<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MAVRS: offboard mode issues, .&#x2F;run_mavros_test.sh]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I hope you are well. I am following the <a href="https://docs.modalai.com/mavros/" rel="nofollow ugc">How to Run MAVROS</a> tutorial. So far, I've been able to follow the entire tutorial without issues. I'm working on launching the simple-example demo by running the command <code>./run_mavros_test.sh</code>.</p>
<p dir="auto">I'm currently running this command on a VOXL2, but it is not mounted on any drone. The VOXL2 only has some image sensors attached, but that's it. When I run the command <code> ./run_mavros_test.sh</code>, it runs, but then terminal stops printing at <code>[ INFO] [1716998627.576438699]: waiting for offboard mode</code>.</p>
<p dir="auto">What is the issue with <code>offboard mode</code>?</p>
<p dir="auto">Earlier, terminal printed some lines which read as follows:</p>
<p dir="auto"><code>[ WARN] [1716998622.782124555]: Could not retrive negate_measured_roll parameter value, using default (0)</code><br />
<code>[ WARN] [1716998622.782390009]: Could not retrive negate_measured_pitch parameter value, using default (0)</code><br />
<code>[ WARN] [1716998622.784349536]: Could not retrive negate_measured_yaw parameter value, using default (0)</code><br />
<code>[ WARN] [1716998622.786280367]: Could not retrive debounce_s parameter value, using default (4.000000)</code><br />
<code>[ WARN] [1716998622.786552227]: Could not retrive err_threshold_deg parameter value, using default (10.000000)</code></p>
<p dir="auto">I then ran the commands<br />
<code>roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch</code>,<br />
<code>systemctl start voxl-px4-imu-server</code>,<br />
<code>systemctl enable voxl-px4-imu-server</code>, and<br />
<code>./run_mavros_test.sh</code><br />
but I still have not fixed the issue with offboard mode.</p>
<p dir="auto">What am I doing wrong? How can I fix offboard mode?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/topic/3502/mavrs-offboard-mode-issues-run_mavros_test-sh</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 15:35:28 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3502.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 May 2024 18:46:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MAVRS: offboard mode issues, .&#x2F;run_mavros_test.sh on Wed, 14 Aug 2024 17:47:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2158">@Denver-Bennett</a> Were you able to find a solution to this? same issue on my end</p>
]]></description><link>https://forum.modalai.com/post/18615</link><guid isPermaLink="true">https://forum.modalai.com/post/18615</guid><dc:creator><![CDATA[Kashish Garg]]></dc:creator><pubDate>Wed, 14 Aug 2024 17:47:04 GMT</pubDate></item></channel></rss>
