  3. Frame size mismatch: got 43200 bytes from pipe, expected 38528
3 Posts 2 Posters 912 Views 1 Watching
  • 黄充黄 Offline
    黄充黄 Offline
    黄充
    Hi, I want to record tof_depth/hires_large_color data simultaneously without using ROS.
    When I try to record tof_depth data in this way::
    First, I launch voxl-stream for tof_depth:
    voxl-camera-server
    voxl-streamer -i tof_depth -p 8901
    Then I use ffmpeg to write the stream
    ffmpeg -i rtsp://192.168.1.16:8901/live \
           -f rawvideo -pix_fmt gray \
           -s 224x172 -r 10 \
           output.raw
    I run into error in two terminals:
    $ voxl-streamer -i tof_depth -p 8901
    Waiting for pipe tof_depth to appear
    Found Pipe
    detected following stats from pipe:
    w: 224 h: 172 fps: 10 format: RAW8
    Stream available at rtsp://127.0.0.1:8901/live
    A new client rtsp://192.168.1.2:55293(null) has connected, total clients: 1
    Camera server Connected
    ERROR:   Frame size mismatch: got 43200 bytes from pipe, expected 38528
    ERROR:   Most Likely the publisher of the camera data made a mistake
    ERROR:   Shutting down voxl-streamer
    Trying to quit g main loop due to program shutdown
    cleaning up gstreamer
    Exited Cleanly
    [in#0 @ 0x6000014d0000] Error opening input: Invalid data found when processing input
    Error opening input file rtsp://192.168.1.16:8901/live.
    Error opening input files: Invalid data found when processing input
    Any idea? Is there a better way to record tof_depth/hires_large_color stream simultaneously? Thank you!
    • 黄充黄 黄充
      voxl-camera-server
             -s 224x172 -r 10 \
             output.raw
      Found Pipe
      Exited Cleanly
      @黄充 , I think you found a small bug. We have two versions of TOF sensors:
      • TOF V1 (which is EOL) with resolution 224x172 = 38528
      • TOF V2 (which is what you probably have) with resolution 240x180 = 43200
      As you can see in the source code, the json metadata for the pipe is initialized with w=224 and h=172, and it is never updated for the new TOF sensor.
      Link Preview Image
      src/hal3_camera_mgr.cpp · dev · voxl / VOXL SDK / Services / voxl-camera-server · GitLab
      GitLab.com
      favicon
      GitLab (gitlab.com)
      voxl-streamer reads the information from pipe metadata and thinks the image size will be 224x172 and when receives the actual data, detects a mismatch.
      If you are able to re-build the camera server with changing the resolution in UpdatePipeJson, i think this will work for you. We will fix this as well.
      Thank you
        Link Preview Image
        GitLab.com
        favicon
        GitLab (gitlab.com)
        Thank you
        I just made a fix on a branch, but did not test it:
        Link Preview Image
        use correct dimensions of tof v2 frame in pipe json (43aa51a4) · Commits · voxl / VOXL SDK / Services / voxl-camera-server · GitLab
        GitLab.com
        favicon
        GitLab (gitlab.com)
        If you are able to test the fix, please give it a try and let me know if it works!
