    ADB shell connects to root@m0054:/# instead of voxl2:/$
    • S
      swickliff
      When I try to ADB shell, it accesses root@m0054:/# instead of voxl2:/$
      This root interface does not have any of the voxl bash commands. For instance I couldn't use voxl-inspect-services.
      I've tried killing and restarting the ADB server, but that did nothing
      lsusb is reading the device as Qualcomm, Inc. KONA-QRD _SN:3C6BFAA2
      A previous forum post had the same issue, they said it was a permissions issue.
      I am not sure what permissions I should try to change. How can I change what ADB shell connects to?
        tom admin @swickliff
        @swickliff It seems as though the voxl-suite hasn't been installed. Can you download and install the latest SDK (1.1.3) from our downloads page? downloads.modalai.com
        • S
          swickliff @tom
          The SDK install failed to locate the voxl-suite-offline-packages. I used the 1.1.2 release because that is what we currently have on our other Voxl2 boards at the moment. If you think the 1.1.3 release will produce different results I can try that.
          Here's a screenshot of the errors:
          This board was originally bricked by accident and went through the unbricking guide but had some warnings or errors pop up when the Image was re-flashed. I believe the Image reflash was attempted again but failed.
            @swickliff What command did you run to generate the above failure? Are you running ./install.sh from the SDK download dir
            • S
              swickliff @tom
              @tom yes, I used ./install.sh from the voxl2_SDK_1.1.2 dir
                @swickliff Can you try ./install.sh -w ? That will do a full system wipe in case a partition is corrupt
                • S
                  swickliff @tom
                  @tom That worked! thanks for the help
