  2. VOXL SDK and Software
  3. MAVRS: offboard mode issues, ./run_mavros_test.sh
ros
2 Posts 2 Posters 702 Views
  • D Offline
    D Offline
    Denver Bennett
    I hope you are well. I am following the How to Run MAVROS tutorial. So far, I've been able to follow the entire tutorial without issues. I'm working on launching the simple-example demo by running the command ./run_mavros_test.sh.
    I'm currently running this command on a VOXL2, but it is not mounted on any drone. The VOXL2 only has some image sensors attached, but that's it. When I run the command ./run_mavros_test.sh, it runs, but then terminal stops printing at [ INFO] [1716998627.576438699]: waiting for offboard mode.
    What is the issue with offboard mode?
    Earlier, terminal printed some lines which read as follows:
    [ WARN] [1716998622.782124555]: Could not retrive negate_measured_roll parameter value, using default (0)
    [ WARN] [1716998622.782390009]: Could not retrive negate_measured_pitch parameter value, using default (0)
    [ WARN] [1716998622.784349536]: Could not retrive negate_measured_yaw parameter value, using default (0)
    [ WARN] [1716998622.786280367]: Could not retrive debounce_s parameter value, using default (4.000000)
    [ WARN] [1716998622.786552227]: Could not retrive err_threshold_deg parameter value, using default (10.000000)
    I then ran the commands
    roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch,
    systemctl start voxl-px4-imu-server,
    systemctl enable voxl-px4-imu-server, and
    but I still have not fixed the issue with offboard mode.
    What am I doing wrong? How can I fix offboard mode?
    Kashish GargK 1 Reply Last reply
    • D Denver Bennett
      Kashish GargK Offline
      Kashish Garg
      @Denver-Bennett Were you able to find a solution to this? same issue on my end
