  3. IMX412 Colour
IMX412 Colour
10 Posts 3 Posters 1.2k Views 2 Watching
  • J Offline
    J Offline
    jcai
    Hi, I have a single IMX412 connected to M0173 J5 on a VOXL2.
    com.qti.sensormodule.imx412_fpv_2.bin is the only sensormodule file I have in /usr/lib/camera.
    This is my camera server config file:
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *    - `preview` stream for raw unprocessed images from CV cameras
     *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
    	"version":	0.1,
    	"fsync_en":	true,
    	"fsync_gpio":	109,
    	"cameras":	[{
    			"type":	"imx412",
    			"name":	"hires_front",
    			"enabled":	true,
    			"camera_id":	0,
    			"fps":	30,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"en_raw_preview":	false,
    			"en_small_video":	true,
    			"small_video_width":	640,
    			"small_video_height":	480,
    			"small_venc_mode":	"h265",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"en_large_video":	false,
    			"large_video_width":	4056,
    			"large_video_height":	3040,
    			"large_venc_mode":	"h265",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	38,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	30,
    			"en_snapshot":	false,
    			"en_snapshot_width":	4056,
    			"en_snapshot_height":	3040,
    			"exif_focal_length":	3.0999999046325684,
    			"exif_focal_length_in_35mm_format":	17,
    			"exif_fnumber":	1.2400000095367432,
    			"ae_mode":	"isp"
    The issue I'm having has to do with the colour of the video. Indoors, the image looks fine but outdoors, there's a red tint that I can't seem to get rid of. I'm using isp currently, but I've also played around with lme_msv, to not much improvement. Is this behaviour normal?
    • J jcai
      	"version":	0.1,
      	"fsync_en":	true,
      	"fsync_gpio":	109,
      	"cameras":	[{
      			"type":	"imx412",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	30,
      			"ae_mode":	"isp"
      @jcai , can you please try the following:
      remove com.qti.sensormodule.imx412_fpv_2.bin (or rename to com.qti.sensormodule.imx412_fpv_2.bin.bak and copy the following to /usr/lib/camera:
      cp /usr/share/modalai/chi-cdk/imx412/com.qti.sensormodule.imx412_2.bin /usr/lib/camera/
      then restart camera server.
      This other sensormodule driver will use another tuning file for image processing. Let me know if that works better for you, I can explain more details about what's going on.
        Another thing to check.. does your IMX412 camera have IR filter installed or not? You should know this based on the part number of IMX412 that you purchased.
        If there is no IR filter, it is possible that you will see more red tint in the image. If this is the case, we can discuss how to fix it.
        J 1 Reply Last reply
          J Offline
          J Offline
          jcai
          @Alex-Kushleyev I've tried the other driver, and the result looks largely the same. It's a bit brighter. (Cropped for file size)
          My sensor indeed doesn't have the IR filter.
          • J jcai
            @jcai , thank you for trying.
            The issue here is that the tuning files we have for the Qualcomm ISP assume that the camera has a IR filter, so the AWB (auto white balance) algorithm in the camera pipeline is not able to compensate the significant difference in RGB levels with the IR filter removed.
            The tuning file is pretty much a black box for the end user, deviating from the original camera parameters / lens specs (which were used for the tuning) can leave to image degradation or color variations.
            We have been working on our own processing pipeline (MISP) which bypasses the ISP and performs debayering, color balance, etc. I will need to document a few steps so that you can try it out.
            Does your use case require the full frame resolution, or what output resolution are you looking for?
              J Offline
              J Offline
              jcai
              @Alex-Kushleyev Thanks for the info. For now, we're going to swap the sensor for one with the filter to see how it performs. I'll be updating results here
              • J jcai
                J Offline
                J Offline
                jcai
                Update: the filter was absolutely the difference maker
                • D Offline
                  D Offline
                  dirizarry
                  @Alex-Kushleyev - Did the MISP pipeline get published yet? We have the same issue with the IR filter compensations and tried to run the binary switch that you noted above. After restarting the voxl-camera-server it stated that it could no longer find the cameras so I switched back to the old imx412_0.bin that was already there.
                  • D dirizarry
                    #9
                    @dirizarry ,
                    If your lens does not have an IR filter, the colors will be distorted. Please take a look at sample images : https://docs.modalai.com/M0161/#image-samples-for-sensor
                    You could replace the lens with another lens that has an IR filter.
                    If you do want to keep the lens without IR filter, please follow the steps below.
                    My best suggestion is to download the latest IMX412 drivers from here
                    Extract the archive and select the sensormodule with the correct id (matching the ID that you have already been using). back up existing imx412 sensormodules and copy the new one to /usr/lib/camera/
                    Then, edit /etc/modalai/voxl-camera-server.conf - i will just provide a minimal config for a single IMX412 camera (you will need to check the camera id in the config file). If you use voxl-portal, you should be able to see hires_misp_color and h264 encoded stream hires_misp_encoded.
                        "version":  0.1,
                        "fsync_en": true,
                        "fsync_gpio":   109,
                        "cameras":  [
                            "type":             "imx412",
                            "name":             "hires",
                            "enabled":          true,
                            "camera_id":        0,
                            "fps":              30,
                            "en_preview":       true,
                            "en_raw_preview":   true,
                            "en_misp":          true,
                            "preview_width":    3840,
                            "preview_height":   2160,
                            "misp_width":       1920,
                            "misp_height":      1080,
                            "misp_zoom":        1,
                            "misp_gamma":       1,
                            "misp_awb":         "auto",
                            "ae_mode":          "lme_msv",
                            "gain_min":         100,
                            "gain_max":         32000,
                            "ae_desired_msv":   100,
                            "misp_venc_enable": true,
                            "misp_venc_mode":   "h264",
                            "misp_venc_br_ctrl":"cbr",
                            "misp_venc_mbps":   5,
                            "en_small_video":   false,
                    Please note that after you start voxl-camera-server, the config file will be auto-populated with some more default parameters for this camera.
                    When viewing hires_misp_color stream in voxl-portal, if you see any flickering, please try to set voxl2 cpu mode to perf : voxl-set-cpu-mode perf as well as reduce the jpeg quality that is used to display this stream (which is YUV converted to jpeg in the back-end). The mjpeg quality can be changed by enabling the advanced controls in voxl-portal (click the tiny check box in the bottom left corner of the page) and reduce the Quality slider.
                    Using MISP should help with reducing the IR effects, but it won't be perfect due to really strong IR light that can be present durig day time outdoors.
                      @dirizarry ,
                          "version":  0.1,
                          "fsync_en": true,
                          "fsync_gpio":   109,
                          "cameras":  [
                              "type":             "imx412",
                              "name":             "hires",
                              "enabled":          true,
                              "camera_id":        0,
                              "fps":              30,
                              "en_preview":       true,
                              "en_misp":          true,
                              "misp_width":       1920,
                              "misp_zoom":        1,
                              "misp_gamma":       1,
                              "misp_awb":         "auto",
                              "gain_min":         100,
                              "gain_max":         32000,
                      Also, a quick note.. regarding what preview resolution to use with IMX412 camera with MISP enabled..
                      For best quality (non-EIS applications, where the output is 16:9 aspect ratio, such as 3840x2160, 1920x1080, 1280x720), you should select 3840x2160 as the preview resolution. For EIS applications, the full frame 4040x3040 resolution should be used because it will allow more stabilization margin. selecting 3840x2160 will tell the camera to crop this region from the full frame 4040x3040, since we don't need the rest of the image.
                      For low latency applications, you can use input resolution of 1936x1080. Note that this is slightly non-standard (as opposed to 1920x1080 because the 1936x1080 resolution allows faster processing. So you could have input resolution of 1936x1080 and output resolution of 1920x1080, 1280x720, etc.
