  2. VOXL Accessories
  3. Clarification on Livox Mid 360 LiDAR Compatibility with VOXL 2 on Starling 2 Max Outdoor Drone
Scheduled Pinned Locked Moved VOXL Accessories
8 Posts 4 Posters 5.0k Views 1 Watching
  • Thasindu WickramaT Offline
    Thasindu Wickrama
    Hello ModalAI Team,
    I am currently planning to work with the Starling 2 Max Outdoor Drone and looking into integrating a Livox Mid 360 LiDAR for mapping purposes. I would like to clarify the following:
    1. Does the VOXL 2 on the Starling 2 Max support the mounting and operation of the Livox Mid 360 LiDAR?
    2. If not natively supported, is there a recommended interface or adapter to establish compatibility?
    3. Is there a USB extension or specific cable available to connect the Livox Mid 360 to the VOXL 2, considering the power and data transmission requirements?
    I appreciate any guidance or documentation you can provide on this integration.
    Thank you!
    • Thasindu WickramaT Thasindu Wickrama
      Hello ModalAI Team,
      Thank you!
      Eric KatzfeyE Online
      @Thasindu-Wickrama We have no experience with this sensor.
      ModeratorM Thasindu WickramaT 2 Replies Last reply
        Starling 2 Max is built using VOXL 2, which is an open development platform. You can find details on VOXL 2 I/O here: https://docs.modalai.com/voxl2-connectors/
        Thasindu WickramaT 1 Reply Last reply
          Thasindu Wickrama
          @Eric-Katzfey have you tried any other lidar (2D or 3D one) with the voxl board?
          • ModeratorM Moderator
            Thasindu Wickrama
            @Moderator does the c29 variant includes the thermal camera? Its not clear as per the webpage information.
              @Thasindu-Wickrama No, we use TOF for depth in indoor environments. In outdoor environments we have used stereo cameras. And we have used single point lidar for distance (height) sensing. How did you want to integrate a LiDAR? Would it be a PX4 driver?
                Thasindu Wickrama
                @Eric-Katzfey we are planning to integrate it with ros. Physical connection through the extension board ethernet port.
                Raza RizviR 1 Reply Last reply
                  Raza RizviR Offline
                  Raza RizviR Offline
                  Raza Rizvi
                  @Thasindu-Wickrama Hey man, I am planning to do the same on a VOXL2 powered custom build drone.
                  Did you have any success?
