<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 Mini / AR0144 J7 Group 1 / voxl-fsync-mod]]></title><description><![CDATA[<p dir="auto">I have been able to successfully compile and run voxl-fsync-mod on the VOXL2 Mini to generate trigger pulses on GPO 41 (on connector J10) for an external USB camera. Next, I would like to trigger our AR0144 (MSU-M0149-1) module, which is connected to J7 Group 1 (sensor3) through MDK-M0076-1-00. If I'm parsing <a href="https://docs.modalai.com/voxl2-mini-connectors/#j7-pin-out" rel="nofollow ugc">this page</a> correctly, I will want to trigger on pin 114. I think I will also need 'com.qti.sensormodule.ar0144_fsin_3.bin' from Modal to enable sync input for the image sensor.</p>
<p dir="auto">Is this understanding correct? And would I be able to get that 'bin' file to support this configuration?</p>
<p dir="auto">Other minor related questions:</p>
<ol>
<li>Is VOXL2 Mini 1.7.X still due to be released soon (so that we can have voxl-fsync-mod built in)?</li>
<li>If we want to trigger multiple cameras on different GPIO, is our best bet to modify voxl-fsync-mod to toggle multiple pins within fsync_hrtimer_tick_cb?</li>
</ol>
]]></description><link>https://forum.modalai.com/topic/3478/voxl2-mini-ar0144-j7-group-1-voxl-fsync-mod</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 21:13:36 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3478.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 May 2024 20:28:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2 Mini / AR0144 J7 Group 1 / voxl-fsync-mod on Mon, 10 Jun 2024 22:01:54 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm that multi-camera triggering works with a very minor patch:</p>
<pre><code>diff --git a/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c b/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
index 837dd21..730e374 100644
--- a/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
+++ b/recipes-kernel/voxl-fysnc-mod/files/voxl-fsync-mod.c
@@ -24,7 +24,10 @@
  * /sys/module/voxl_fsync_mod/parameters/pulse_width_us
  *  - uint - the length of pulse to use in microseconds, default 10, 10us
- * /sys/module/voxl_fsync_mod/parameters/gpio_num
+ * /sys/module/voxl_fsync_mod/parameters/gpio1_num
+ *  - uint - the GPIO number to use
+ * /sys/module/voxl_fsync_mod/parameters/gpio2_num
 #define GPIO_OFFSET 1100
@@ -38,8 +41,10 @@ static uint pulse_width_us = 10; //
 module_param(pulse_width_us, uint, 0644);
 /* GPIO number */
-static uint gpio_num = 109;
-module_param(gpio_num, uint, 0644);
+static uint gpio1_num = 41;
+module_param(gpio1_num, uint, 0644);
+static uint gpio2_num = 114;
+module_param(gpio2_num, uint, 0644);
 /* enable/disable the GPIO output and timestamps */
 static int enabled = 0;
@@ -143,8 +148,10 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
 	/* initialize on being enabled */
 	if (!initialized &amp;&amp; enabled) {
-		gpio_direction_output((gpio_num + GPIO_OFFSET), 0);
-		gpio_export((gpio_num + GPIO_OFFSET), true);
+		gpio_direction_output((gpio1_num + GPIO_OFFSET), 0);
+		gpio_export((gpio1_num + GPIO_OFFSET), true);
+		gpio_direction_output((gpio2_num + GPIO_OFFSET), 0);
+		gpio_export((gpio2_num + GPIO_OFFSET), true);
 		initialized = true;
 		pr_info("voxl-fsync: initialized\n");
@@ -153,7 +160,8 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
 	hrtimer_forward_now(&amp;fsync_hrtimer, ns_to_ktime(sampling_period_ns));
 	if (enabled) {
-		gpio_set_value((gpio_num + GPIO_OFFSET), 1);
+		gpio_set_value((gpio1_num + GPIO_OFFSET), 1);
+		gpio_set_value((gpio2_num + GPIO_OFFSET), 1);
 		/* TIMESTAMP TIMESTAMP TIMESTAMP*/
 		mutex_lock(&amp;fysnc_mutex);
@@ -163,7 +171,8 @@ static enum hrtimer_restart fsync_hrtimer_tick_cb(struct hrtimer *timer)
 		if(pulse_width_us &gt; 0)
 			udelay(pulse_width_us);
-		gpio_set_value((gpio_num + GPIO_OFFSET), 0);
+		gpio_set_value((gpio1_num + GPIO_OFFSET), 0);
+		gpio_set_value((gpio2_num + GPIO_OFFSET), 0);
 		/* signal clients */
 		fsync_update_pending = 1;
]]></description><link>https://forum.modalai.com/post/17612</link><guid isPermaLink="true">https://forum.modalai.com/post/17612</guid><dc:creator><![CDATA[Kerry Snyder]]></dc:creator><pubDate>Mon, 10 Jun 2024 22:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 Mini / AR0144 J7 Group 1 / voxl-fsync-mod on Fri, 07 Jun 2024 22:38:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! I was able to grab and flash SDK 1.3.0 yesterday and it's been working well.</p>
<p dir="auto">com.qti.sensormodule.ar0144_fsin_2.bin does seem to work - I'm able to configure gpio_num to 114 and control the ar0144 rate with voxl_fsync_mod.</p>
<p dir="auto">The max frame rate I saw indoors was 43.5hz with sampling_period_ns set to 23000000, and outdoors was 52.6hz with sampling_period_ns set to 19000000. I suspect this is somehow related to exposure time (or an exposure cap) although I see a solid 60hz indoors and outdoors when I manually configure the frame rate. For reference, this is all measured with gstreamer qtiqmmfsrc into OpenCV and then ROS2, which could definitely impact performance and exposure control.</p>
<p dir="auto">I'll try out a multi-gpio kernel module modification! Thanks again!</p>
]]></description><link>https://forum.modalai.com/post/17566</link><guid isPermaLink="true">https://forum.modalai.com/post/17566</guid><dc:creator><![CDATA[Kerry Snyder]]></dc:creator><pubDate>Fri, 07 Jun 2024 22:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 Mini / AR0144 J7 Group 1 / voxl-fsync-mod on Fri, 07 Jun 2024 21:20:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kerry-snyder" aria-label="Profile: Kerry-Snyder">@<bdi>Kerry-Snyder</bdi></a> , nice work tracking all of this down!  Impressive.</p>
<p dir="auto">Agree, GPIO114 is the pin that routes from M0104 (voxl2-mini) J7 pin pin 16 through M0076 interposer, which connects to M0149 AR0144 pin 26 (via M0076 stuffing resistor R3).  I can physically test this when back in the office Monday on latest system image 1.3.0 as well, always like to verify on something I haven't tried yet!  If this all works nicely I'll get a public doc in place too to help others.</p>
<p dir="auto">The camera HW IDs are 0-based, so I think you should be able to use the shipping <code>/usr/share/modalai/chi-cdk/ar0144-fsin/com.qti.sensormodule.ar0144_fsin_2.bin</code>, e.g.:<br />
J6-lower  = HW ID 0<br />
J6-upper = HW ID 1<br />
J7-lower  = HW ID 2</p>
<hr />
<p dir="auto">#1]</p>
<p dir="auto">voxl2-mini has SDK 1.3.0 support, it shows up down in the list and I need to do some SQL stuff to change the order here which I've put off so look to the bottom:<br />
<img src="/assets/uploads/files/1717795013123-58700bbd-95b8-4c61-ba33-dca012ae7961-image.png" alt="58700bbd-95b8-4c61-ba33-dca012ae7961-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then find:<br />
VOXL2 Mini SDK 1.3.0	voxl2-mini_SDK_1.3.0.tar.gz	6/3/2024, 5:23:14 PM</p>
<p dir="auto">(see this link <a href="https://developer.modalai.com/asset/10" rel="nofollow ugc">https://developer.modalai.com/asset/10</a> )</p>
<p dir="auto">#2]</p>
<p dir="auto">That seems about right and what I would try first for sure, we haven't done this yet but it should be doable in that location.  Holler back if you have any questions!</p>
]]></description><link>https://forum.modalai.com/post/17563</link><guid isPermaLink="true">https://forum.modalai.com/post/17563</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Fri, 07 Jun 2024 21:20:28 GMT</pubDate></item></channel></rss>
