  3. Camera server keep crashing everytime it is launched
px4-dev-kit
25 Posts 4 Posters 8.5k Views 2 Watching
    @Judoor-0 , it seems in this test TOF has not even been detected, you can see two cameras found in slots 2 and 3 (imx214 hi-res camera and ov7251 tracking camera).
    Did anything change? (Tof unplugged?)
    Just fyi, even if you disable cameras in the config, they will still be detected.
    J Offline
    J Offline
    Judoor 0
    @Alex-Kushleyev Well the tof sensor work from time to time but only for a short period.
    When it works, I've got point cloud in voxl Portal (but it's upside down) and after a bit, it just stop functioning. It's quite random and hard to reproduce.
      [[topic:post-is-deleted]]
      @Gary-Holmgren , can you send me a picture or diagram that shows where hires, tracking and new TOF sensor are plugged in? Are they plugged in as C06 configuration, except instead of old TOF, you have the new TOF module? https://docs.modalai.com/voxl2-camera-configs/#c-06-tof-hires-and-tracking-d0005-starling
      • J Judoor 0
        @Judoor-0 , have you used the TOF sensor recently for extended periods of time (before upgrading to SDK 1.2.0 ?). Extended, i mean, longer than just a few minutes.
        I am just trying to figure out whether this is an old hardware problem or a new software problem (or potentially new hardware problem).
        Also, what adapter do you use to plug the TOF sensor into VOXL2 board (the first adapter that plugs into VOXL2). Is it M0076 or M0135 or something else?
        J 2 Replies Last reply
          J Offline
          J Offline
          Judoor 0
          @Alex-Kushleyev No I didn't use the TOF sensor before, I almost directly updated the sdk.
          But what I can recall is that even on the original 1.1.1 sdk I didn't saw any point cloud on the tof_pc on voxl portal. But I thought it was because I had to set something up for it to work.
          On the version 1.2.0 I did saw once (as mention before) some point cloud appear on voxl-portal but after 3 minutes it crashed and I've never seen it since.
          The cable that come from the TOF sensor is MFPC-M0040 REV A and the adapter for the board is M0135.
          Julien
            Gary HolmgrenG Offline
            Gary Holmgren
              J Offline
              J Offline
              Judoor 0
              @Alex-Kushleyev I really need this sensor to work so can you tell me if you think that it is a hardware problem I need to change the faulty piece as quick as possible. I'm right now making a new order for another starling 2 so I need to know.
              Otherwise, what can I do to debug this sensor.
              Julien
              • J Judoor 0
                Julien
                @Judoor-0 , I am sorry that this happened to you.
                It seems that there is some hardware issue.
                Let's do a quick test by connecting TOF to a different camera port and updating camera server configuration to reflect this:
                • i am assuming your 3 cameras (tof, hires, tracking) are connected in the following configuration : https://docs.modalai.com/voxl2-camera-configs/#c-06-tof-hires-and-tracking-d0005-starling
                • this means TOF should be in slot 0, IMX214 in slot 2, ov7251 (tracking) in slot 3. the last two i can see confirmed from the log that you posted (where TOF was not detected).
                • power off voxl2
                • remove the flex cable witih IMX214 and tracking camera from J7
                • disconnect M0135 + TOF from J6 and plug it into J7 (same orientation as it was plugged into J6)
                • power on voxl2
                • copy the TOF driver for slot 2: /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_2.bin
                • run voxl-camera-server -l to see if TOF is detected in slot 2
                • edit /etc/voxl-camera-server.conf to disable hires and tracking cameras (enabled : false), confirm that TOF camera ID is set to 0 and TOF is enabled in the config file
                • start voxl-camera-server in foreground and see if TOF is functioning normally.
                Please let me know the result.
                J 1 Reply Last reply
                  • power off voxl2
                  • power on voxl2
                  J Offline
                  J Offline
                  Judoor 0
                  @Alex-Kushleyev Here is my starling 2 camera configuration the only difference is that I also have a M0135 module to connect the imx214 and tracking.
                  So, I unpluged the cameras, plug the TOF sensor on the other M0135 adapter.
                  I copied the driver in /usr/lib/camera and delete the existing one for slot 2 (it was imx214)
                  Now when I run voxl-camera-server -l I got this, so I suppose it correctly detected the TOF sensor.
                  voxl2:/$ voxl-camera-server -l
                  DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x007A, Sensor Id: 0x003D
                  DEBUG:   Number of cameras: 1
                  Stats for camera: 0
                   224 x 1557
                   224 x 1557 HAL_PIXEL_FORMAT_RAW10
                   224 x 1557 HAL_PIXEL_FORMAT_RAW12
                   224 x 1557 HAL_PIXEL_FORMAT_RAW16
                   224 x 1557 HAL_PIXEL_FORMAT_RAW_OPAQUE
                  	min = 54
                  	max = 0
                  	min = 0ns
                  	max = 0ns
                  Number of cameras detected: 1
                  Just a note here, I found weird that the recommended resolution for the camera is 224x1557. Shouldn't it be 224x171 ?
                  Then when I disable the other cam and start the voxl-camera-server, I still got this with voxl-inspect-cam -a
                  And I've got the same errors when I directly run voxl-camera-server, the command end up by aborted and nothing's working.
                  detected system image 1.7.6
                  using new imx214 defaults
                  configuration for 3 cameras:
                  cam #0
                      sensor type:         pmd-tof
                      isEnabled:           1
                      camId:               0
                      camId2:              -1
                      fps:                 5
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           224
                      pre_height:          1557
                      en_raw_preview:      1
                      en_small_video:      0
                      small_video_width:   -1
                      small_video_height:  -1
                      en_large_video:      0
                      large_video_width:   -1
                      large_video_height:  -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             off
                      standby_enabled:     0
                      decimator:           5
                      independent_exposure:0
                  cam #1
                      sensor type:         imx214
                      isEnabled:           0
                      camId:               1
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      small_video_width:   1024
                      small_video_height:  768
                      en_large_video:      1
                      large_video_width:   4208
                      large_video_height:  3120
                      en_snapshot:         1
                      snap_width:          4208
                      snap_height:         3120
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                  cam #2
                      sensor type:         ov7251
                      isEnabled:           0
                      camId:               2
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      standby_enabled:     0
                      decimator:           1
                  fsync_en:            0
                  fsync_gpio:          111
                  connected to GPS mavlink pipe
                  Starting Camera: tof (id #0)
                  Connected to cpu-monitor
                  	Skipping Camera: hires, configuration marked disabled
                  	Skipping Camera: tracking, configuration marked disabled
                  ------ voxl-camera-server: Started 1 of 3 cameras
                  Aborted
                  • J Judoor 0
                    Stats for camera: 0
                     224 x 1557
                    	min = 54
                    	max = 0
                    	min = 0ns
                    	max = 0ns
                    cam #0
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 5
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           224
                        pre_height:          1557
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             off
                        standby_enabled:     0
                        decimator:           5
                    cam #1
                        sensor type:         imx214
                        isEnabled:           0
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_snapshot:         1
                        snap_width:          4208
                        snap_height:         3120
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        sensor type:         ov7251
                        isEnabled:           0
                        camId:               2
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            0
                    fsync_gpio:          111
                    Aborted
                    @Judoor-0 , since the issue is the same when using voxl2 J7, it seems there may be a hw issue either in the m0135 adapter or the tof module. If you are able, please try the second m0135 adapter (disconnect from the hires and tracking cameras and connect to tof), then plug back into j7. If the symptoms repeat, the TOF sensor is most likely bad, so we can send a replacement one to you.
                      J Offline
                      J Offline
                      Judoor 0
                      @Alex-Kushleyev I tried with both and it didn't work either.
                      Please, if you can send a replacement one as soon as possible it would be great because my schedule to deliver the finish product is very tight.
                      Julien
                        J Offline
                        J Offline
                        Judoor 0
                        @Alex-Kushleyev Also why does it says that the resolution for the camera should be 224x1557 and not 224x171 like on the datasheet of the sensor?
                        Julien
                        • J Judoor 0
                          Julien
                          @Judoor-0 , the tof sensor takes multiple exposures and returns stacked IR image (kind of like HDR). That image is processed by the TOF library on the cpu to output the final image at the proper resolution.
                          I will check about RMA, you probably need to fill out the form: https://www.modalai.com/pages/rma
                            J Offline
                            J Offline
                            Judoor 0
                            @Alex-Kushleyev Ok, I filled up the RMA form in cas it's needed.
                            My S/N is M23000001E9.
                            Julien
                            • J Judoor 0
                              Julien
                              Jetson NanoJ Offline
                              Jetson Nano
                              Veteran
                              @Judoor-0 I'm facing a similar problem with ToF configuration on a Starling setup. Through RMA was anything wrt. to hardware found? If not how did RMA help you?
                              • Jetson NanoJ Jetson Nano
                                @Jetson-Nano , if you run the camera server in foreground (and with -d 0 option to enable debugging), it could help localize the issue. Also try disabling cameras one by one in voxl-camera-server.conf to find which camera is causing an issue.
                                Is the issue you are seeing specific to TOF? Was it previously working?
                                  Jetson Nano
                                  Veteran
                                  #24
                                  @Alex-Kushleyev I tried that and have posted the output here (https://forum.modalai.com/topic/3688/vision-sensors-not-detected-in-voxl2). Initially the issue was with all the cameras, now it is only ToF.
                                    @Jetson-Nano , OK it seems we have two parallel threads going. please see my reply to the other thread https://forum.modalai.com/topic/3688/vision-sensors-not-detected-in-voxl2 and test it step by step as I suggested (reducing fps of imx214 camera first, then disabling sensors one by one)
