Power Module
I'm in need of a .step file for VOXL2 mini "Power Module". Is there a difference between the VOXL ESC MINI (w/Built in Power Module) vs just the VOXL2 mini and Power Module?
Not finding "Power Module" in the PCB catalog. -
Not finding "Power Module" in the PCB catalog.Hi @FIREBIRD
Our standard power module is the same for VOXL 2 and VOXL 2 Mini. We just change the voltage settings.
Here is the link and the best we have is a PCB step file for this design (board only, no cables):
https://docs.modalai.com/power-module-v3-datasheet/
Hope this helps!
Thanks! -
V Vinny referenced this topic on
Hi @FIREBIRD
Hope this helps!
Thanks!You might also want to double check the current rating of the power module versus the full load from your setup. A lot of weird reboot or brownout issues end up being power related, especially once extra peripherals get added. Keeping the wiring short and using a stable regulator helps too.
V Vinny has marked this topic as solved on
