p>
</a>
</div><p></p>
<p dir="auto">Please let me know if there is any advice about how I can get it to correctly execute the waypoint mission.</p>
]]></description><link>https://forum.modalai.com/topic/5307/unable-to-execute-autonomous-waypoint-mission-using-qgroundcontrol</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 13:45:17 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5307.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jul 2026 00:24:20 GMT</pubDate><ttl>60</ttl></channel></rss>
