    Connecting to QGC Via Transmitter
    • P
      PatkirkMartin
      Hi all,
      Here is my setup:
      • VOXL2 flight controller
      • PX4 autopilot
      • Radiomaster GX12 Transmitter
      • Radiomaster RP2 receiver
      What I would like to do is connect to QGC via the transmitter. However, I am unsure how to go about doing this or if it is even possible on the VOXL2. I've successfully established RC with the FC in CRSF link mode; I can see the stick inputs updating when connected to QGC via USB-C.
      On other flight controllers, I have been able to establish transmitter/QGC connection by putting the transmitter in "Mavlink" mode and connecting to the transmitter WiFi. This does not seem to be working with my VOXL2. I've tried changing the /etc/modalai/voxl-px4.conf "RC" setting to "external" and "crsf_mav" and neither seems to work (maybe I'm missing something).
      Any help would be greatly appreciated. Happy to provide more information as needed.
        Eric Katzfey ModalAI Team @PatkirkMartin
        @PatkirkMartin Mavlink over a DSP mapped UART won't work. However, if you have an accessory board with an apps processor UART available then you should be able to configure that to work with Mavlink.
        P 1 Reply Last reply Reply Quote 0
        • P
          PatkirkMartin @Eric Katzfey
          Thanks for your reply! I am not attempting to establish communication via UART. I have already successfully been communicating the the FC/PX4 via WiFi, ethernet, and USB-C through the ADB shell (link). What I am talking about doing in my post is fundamentally different. I have an ELRS receiver plugged into J19 on the VOXL2. As mentioned in the above post, I have verified that the ELRS receiver/transmitter works for RC inputs over CRSF.
          What I am trying to get working now is using the transmitter for QGC connection. This is possible on other flight controllers by connecting to the transmitter's local WiFi or via USB, but this does not seem to be working in the same way for the VOXL2. I imagine I am missing a specific configuration option or setting somewhere, or maybe this just isn't possible since Mavlink seems to be only communicated via UDP on this device. That is what I am looking for clarity on.
