  2. VOXL SDK and Software
  3. voxl-tflite-server build failed
tflite-servervoxl-sdk
7 Posts 2 Posters 1.7k Views 1 Watching
  • WondosenW Offline
    WondosenW Offline
    Wondosen
    I was able to compile successfully before, but recently the linker has stopped finding the library files "absl_wyhash" and "clog".
    The compilation output is shown below.
    • WondosenW Wondosen
      @Wondosen How are you running ./install_build_deps.sh?
      WondosenW 2 Replies Last reply
        WondosenW Offline
        WondosenW Offline
        Wondosen
        wrote on last edited by Wondosen
        @tom yes I did
        ./install_build_deps.sh qrb5165 dev
          WondosenW Offline
          WondosenW Offline
          Wondosen
          @tom for running, ./build.sh qrb5165
            @Wondosen You're building voxl-tflite-server which is part of SDK 1.4.4, while calling install_build_deps.sh qrb5165 dev will pull the dependencies for a much newer version of voxl-tflite-server than you're using.
            Try running ./install_build_deps.sh qrb5165 sdk-1.4
              @tom I just ran the following successfully:
              cd voxl-tflite-server
              git checkout master
              git pull
              voxl-docker -i  voxl-cross:V2.7
              ./build.sh qrb5165
              ./make_package.sh
              here's a snippet
              [ 60%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/generic_object_detection_model_helper.cpp.o
              [ 66%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/yolov5_model_helper.cpp.o
              [ 73%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/posenet_model_helper.cpp.o
              [ 80%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/yolov8_model_helper.cpp.o
              [ 86%] Building C object src/CMakeFiles/voxl-tflite-server.dir/resize.c.o
              [ 93%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/utils.cpp.o
              [100%] Linking CXX executable voxl-tflite-server
              /usr/lib64//libtensorflow-lite.a(nnapi_delegate.cc.o): In function `tflite::delegate::nnapi::NNMemory::NNMemory(NnApi const*, char const*, unsigned long)':
              nnapi_delegate.cc:(.text+0xd58): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
              [100%] Built target voxl-tflite-server
              voxl-cross(2.7):~(master)(0.4.1)$ ls
              CHANGELOG         build              include                scripts
              CMakeLists.txt    build.sh           install_build_deps.sh  services
              LICENSE           clean.sh           make_package.sh        src
              README.md         debug_source.sh    misc_files
              bash_completions  deploy_to_voxl.sh  pkg
              voxl-cross(2.7):~(master)(0.4.1)$ ./make_package.sh
              Package Name:  voxl-tflite-server
              version Number:  0.4.1
              Consolidate compiler generated dependencies of target voxl-tflite-server
              Install the project...
              -- Install configuration: "DEBUG"
              -- Installing: ../pkg/data/usr/bin/voxl-tflite-server
              /home/root
              starting building Debian Package
              dpkg-deb: building package 'voxl-tflite-server' in 'voxl-tflite-server_0.4.1_arm64.deb'.
              DONE
              WondosenW 1 Reply Last reply
                git checkout master
                git pull
                ./build.sh qrb5165
                ./make_package.sh
                here's a snippet
                /home/root
                DONE
                WondosenW Offline
                WondosenW Offline
                Wondosen
                @tom Thank you so much. It is working now with your suggestion. I think the README file of voxl-tflite-server need to be updated.
