    VOXL2 Mini / AR0144 J7 Group 1 / voxl-fsync-mod
    VOXL 2 Mini
    • Kerry SnyderK
      Kerry Snyder
      I have been able to successfully compile and run voxl-fsync-mod on the VOXL2 Mini to generate trigger pulses on GPO 41 (on connector J10) for an external USB camera. Next, I would like to trigger our AR0144 (MSU-M0149-1) module, which is connected to J7 Group 1 (sensor3) through MDK-M0076-1-00. If I'm parsing this page correctly, I will want to trigger on pin 114. I think I will also need 'com.qti.sensormodule.ar0144_fsin_3.bin' from Modal to enable sync input for the image sensor.
      Is this understanding correct? And would I be able to get that 'bin' file to support this configuration?
      Other minor related questions:
      1. Is VOXL2 Mini 1.7.X still due to be released soon (so that we can have voxl-fsync-mod built in)?
      2. If we want to trigger multiple cameras on different GPIO, is our best bet to modify voxl-fsync-mod to toggle multiple pins within fsync_hrtimer_tick_cb?
      • modaltbM
        modaltb ModalAI Team
        Hi @Kerry-Snyder , nice work tracking all of this down! Impressive.
        Agree, GPIO114 is the pin that routes from M0104 (voxl2-mini) J7 pin pin 16 through M0076 interposer, which connects to M0149 AR0144 pin 26 (via M0076 stuffing resistor R3). I can physically test this when back in the office Monday on latest system image 1.3.0 as well, always like to verify on something I haven't tried yet! If this all works nicely I'll get a public doc in place too to help others.
        The camera HW IDs are 0-based, so I think you should be able to use the shipping /usr/share/modalai/chi-cdk/ar0144-fsin/com.qti.sensormodule.ar0144_fsin_2.bin, e.g.:
        J6-lower = HW ID 0
        J6-upper = HW ID 1
        J7-lower = HW ID 2
        #1]
        voxl2-mini has SDK 1.3.0 support, it shows up down in the list and I need to do some SQL stuff to change the order here which I've put off so look to the bottom:
        Then find:
        VOXL2 Mini SDK 1.3.0 voxl2-mini_SDK_1.3.0.tar.gz 6/3/2024, 5:23:14 PM
        (see this link https://developer.modalai.com/asset/10 )
        #2]
        That seems about right and what I would try first for sure, we haven't done this yet but it should be doable in that location. Holler back if you have any questions!
        • Kerry SnyderK
          Kerry Snyder
          Thanks! I was able to grab and flash SDK 1.3.0 yesterday and it's been working well.
          com.qti.sensormodule.ar0144_fsin_2.bin does seem to work - I'm able to configure gpio_num to 114 and control the ar0144 rate with voxl_fsync_mod.
          The max frame rate I saw indoors was 43.5hz with sampling_period_ns set to 23000000, and outdoors was 52.6hz with sampling_period_ns set to 19000000. I suspect this is somehow related to exposure time (or an exposure cap) although I see a solid 60hz indoors and outdoors when I manually configure the frame rate. For reference, this is all measured with gstreamer qtiqmmfsrc into OpenCV and then ROS2, which could definitely impact performance and exposure control.
          I'll try out a multi-gpio kernel module modification! Thanks again!
          • Kerry SnyderK
            Kerry Snyder
            I can confirm that multi-camera triggering works with a very minor patch:
            diff --git a/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c b/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
            index 837dd21..730e374 100644
            --- a/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
            +++ b/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
            @@ -24,7 +24,10 @@
              * /sys/module/voxl_fsync_mod/parameters/pulse_width_us
              *  - uint - the length of pulse to use in microseconds, default 10, 10us
            - * /sys/module/voxl_fsync_mod/parameters/gpio_num
            + * /sys/module/voxl_fsync_mod/parameters/gpio1_num
            + *  - uint - the GPIO number to use
            + * /sys/module/voxl_fsync_mod/parameters/gpio2_num
             #define GPIO_OFFSET 1100
            @@ -38,8 +41,10 @@ static uint pulse_width_us = 10; //
             module_param(pulse_width_us, uint, 0644);
             /* GPIO number */
            -static uint gpio_num = 109;
            -module_param(gpio_num, uint, 0644);
            +static uint gpio1_num = 41;
            +module_param(gpio1_num, uint, 0644);
            +static uint gpio2_num = 114;
            +module_param(gpio2_num, uint, 0644);
             /* enable/disable the GPIO output and timestamps */
             static int enabled = 0;
            @@ -143,8 +148,10 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
             	/* initialize on being enabled */
             	if (!initialized && enabled) {
            -		gpio_direction_output((gpio_num + GPIO_OFFSET), 0);
            -		gpio_export((gpio_num + GPIO_OFFSET), true);
            +		gpio_direction_output((gpio1_num + GPIO_OFFSET), 0);
            +		gpio_export((gpio1_num + GPIO_OFFSET), true);
            +		gpio_direction_output((gpio2_num + GPIO_OFFSET), 0);
            +		gpio_export((gpio2_num + GPIO_OFFSET), true);
             		initialized = true;
             		pr_info("voxl-fsync: initialized\n");
            @@ -153,7 +160,8 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
             	hrtimer_forward_now(&fsync_hrtimer, ns_to_ktime(sampling_period_ns));
             	if (enabled) {
            -		gpio_set_value((gpio_num + GPIO_OFFSET), 1);
            +		gpio_set_value((gpio1_num + GPIO_OFFSET), 1);
            +		gpio_set_value((gpio2_num + GPIO_OFFSET), 1);
             		/* TIMESTAMP TIMESTAMP TIMESTAMP*/
             		mutex_lock(&fysnc_mutex);
            @@ -163,7 +171,8 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
             		if(pulse_width_us > 0)
             			udelay(pulse_width_us);
            -		gpio_set_value((gpio_num + GPIO_OFFSET), 0);
            +		gpio_set_value((gpio1_num + GPIO_OFFSET), 0);
            +		gpio_set_value((gpio2_num + GPIO_OFFSET), 0);
             		/* signal clients */
             		fsync_update_pending = 1;
