    ESC Calibration and Potential Motor Failure
    Power Modules
    • D
      dan64
      Background
      We are seeing some issues with one of four motors on a Starling 2 Max not spinning at the same rate (very low RPMs). We've run a few troubleshooting steps by attempting to arm and using the voxl-esc-spin.py script.
      Our initial diagnosis is that the motor may need to be replaced since the voltage being passed through is comparable to the voltage passed through to other motors. However, there is no visible damage to the motor or any wires.
      We also attempted to run the px4-esc-cal-tool-v1-11.py according to the instructions here: https://docs.modalai.com/flight-core-pwm-esc-calibration/. We ran into some issues running the script here during the interactive prompts: No Serial Connection Found for px4-esc-cal-tool-v1-11.py
      We were using the provided MCBL-00009-1 JST-to-USB Female A connector, but were unable to establish a serial connection to our machine. See attached image
      We used multiple different connectors along with USB A to C cords to attempt the connection to rule out a cable issue.
      Our development machines are Apple M4 Max MacBook Pros running MacOS Sequoia 15.3.2
      Request(s)
      Do you have any additional troubleshooting steps?
      Any guidance on getting the px4-esc-cal-tool to work?
      Is our diagnosis on the right track and the next steps would be to replace the motors? If so, is there a guide to replacing motors on a Starling 2 Max?
      Output and relevant VOXL version information is attached or pasted below.
      VOXL Version:
      Welcome to Ubuntu 18.04.6 LTS (GNU/Linux 4.19.125 aarch64)
      * Documentation:  https://help.ubuntu.com
      * Management:     https://landscape.canonical.com
      * Support:        https://ubuntu.com/pro
      This system has been minimized by removing packages and content that are
      not required on a system that users do not log into.
      To restore this content, you can run the 'unminimize' command.
      system-image: 1.7.8-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Sat May 18 00:10:25 UTC 2024 4.19.125
      hw platform:  M0054
      mach.var:     1.0.1
      voxl-suite:   1.3.2
      current IP:   tun0: 10.8.0.7
      voxl-esc-spin.py output (trimmed in the middle because values are more or less consistent):
      ./voxl-esc-spin.py --id 255 --power 60 --ramp-time 3.0 --timeout 4.0 --enable-plot 1
      [GCC 8.4.0]
      VOXL Platform: M0054
       Board      : version 40: ModalAi 4-in-1 ESC (M0129-3)
       UID        : 0x2039333557555313002A002D
       Firmware   : version   39, hash eb6fb500
       Bootloader : version  184, hash 10bf24c8
       UID        : 0x2039333557555313002A0022
       UID        : 0x2039333557555313002A002B
       UID        : 0x2039333557555313002A002C
      WARNING:
      from all persons.
      Type "Yes" to continue: yes
      [0.017] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.017] (1) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.017] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.037] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.037] (1) RPM: 0, PWR: 0, VOLTAGE: 16.178V, TEMPERATURE: 45.11C, CURRENT: 0.000A
      [0.037] (2) RPM: 19, PWR: 1, VOLTAGE: 16.160V, TEMPERATURE: 45.97C, CURRENT: 0.000A
      [0.037] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.062] (0) RPM: 68, PWR: 6, VOLTAGE: 16.130V, TEMPERATURE: 46.55C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.153V, BOARD_CURRENT: 0.400A
      [0.062] (1) RPM: 0, PWR: 0, VOLTAGE: 16.178V, TEMPERATURE: 45.11C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.153V, BOARD_CURRENT: 0.400A
      [0.062] (2) RPM: 19, PWR: 1, VOLTAGE: 16.160V, TEMPERATURE: 45.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.153V, BOARD_CURRENT: 0.400A
      [0.062] (3) RPM: 50, PWR: 4, VOLTAGE: 16.153V, TEMPERATURE: 48.16C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.153V, BOARD_CURRENT: 0.400A
      [0.076] (0) RPM: 68, PWR: 6, VOLTAGE: 16.130V, TEMPERATURE: 46.55C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.076] (1) RPM: 85, PWR: 8, VOLTAGE: 16.022V, TEMPERATURE: 45.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.076] (2) RPM: 118, PWR: 11, VOLTAGE: 15.954V, TEMPERATURE: 46.01C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.076] (3) RPM: 140, PWR: 11, VOLTAGE: 15.874V, TEMPERATURE: 48.30C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.092] (0) RPM: 155, PWR: 11, VOLTAGE: 15.868V, TEMPERATURE: 46.51C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.092] (1) RPM: 85, PWR: 8, VOLTAGE: 16.022V, TEMPERATURE: 45.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.092] (2) RPM: 118, PWR: 11, VOLTAGE: 15.954V, TEMPERATURE: 46.01C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.092] (3) RPM: 140, PWR: 11, VOLTAGE: 15.874V, TEMPERATURE: 48.30C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [0.119] (0) RPM: 155, PWR: 11, VOLTAGE: 15.868V, TEMPERATURE: 46.51C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.874V, BOARD_CURRENT: 2.408A
      [3.816] (0) RPM: 15173, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 48.44C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.816] (1) RPM: 745, PWR: 60, VOLTAGE: 15.985V, TEMPERATURE: 46.30C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.816] (2) RPM: 15240, PWR: 60, VOLTAGE: 15.972V, TEMPERATURE: 48.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.816] (3) RPM: 15233, PWR: 60, VOLTAGE: 15.980V, TEMPERATURE: 49.93C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.838] (0) RPM: 15173, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 48.44C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.838] (1) RPM: 798, PWR: 60, VOLTAGE: 15.992V, TEMPERATURE: 46.36C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.838] (2) RPM: 15223, PWR: 60, VOLTAGE: 15.970V, TEMPERATURE: 48.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.838] (3) RPM: 15252, PWR: 60, VOLTAGE: 15.979V, TEMPERATURE: 49.96C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.980V, BOARD_CURRENT: 1.104A
      [3.854] (0) RPM: 15159, PWR: 60, VOLTAGE: 15.991V, TEMPERATURE: 48.43C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.854] (1) RPM: 798, PWR: 60, VOLTAGE: 15.992V, TEMPERATURE: 46.36C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.854] (2) RPM: 15223, PWR: 60, VOLTAGE: 15.970V, TEMPERATURE: 48.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.854] (3) RPM: 15252, PWR: 60, VOLTAGE: 15.979V, TEMPERATURE: 49.96C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.876] (0) RPM: 15159, PWR: 60, VOLTAGE: 15.991V, TEMPERATURE: 48.43C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.876] (1) RPM: 816, PWR: 60, VOLTAGE: 15.990V, TEMPERATURE: 46.32C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.876] (2) RPM: 15223, PWR: 60, VOLTAGE: 15.970V, TEMPERATURE: 48.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.876] (3) RPM: 15252, PWR: 60, VOLTAGE: 15.979V, TEMPERATURE: 49.96C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.979V, BOARD_CURRENT: 1.144A
      [3.892] (0) RPM: 15171, PWR: 60, VOLTAGE: 15.982V, TEMPERATURE: 48.42C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.892] (1) RPM: 855, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 46.36C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.892] (2) RPM: 15269, PWR: 60, VOLTAGE: 15.965V, TEMPERATURE: 48.41C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.892] (3) RPM: 15252, PWR: 60, VOLTAGE: 15.981V, TEMPERATURE: 49.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.914] (0) RPM: 15171, PWR: 60, VOLTAGE: 15.982V, TEMPERATURE: 48.42C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.914] (1) RPM: 855, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 46.36C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.914] (2) RPM: 15261, PWR: 60, VOLTAGE: 15.973V, TEMPERATURE: 48.43C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.914] (3) RPM: 15252, PWR: 60, VOLTAGE: 15.981V, TEMPERATURE: 49.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.981V, BOARD_CURRENT: 1.144A
      [3.935] (0) RPM: 15170, PWR: 60, VOLTAGE: 15.987V, TEMPERATURE: 48.40C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.935] (1) RPM: 855, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 46.36C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.935] (2) RPM: 15261, PWR: 60, VOLTAGE: 15.973V, TEMPERATURE: 48.43C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.935] (3) RPM: 15244, PWR: 60, VOLTAGE: 15.976V, TEMPERATURE: 49.98C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.960] (0) RPM: 15170, PWR: 60, VOLTAGE: 15.987V, TEMPERATURE: 48.40C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.960] (1) RPM: 750, PWR: 60, VOLTAGE: 15.989V, TEMPERATURE: 46.32C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.960] (2) RPM: 15290, PWR: 60, VOLTAGE: 15.973V, TEMPERATURE: 48.41C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.960] (3) RPM: 15244, PWR: 60, VOLTAGE: 15.976V, TEMPERATURE: 49.98C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.976V, BOARD_CURRENT: 1.192A
      [3.976] (0) RPM: 15170, PWR: 60, VOLTAGE: 15.987V, TEMPERATURE: 48.40C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.976] (1) RPM: 750, PWR: 60, VOLTAGE: 15.989V, TEMPERATURE: 46.32C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.976] (2) RPM: 15290, PWR: 60, VOLTAGE: 15.973V, TEMPERATURE: 48.41C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.976] (3) RPM: 15245, PWR: 60, VOLTAGE: 15.974V, TEMPERATURE: 49.98C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.994] (0) RPM: 15169, PWR: 60, VOLTAGE: 15.986V, TEMPERATURE: 48.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.994] (1) RPM: 700, PWR: 60, VOLTAGE: 16.000V, TEMPERATURE: 46.28C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.994] (2) RPM: 15261, PWR: 60, VOLTAGE: 15.981V, TEMPERATURE: 48.48C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      [3.994] (3) RPM: 15245, PWR: 60, VOLTAGE: 15.974V, TEMPERATURE: 49.98C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.974V, BOARD_CURRENT: 1.248A
      Finished!
      [3.994172] TX=404, RX=501 packets, RX CRC ERRORS=0
      Average RPMs: 15155.23 1018.99 15249.99 15239.80
      Average RPM deviation between ESCs : 14231.00
      WARNING: In order to plot the results, install the Python "plotly" module: pip3 install plotly --upgrade
        Alex Kushleyev ModalAI Team @dan64
        Hello @dan64,
        The px4-esc-cal-tool does not apply to ModalAI uart-based ESCs. That tool was used for calibrating ESC response to PWM control signal for old-style ESCs.
        There is no need to re-calibrate the ModalAI ESC if you use a stock configuration, such as the motor + propeller that comes with Starling 2 MAX.
        The ESC parameters for this motor + propeller are located here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
        You could use voxl-esc tools to verify this. Since you already ran the spin test using voxl-esc tools, this should be somewhat familiar.
        ./voxl-esc-verify-params.py
        This should query all the params on your ESC and they should match the same param file (which is also stored in /usr/share/modalai/voxl-esc-params/ folder.
        From the test spin results, it does appear that a motor may be faulty. I am assuming this behavior happens every time you run the test. However, you can never know for sure that the motor is at fault - it could be an ESC issue. In such case, the best thing to do is to do a similar test with another motor attached to the ESC channel in question. The ESC with the correct params is tuned for this motor + propeller and has been thoroughly tested, so I do not recommend trying to fix this by modifying ESC parameters (this will most likely result in a wasted effort).
        You can purchase the Starling 2 Max replacement motor here : https://www.modalai.com/products/starling-2-max-replacement-parts?variant=49704826896688 . It looks like the image for the motor has the wrong kV (2850), but the actual motor kV will be 1500.
        The motor used on Starling 2 Max very similar to Tmotor 2203.5 1500kv, you could also replace it with this one without changing any parameters.
        Testing a replacement motor should be relatively easy if you cut the motor leads on the motor arm and not disassemble the drone to get access to the ESC. Remove the old motor and solder and heat shrink the connections for the new motor and repeat the spin test (in order to make sure that the spin direction of the new motor matches the old motor, you can mark the wires before cutting and solder the new motor in the same wire order). If you wanted to not cut the motor wires along the arm, then you would need to do some disassembly to gain access to the ESC solder pads. (instructions outlined here : https://forum.modalai.com/topic/4023/motor-replacement-instructions-starling-2-max).
        I am curious what the motor spinning actually looks / sounds like, so if you are able to record a short video of the motor spinning, starting from the spin-up (just the faulty ID), that could be helpful:
        ./voxl-esc-spin.py --id 1 --power 15
        N 1 Reply Last reply Reply Quote 1
        • N
          noda-wills @Alex Kushleyev
          Thanks for the advice! Sorry for the delay in following up. Dan and I are on the same team and I currently have the physical drone in my possession.
          I've attached a video of what the motor spinning actually looks and sounds like. The motor you see is actually a replacement, and the behavior is the same. It appears we may actually have an ESC issue or an issue at the connection point between the motor wires and ESC.
          The video shown is the result of running:
          voxl2:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-spin.py --id 1 --power 15
          Modal AI Starling 2 Max - Motor Spin Test Video
          When running the voxl-esc-verify-params.py script, the output shows that params are all matching:
          voxl2:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-verify-params.py
          [GCC 8.4.0]
          INFO: Params from ID 0 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          INFO: Params from ID 1 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          INFO: Params from ID 2 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          INFO: Params from ID 3 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
          INFO: Success! Params in all ESCs are valid and identical.
          Any thoughts on next steps here?
