Can' connect between FrSKY D4R-II and flight core m500
I have been try to connect another reciever from FrSky to Flight Core of Voxl m500 but it seem didn't work rigtht . My reciever had been binded with transmiter but when I run QGroundControl and use transmiter to control , QGC didn't have any signal .
Hi @mr-TOKI ,
First off, nice name! Second, thanks for the pics.
We've tried with the X8R model using the following setup. It required 5VDC, and the RC input port is 3.3VDC, so we had to pull 5VDC off a different port as shown here:
https://docs.modalai.com/flight-core-connections/#rc-receiver
Hi @mr-TOKI ,
Hi @mr-TOKI ,
@modaltb said in Can' connect between FrSKY D4R-II and flight core m500:
X8R
I wired as picture and followed the doc as you send. But I still can't use my transmiter to control it eventhough led from RC was green. I still can't find the problem . Please help me
Can you connect the Flight Core to QGroundControl using USB, and then go to the MAVLink console? You can run
rc_input statusfrom there and check if you see anything:
