esc
108 Posts 3 Posters 74.9k Views 1 Watching
    @rdjarvis , I loaded the same params that you were testing and I was able to reproduce the issue.
    The issue is that the old spin-up procedure is not working well for this particular motor and the ESC incorrectly synchronized with the motor phases (de-sync), resulting in incorrect motor control and motor overheating.
    We recommend using our new sinusoidal spin-up procedure which is a lot more reliable.
    I will make a new parameter file for the Tmotor 2850kV motor with a 3076 propeller and share with you as well as resulting plots for your reference.
    rdjarvisR Offline
    rdjarvisR Offline
    rdjarvis
    @Alex-Kushleyev Wonderful! Thank you for the hard work! Im happy you were able to reproduce. As you see, the motor heats up very early on the calibration cycle.
    We are ready to test as soon as you can send those params!
    Thank you,
    RDJ
    • rdjarvisR rdjarvis
      Thank you,
      RDJ
      @rdjarvis ,
      I have added the parameter file (here) . I used your exact motor and 3076 tri-blade propeller.
      If you have slightly different propeller, all you should have to do is just run the calibration procedure (please use voxl-esc tools from main branch) , update the a0,a1,a2 params and upload the new esc param file to the ESC.
      I think this should perform pretty well, i did some aggressive testing (rpm step from 10k to 30k rpm), using the following command, and the results are very smooth. You can use this test and start with a lower step amplitude and make sure that works well and then increase the step size as you gain confidence. you should see smooth results like this, if you see any unusual spikes, let me know and send a plot.
      #only test this with battery (not power supply) due to regenerative spikes
      ./voxl-esc-spin-step.py --id 2 --rpm 10000 --step-amplitude 20000 --timeout 3 --enable-plot 1 --cmd-rate 2000
      Please upload this param file, and run the calibration, you can also do the ramp test to 100% using
      ./voxl-esc-spin.py --id 2 --power 100 --ramp-time 2.0 --timeout 2.5 --enable-plot 1 --cmd-rate 250
      Produces the following results on my setup (very smooth):
      You can update your max rpm based on this result, but beware that max rpm is a function of voltage.
        @rdjarvis ,
        rdjarvisR Offline
        rdjarvisR Offline
        rdjarvis
        @Alex-Kushleyev We will test soon and get back to you.
        As always, thank you for all the help!!
        RDJ
          @rdjarvis ,
          Alexander SaundersA Offline
          Alexander Saunders
          We ran the calibration script and failing to see where/which directory the html file is being stored. Could you point me to the location?
          • blueB blue referenced this topic on
            @Alexander-Saunders , the file should be saved in the same directory where you are running the calibration script from (current directory). here is the line of code in the calibration script, which saves the figure right before trying to plot it in a browser.
              here is the calibration result i got with my setup (and the a0, a1, a2 params are already in the xml file i linked before):
              rdjarvisR 1 Reply Last reply
                rdjarvisR Offline
                rdjarvisR Offline
                rdjarvis
                @Alex-Kushleyev after uploading the new params you sent the ESC no longer communicates with the VOXL2.
                The ESC board is no longer recognized by VOXL2. All hardware is set up properly.
                voxl_uart_read_byte bus 12 is not initiated
                Please point us in the right direction.
                  @rdjarvis , the latest params switched baud rate from 250k to 2mbit, but that should not be an issue. You should make sure voxl esc param in px4 is 20000000.
                  Please try voxl-esc python tools directly and make sure px4 is disabled when you run them (instead of running the voxl-esc wrapper like you did).
                  Sometimes stopping px4 gets the dsp in a weird state, in which case you can disable px4 from autostart, reboot and then do a voxl-esc-scan.py
                    rdjarvisR Offline
                    rdjarvisR Offline
                    rdjarvis
                    @Alex-Kushleyev Copy all, we will try. Thank you.
                      Alexander Saunders
                      For the esc tools, we were running the commands from /usr/share/modalai/voxl-esc-tools. To clarify, for the baud rate changes, do you want 2,000,000 or 20,000,000. We will try the tools again and confirm px4 is stopped via systemctl stop voxl-px4.
                        @Alexander-Saunders, my bad too many zeros. 2,000,000 (2Mbit)
                        Alex KushleyevA Alexander SaundersA 2 Replies Last reply
                          #36
                          The screen shot in earlier post today shows running “voxl-esc” which is a wrapper for the python tools, sometimes it is easier just to use python tools directly, but make sure they are latest version. the version in /usr/share/modalai is probably not latest. Normally you dont need to update the tools but if something is not working as expected, it is good to try the latest.
                            rdjarvisR Offline
                            rdjarvisR Offline
                            rdjarvis
                            We verified PX4 was not running.
                              Alexander Saunders
                              No worries. We also verified if the issue was with the particular param file and ran the command to upload a different one. No luck with that and we still receive the same error (Bus 12, ESC not detected, etc)
                                @Alexander-Saunders
                                Can you please try voxl-esc tools from dev branch on github? Instead of /usr/share/modalai/voxl-esc-tools
                                  @Alexander-Saunders
                                  Also, which SDK are you using? i am surprised to see this issue.
                                  Also, can you please double check the ESC bootup sequence:
                                  • apply power
                                  • 4 blue leds flash quickly for 1 second, then turn off
                                  • 4 blue leds blink twice
                                  • motor makes a quick chirp (three tones based on the latest params that provided)
                                  rdjarvisR Alex KushleyevA 2 Replies Last reply
                                    • apply power
                                    rdjarvisR Offline
                                    rdjarvisR Offline
                                    rdjarvis
                                    @Alex-Kushleyev ESC gave
                                    4 LEDs quickly flashing
                                    4 LEDs flash 3 times
                                    Motor chirps
                                      Motor chirps
                                      rdjarvisR Offline
                                      rdjarvisR Offline
                                      rdjarvis
                                        • apply power
                                        One more suggestion, it often helps to use a direct connection between the ESC and your linux PC and run the voxl-esc tools there. This way you can see the plots instantly during testing and also if there are some issues with communication to the ESC, you can always connect it to the PC and check the ESC that way.
                                        Do you have a USB to serial adapter cable that plugs into the ESC <-> PC ?
                                          Motor chirps
                                          @rdjarvis said in Motor issues when running ESC calibration:
                                          Motor chirps
                                          OK that is good!
