  3. docker pull returns 410 Gone
3 Posts 3 Posters 2.2k Views 1 Watching
  • W Offline
    W Offline
    wouter
    Trying to use the ubuntu image on the VOXL results in error for me:
    voxl:~$ docker run arm64v8/ubuntu:22.04 echo 1
    Unable to find image 'arm64v8/ubuntu:22.04' locally
    Pulling repository docker.io/arm64v8/ubuntu
    Error: Status 410 trying to pull repository arm64v8/ubuntu: "<html>\r\n<head><title>410 Gone</title></head>\r\n<body>\r\n<center><h1>410 Gone</h1></center>\r\n<hr><center>openresty</center>\r\n</body>\r\n</html>\r\n"
    Looking at the documentation, the helloworld image is used (https://docs.modalai.com/docker-on-voxl/#running-a-docker-image).
    Pulling this image on the VOXL (docker pull helloworld) results in the same error
    Error: Status 410 trying to pull repository library/helloworld: "<html>\r\n<head><title>410 Gone</title></head>\r\n<body>\r\n<center><h1>410 Gone</h1></center>\r\n<hr><center>openresty</center>\r\n</body>\r\n</html>\r\n"
    It seems that an old version of docker is the cause. Is it possible to upgrade docker?
    • Sarah McMahonS Offline
      Sarah McMahon
      Did you find a solution I have just run into the same error?
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        Hi @wouter the reason this is happening is recently docker depricated their api v1 version and are only using v2 api calls now. Meaning the original voxl is not able to pull down pre made docker images. The solution around this is to build the docker image on a parent computer, tar it up via docker save, then push that to the voxl and run a docker load -i on the tar file.
        You can follow similar to what we do in voxl-docker-mavsdk:
        https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk/-/blob/main/Dockerfile?ref_type=heads
