    Building Tensorflow Lite From Source w/ NNAPI
    Qualcomm Flight RB5 5G Drone
    android nnapi snpe tensorflow
    • M
      mrawding
      I am attempting to build Tensorflow Lite v2.6 on the RB5 with NNAPI enabled. After following the tensorflow tutorial I am unable to build with NNAPI enabled even with the correct CMAKE Flags to enable the build.
      The problem is a missing pre-processor definition of __ANDROID__=1.
      After defining that, it seemed to cause some issues because of missing andoir includes such as.
      sys/system_properties.h (copied cutils/sys/system_properties to resolve.
      and
      android/api-level.h
      On the Qualcomm Website here:
      https://developer.qualcomm.com/qualcomm-qcs610-development-kit/learning-resources/neural-network-api
      It says I should be able to use NNAPI. I understand that the gstreamer plugin is an option, but I would like to interface tensorflow lite directly. Is there an SDK that will help me build this? I've looked through most of them and they don't seem to have the files that I would need most likely.
      Has anyone made any progress with this or could point me in a good direction.
      • modaltbM
        modaltb ModalAI Team
        Hi @mrawding ,
        What hardware are you using???? 😉
        We are very light with RB5 Flight docs at this point, I have headers from our system image build that I can try to share if that would help, but we've not gone too far yet in this area.
        We have our system image in an emulator as well, but still pretty alpha level: https://gitlab.com/voxl-public/rb5-flight/rb5-flight-emulator
        • M
          mrawding
          Hi Travis,
          I am using the EVT board at the moment. The problem is that is seems to be missing the Android NDK on board. We need these toolchain libraries onboard to compile tensorflowlite with NNAPI and hexagon acceleration delegates. The only thing that might work as of now is gpu delegation, but I haven't tested it at runtime just yet.
          How was this done on the voxl? I tried downloading the hexagon sdk, but I am unsure how to compile and install the ndk on the RB5.
            Hey @mrawding,
            For tesorflowlite on VOXL we currently use the voxl-tflite-server which uses the GPU delegate. This is a custom tflite build we made.
            • S
              snogar @Guest
              @modalab Just bumping this thread. It would be very helpful to build NNAPI on both the voxl and RB5 as this would enable the ability to run both PyTorch and Tensorflow Lite, greatly enhancing the ease of running machine learning models on the platform. From what I can gather, NNAPI is needed to utilize the neural processor on the RB5.
              • modaltbM
                Hi @snogar ,
                Roger! The hood is open right now, we'll be digging in here in the next week(s) and will update you.
                • S
                  snogar @modaltb
                  @modaltb Excellent! Happy to help if you need it. Don't hesitate to reach out to myself or @mrawding
