Pin Assignments for voxlCAM Connectors to Jetson Nano
I am trying to connect the voxlCAM to a Jetson Nano using the connectors instead of the USB cable. The voxlCAM has three visible connectors, and I need detailed information on the pin assignments and how to utilize these connectors for connection.
Could you please provide documentation or guidance on the pin assignments for these connectors and any necessary steps to successfully connect the voxlCAM to the Jetson Nano?
Thank you for your assistance.
Best regards,
Best regards,
@藤田真也 Inside for VOXL CAM is a VOXL 1. The datasheet which describes the VOXL 1 connectors is here: https://docs.modalai.com/voxl-datasheets-connectors/
@Moderator
Hello,Thank you very much for your prompt response and for providing the link to the datasheet for the VOXL 1 connectors. This information is exactly what I needed. I appreciate your assistance and support.
