    Intermittent crashing of voxl-camera-server during VOA testing
    • J
      jaredjohansen
      We have calibrated our stereo cameras per these instructions: https://docs.modalai.com/calibrate-cameras/#calibrate-stereo-cameras.
      We are using the dev version of the voxl-vision-px4 (that fixed a previous bug) and which also tightened the range of accurate obstacle detections from 0.2 -> 20 meters to 0.5 -> 8 meters. In our experience, detections within this range are still quite noisy (sometimes swinging 2-3 meters in tolerance), but they do serve as coarse-grained estimates. In our VOXL, we have enabled the voxl-camera-server and voxl-dfs-server. We confirm this is working by looking at the OBSTACLE_DISTANCE field in the MAVLink Inspector in QGC.
      In QGC -> Vehicle Setup -> Safety -> Collision Avoidance, we have enabled Obstacle Prevention. We have also set the MPC_COL_PREV_D distance to 6.0 meters. We have taken the drone outside, gotten GPS sync, turned on Position mode, and manually attempted to fly it into a large tree with dense foliage. As advertised, the VOA will kick in and prevent us from flying into the tree. (This is great!)
      During this testing, when we fly the drone towards the tree, we see a spike in the CPU usage of the voxl-dfs-server. (We are not surprised by this, but share it as a data point along with our belief that this service is operating as expected and uses more CPU to compute points as it approaches obstacles.)
      Sometimes, when we fly the drone towards the tree, the voxl-camera-server will crash. One time, we saw the voxl-dfs-server crash as well. The crash message from the voxl-camera-server contains an ESTOP message on a single camera stream, although the exact camera stream varies (e.g., hires, tracking, or stereo). When one of these services crash, QGC oscillates between Position Mode and Hold Mode. On our controller, we lose the ability to pitch and roll. We can yaw, ascend and descend, but nothing more. Without being able to fly in any direction, we eventually land.
      We suspect that when the voxl-camera-server crashes, the voxl-dfs-server is unable to get data and does not function. We do not know if this fact is communicated to QGC and is the mechanism that triggers the Hold mode.
      We believe this intermittent crashing is likely due to some bug (perhaps due in some part to the interaction between the voxl-camera-server and voxl-dfs-server in the midst of a VOA event). Please advise if this is likely the case and how we might handle this.
        Can you paste the log from journalctl -u voxl-camera-server here so that we can see exactly what it's saying. Camera server doesn't know or care about what its clients do with the data it provides, it only knows if someone is listening for each camera. These camera server crashes are almost always caused by hardware issues with regards to the camera cables, though it is unusual that the errors you're seeing are coming from different cameras each time. You can also run camera server manually with debug flags voxl-camera-server -d 0 to have it print additional outputs about every single thing that it does. If you can show me a log either from journalctl or a manually run camera server instance that'd be very helpful.
          Hi Jared,
          Quick follow up to our call earlier, I've published the latest version of camera server(0.7.5) to stable, this has the increased pipe sizes for the hires camera and will print out the available resolutions for each camera when run with voxl-camera-server -d 1 (or -d 0, though this will be VERY verbose and will start printing each new exposure/gain).
          J Daniel RyuD 2 Replies Last reply Reply Quote 0
          • J
            jaredjohansen @Guest
            Awesome, thank you, @Alex-Gardner. We will try this when we are back in the office and let you know what we find.
            • Daniel RyuD
              Daniel Ryu @Guest
              @Alex-Gardner The available resolutions do print out accordingly, about the same as the previous list you send us. Thanks!
              • J
                jaredjohansen
                Thanks for printing out those resolutions. Very helpful!
                yocto:~$ voxl-camera-server -d 1
                exising instance of voxl-camera-server found, attempting to stop it
                ------ voxl-camera-server INFO: Port J2
                ------ voxl-camera-server: Done configuring hires camera
                	 Port       : port_J2
                	 Enabled    : 1
                	 Type       : hires
                	 Api        : hal3
                	 P-W        : 640
                	 P-H        : 480
                	 P-Fmt      : nv21
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : isp
                ------ voxl-camera-server INFO: Port J3
                ------ voxl-camera-server: Done configuring stereo camera
                	 Port       : port_J3
                	 Enabled    : 1
                	 Type       : stereo
                	 Api        : hal3
                	 P-W        : 1280
                	 P-H        : 480
                	 P-Fmt      : nv21
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : modalai
                =================MODALAI Auto Exposure Settings==================
                gain_min:                        0
                gain_max:                        1000
                exposure_min_us:                 100
                exposure_max_us:                 33000
                desired_msv:                     58.000000
                k_p_ns:                          32000.000000
                k_i_ns:                          20.000000
                max_i:                           250.000000
                p_good_thresh:                   3
                exposure_period:                 1
                gain_period:                     2
                display_debug:                   no
                exposure_offset_for_gain_calc:   8000
                ------ voxl-camera-server INFO: Port J4
                ------ voxl-camera-server: Done configuring tracking camera
                	 Port       : port_J4
                	 Enabled    : 1
                	 Type       : tracking
                	 Api        : hal3
                	 P-W        : 640
                	 P-H        : 480
                	 P-Fmt      : raw8
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : modalai
                gain_min:                        0
                gain_max:                        1000
                k_i_ns:                          20.000000
                max_i:                           250.000000
                p_good_thresh:                   3
                exposure_period:                 1
                gain_period:                     2
                display_debug:                   no
                Writing new configuration to /etc/modalai/voxl-camera-server.conf
                Created pipe: hires_preview channel: 0
                Created pipe: stereo channel: 1
                Created pipe: tracking channel: 2
                Starting Camera: tracking
                SUCCESS: Camera module opened
                ----------- Number of cameras: 3
                ------ voxl-camera-server INFO: Client: qvio-server0 connected to channel: 2
                ------ voxl-camera-server ERROR: Client connected to invalid channel: 0
                ------ voxl-camera-server ERROR: Client connected to invalid channel: 1
                ----------- HiRes  camera id: 0
                ----------- Stereo camera id: 2
                ----------- Mono   camera id: 1
                ------ voxl-camera-server INFO: Client: voxl-streamer0 connected to channel: 2
                Available resolutions for camera: tracking:
                640 x 480
                320 x 240
                Resolution: 640 x 480 Found!
                ------ voxl-camera-server: Preview buffer allocations
                Internal Exposure for: tracking 2
                /builds/voxl-public/modal-pipe-architecture/voxl-camera-server/src/expgain_interface/expgain_interface_factory.cpp 45 Creating exposure interface
                Creating ModalAI exposure interface
                	 Port       : port_J4
                	 Enabled    : 1
                	 Type       : tracking
                	 Api        : hal3
                	 P-W        : 640
                	 P-H        : 480
                	 P-Fmt      : raw8
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : modalai
                gain_min:                        0
                gain_max:                        1000
                k_i_ns:                          20.000000
                max_i:                           250.000000
                p_good_thresh:                   3
                exposure_period:                 1
                gain_period:                     2
                display_debug:                   no
                Starting Camera: hires
                Available resolutions for camera: hires:
                4160 x 3120
                4056 x 3040
                4000 x 3000
                3040 x 3040
                3016 x 3016
                3840 x 2160
                3648 x 2736
                3264 x 2448
                3200 x 2400
                2976 x 2976
                3044 x 1720
                2704 x 2028
                2704 x 1520
                2592 x 1944
                2688 x 1512
                2028 x 1144
                2160 x 2160
                1920 x 2160
                1920 x 1920
                1880 x 1880
                2048 x 1536
                1920 x 1440
                1920 x 1080
                1600 x 1600
                1600 x 1200
                1520 x 1520
                1440 x 1080
                1080 x 1080
                1280 x 960
                1340 x 760
                1280 x 768
                1280 x 720
                1200 x 1200
                1280 x 640
                1280 x 480
                1040 x 780
                1024 x 768
                960 x 960
                720 x 720
                800 x 600
                960 x 720
                848 x 480
                858 x 480
                864 x 480
                800 x 480
                720 x 480
                640 x 480
                640 x 240
                640 x 360
                480 x 640
                480 x 480
                480 x 360
                480 x 320
                432 x 240
                352 x 288
                320 x 240
                	 Port       : port_J2
                	 Enabled    : 1
                	 Type       : hires
                	 Api        : hal3
                	 P-W        : 640
                	 P-H        : 480
                	 P-Fmt      : nv21
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : isp
                Starting Camera: stereo
                Available resolutions for camera: stereo:
                1280 x 480
                848 x 480
                858 x 480
                864 x 480
                800 x 480
                720 x 480
                640 x 480
                640 x 240
                640 x 360
                480 x 480
                480 x 360
                480 x 320
                432 x 240
                352 x 288
                320 x 240
                Resolution: 1280 x 480 Found!
                Internal Exposure for: stereo 1
                Received raw10 frame, checking to see if is actually raw8
                Frame was actually 8 bit, sending as is
                	 Port       : port_J3
                	 Enabled    : 1
                	 Type       : stereo
                	 Api        : hal3
                	 P-W        : 1280
                	 P-H        : 480
                	 P-Fmt      : nv21
                	 FPS        : 30
                	 OverrideId : -1
                	 AEAlgo     : modalai
                gain_min:                        0
                gain_max:                        1000
                k_i_ns:                          20.000000
                max_i:                           250.000000
                p_good_thresh:                   3
                exposure_period:                 1
                gain_period:                     2
                display_debug:                   no
