    Depth Information Source Unclear
    Starling & Starling 2
    starling2 max voa depth sensor dfs
    • G
      griffin
      Following the 0.9 VOA tutorial we cannot start up the voxl-dfs-server via systemctl enable or start, it shows enabled but does not run even after restarting the drone.
      • Checking in the VOXL portal the VOA point cloud shows that some kind of depth information is being gathered.
      • Does DFS occur through some process other than the dfs-server in the 1.0+ version of the SDK? Or does the depth information originate from the TOF sensor?
      • The config file from the VOA tutorial is missing / has been renamed to voxl-vision-hub.conf, there is a voxl-vision-hub process running; is this where depth information is produced in newer SDK versions?
      Additionally:
      • The tof_pc and tof views in VOXL portal seems to be rotated s.t. z is forward, y is left and x is down which does not match the NED/FRD frames of the other views. Is this correct?
      • The VOXL mapper does not populate on the portal (blank scene) and the mapper service does not appear for voxl-inspect-services.
      What is the source of depth information on a Starling 2 Max drone with the TOF module?
      Any help is appreciated.
      • James StrawsonJ
        James Strawson ModalAI Team
        Hi Griffin,
        DFS stands for depth-from-stereo and is only used on the M500 and Sentinel platforms that have stereo cameras.
        Starlings use the PMD TOF camera which outputs 3D point points directly from voxl-camera-server. That data is in the reference frame of the camera such that Z points out the lens, X to the right of the image, and Y pointing downwards.
        voxl-vision-hub then consumes that data and rotates it based on the mounting location described in /etc/modalai/extrinsics.conf and the current position/orientation of the drone as reported by VIO.
        voxl-mapper is not installed by default as it's not part of the core SDK, however it is locally available and can be installed with apt install voxl-mapper without needing an internet connection.
        Best,
        James
        G 1 Reply Last reply Reply Quote 1
        • G
          griffin @James Strawson
          @James-Strawson
          Hey James,
          Thanks for the tip, installing via apt install voxl-mapper and then running with systemctl start voxl-mapper worked out of the box.
          Kind regards,
          Griffin
