    VOXL2 mpatoros2 build
    885
    • D
      Darshit Desai
      I have been following instructions of building mpatoros2 for voxl2 starling using the emulator but everytime I try to build it it shows some error related to ros2 foxy
      I am following this instructions: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/master?ref_type=heads
      I have installed qrb5165 arm emulator using this instructions: https://docs.modalai.com/voxl-emulator/
      Error:
      • D Darshit Desai referenced this topic on 31 Jan 2024, 16:34
      • Z
        Zachary Lowell 0 ModalAI Team
        I just ran through the install script as well and am not getting this issue. Can you please show we a step by step of what you are doing. Maybe you can tee it into a log file or copy and paste the terminal output. Can you also checkout the dev branch please and then retry?
        D 1 Reply Last reply 31 Jan 2024, 16:49 Reply Quote 0
        • D
          Darshit Desai @Zachary Lowell 0
          @Zachary-Lowell-0
          This is the first command I ran installdeps, the output is below:
          qrb5165-emulator:~(dev)(0.0.2)$ ./install_build_deps.sh qrb5165 stable
          using qrb5165 stable debian repo
          Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ InRelease
          Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Release
          Ign:3 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Packages
          Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Translation-en
          Err:3 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Packages
            404  Not Found [IP: 35.215.116.197 80]
          Reading package lists...
          installing:
          libmodal-json
          libmodal-pipe
          libvoxl-cutils
          voxl-ros2-foxy
          Hit:1 http://packages.ros.org/ros/ubuntu bionic InRelease
          Hit:2 http://packages.ros.org/ros2/ubuntu bionic InRelease
          Get:3 https://download.docker.com/linux/ubuntu bionic InRelease [64.4 kB]
          Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ InRelease
          Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
          Ign:6 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Release
          Hit:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
          Ign:8 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Packages
          Hit:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
          Ign:10 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Translation-en
          Hit:11 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
          Err:8 http://voxl-packages.modalai.com ./dists/qrb5165/stable/binary-arm64/ Packages
          Fetched 64.4 kB in 6s (10.1 kB/s)
          Building dependency tree...
          Reading state information...
          0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
          libeigen3-dev is already the newest version (3.3.4-4).
          python3-pip is already the newest version (9.0.1-2.3~ubuntu1.18.04.8).
          python3-numpy is already the newest version (1:1.13.3-2ubuntu1).
          Requirement already satisfied: pip in /usr/local/lib/python3.6/dist-packages (21.3.1)
          Requirement already satisfied: colcon-common-extensions in /usr/local/lib/python3.6/dist-packages (0.3.0)
          Requirement already satisfied: lark in /usr/local/lib/python3.6/dist-packages (1.1.9)
          Requirement already satisfied: colcon-notification in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.15)
          Requirement already satisfied: colcon-bash in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.5.0)
          Requirement already satisfied: colcon-ros in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.4.1)
          Requirement already satisfied: colcon-metadata in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.5)
          Requirement already satisfied: colcon-defaults in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.8)
          Requirement already satisfied: colcon-zsh in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.5.0)
          Requirement already satisfied: colcon-library-path in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.1)
          Requirement already satisfied: colcon-package-selection in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.10)
          Requirement already satisfied: colcon-argcomplete in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.3.3)
          Requirement already satisfied: colcon-devtools in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.5)
          Requirement already satisfied: colcon-cd in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.1.1)
          Requirement already satisfied: colcon-cmake in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.28)
          Requirement already satisfied: colcon-package-information in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.3.3)
          Requirement already satisfied: colcon-parallel-executor in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.3.0)
          Requirement already satisfied: colcon-python-setup-py in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.8)
          Requirement already satisfied: colcon-test-result in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.3.8)
          Requirement already satisfied: colcon-core in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.15.2)
          Requirement already satisfied: colcon-recursive-crawl in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.3)
          Requirement already satisfied: colcon-output in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.2.13)
          Requirement already satisfied: colcon-powershell in /usr/local/lib/python3.6/dist-packages (from colcon-common-extensions) (0.4.0)
          Requirement already satisfied: argcomplete in /usr/lib/python3/dist-packages (from colcon-argcomplete->colcon-common-extensions) (1.8.1)
          Requirement already satisfied: pytest in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (7.0.1)
          Requirement already satisfied: pytest-cov in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (4.0.0)
          Requirement already satisfied: packaging in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (21.3)
          Requirement already satisfied: pytest-repeat in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (0.9.1)
          Requirement already satisfied: EmPy<4 in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (3.3.4)
          Requirement already satisfied: pytest-rerunfailures in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (10.3)
          Requirement already satisfied: distlib in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (0.3.8)
          Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.6/dist-packages (from colcon-core->colcon-common-extensions) (4.8.3)
          Requirement already satisfied: setuptools>=30.3.0 in /usr/lib/python3/dist-packages (from colcon-core->colcon-common-extensions) (39.0.1)
          Requirement already satisfied: PyYAML in /usr/local/lib/python3.6/dist-packages (from colcon-defaults->colcon-common-extensions) (6.0.1)
          Requirement already satisfied: notify2 in /usr/local/lib/python3.6/dist-packages (from colcon-notification->colcon-common-extensions) (0.3.1)
          Requirement already satisfied: catkin-pkg>=0.4.14 in /usr/local/lib/python3.6/dist-packages (from colcon-ros->colcon-common-extensions) (1.0.0)
          Requirement already satisfied: colcon-pkg-config in /usr/local/lib/python3.6/dist-packages (from colcon-ros->colcon-common-extensions) (0.1.0)
          Requirement already satisfied: docutils in /usr/local/lib/python3.6/dist-packages (from catkin-pkg>=0.4.14->colcon-ros->colcon-common-extensions) (0.18.1)
          Requirement already satisfied: pyparsing in /usr/local/lib/python3.6/dist-packages (from catkin-pkg>=0.4.14->colcon-ros->colcon-common-extensions) (3.1.1)
          Requirement already satisfied: python-dateutil in /usr/local/lib/python3.6/dist-packages (from catkin-pkg>=0.4.14->colcon-ros->colcon-common-extensions) (2.8.2)
          Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.6/dist-packages (from importlib-metadata->colcon-core->colcon-common-extensions) (3.6.0)
          Requirement already satisfied: typing-extensions>=3.6.4 in /usr/local/lib/python3.6/dist-packages (from importlib-metadata->colcon-core->colcon-common-extensions) (4.1.1)
          Requirement already satisfied: pluggy<2.0,>=0.12 in /usr/local/lib/python3.6/dist-packages (from pytest->colcon-core->colcon-common-extensions) (1.0.0)
          Requirement already satisfied: tomli>=1.0.0 in /usr/local/lib/python3.6/dist-packages (from pytest->colcon-core->colcon-common-extensions) (1.2.3)
          Requirement already satisfied: iniconfig in /usr/local/lib/python3.6/dist-packages (from pytest->colcon-core->colcon-common-extensions) (1.1.1)
          Requirement already satisfied: attrs>=19.2.0 in /usr/local/lib/python3.6/dist-packages (from pytest->colcon-core->colcon-common-extensions) (22.2.0)
          Requirement already satisfied: py>=1.8.2 in /usr/local/lib/python3.6/dist-packages (from pytest->colcon-core->colcon-common-extensions) (1.11.0)
          Requirement already satisfied: coverage[toml]>=5.2.1 in /usr/local/lib/python3.6/dist-packages (from pytest-cov->colcon-core->colcon-common-extensions) (6.2)
          Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil->catkin-pkg>=0.4.14->colcon-ros->colcon-common-extensions) (1.11.0)
          Done installing dependencies
          This is second clean up and build command:
          qrb5165-emulator:~(dev)(0.0.2)$ ./clean.sh
          qrb5165-emulator:~(dev)(0.0.2)$ ./build.sh qrb5165 | tee build_log.log
          ./build.sh: line 41: /opt/ros/foxy/setup.bash: No such file or directory
          D 1 Reply Last reply 31 Jan 2024, 16:54 Reply Quote 0
          • D
            Darshit Desai @Darshit Desai
            @Zachary-Lowell-0 This time instead of building with the stable tag in the install deps command I kept the dev tag and it fails to build some packages in the build stage
            qrb5165-emulator:~(dev)(0.0.2)$ ./install_build_deps.sh qrb5165 dev | tee install_command_dev.log
            using qrb5165 dev debian repo
            Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ InRelease
            Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Release
            Ign:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages
            Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Translation-en
            Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages [40.3 kB]
            Fetched 40.3 kB in 1s (29.7 kB/s)
            installing:
            libmodal-json
            libmodal-pipe
            libvoxl-cutils
            voxl-ros2-foxy
            WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
            Get:2 https://download.docker.com/linux/ubuntu bionic InRelease [64.4 kB]
            Hit:3 http://packages.ros.org/ros2/ubuntu bionic InRelease
            Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ InRelease
            Ign:6 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Release
            Ign:8 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages
            Ign:10 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Translation-en
            Hit:8 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages
            4 packages can be upgraded. Run 'apt list --upgradable' to see them.
            0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
            The following NEW packages will be installed:
              libmodal-json libmodal-pipe libvoxl-cutils voxl-ros2-foxy
            0 upgraded, 4 newly installed, 0 to remove and 4 not upgraded.
            Need to get 20.5 MB of archives.
            After this operation, 0 B of additional disk space will be used.
            Get:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-json 0.4.3-202209281920 [43.8 kB]
            Get:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-pipe 2.10.0-202311162306 [86.6 kB]
            Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libvoxl-cutils 0.1.1-202210072352 [6228 B]
            Get:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ voxl-ros2-foxy 0.0.1-202310061042 [20.3 MB]
            debconf: delaying package configuration, since apt-utils is not installed
            Fetched 20.5 MB in 2s (9809 kB/s)
                                             Selecting previously unselected package libmodal-json.
            (Reading database ... 118815 files and directories currently installed.)
            Preparing to unpack .../libmodal-json_0.4.3-202209281920_arm64.deb ...
            Unpacking libmodal-json (0.4.3-202209281920) ...
            Selecting previously unselected package libmodal-pipe.
            Preparing to unpack .../libmodal-pipe_2.10.0-202311162306_arm64.deb ...
            Unpacking libmodal-pipe (2.10.0-202311162306) ...
            Selecting previously unselected package libvoxl-cutils.
            Preparing to unpack .../libvoxl-cutils_0.1.1-202210072352_arm64.deb ...
            Unpacking libvoxl-cutils (0.1.1-202210072352) ...
            Selecting previously unselected package voxl-ros2-foxy.
            Preparing to unpack .../voxl-ros2-foxy_0.0.1-202310061042_arm64.deb ...
            Unpacking voxl-ros2-foxy (0.0.1-202310061042) ...
            Setting up libvoxl-cutils (0.1.1-202210072352) ...
            Setting up libmodal-json (0.4.3-202209281920) ...
            Setting up libmodal-pipe (2.10.0-202311162306) ...
            Setting up voxl-ros2-foxy (0.0.1-202310061042) ...
            Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
            WARNING: The directory '/home/root/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
            WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
            Starting >>> voxl_msgs
            Starting >>> voxl_offboard_figure8
            Finished <<< voxl_offboard_figure8 [3.46s]
            Finished <<< voxl_msgs [32.9s]
            Starting >>> voxl_mpa_to_ros2
            --- stderr: voxl_mpa_to_ros2
            CMake Error at CMakeLists.txt:58 (find_package):
              By not providing "Findpx4_ros_com.cmake" in CMAKE_MODULE_PATH this project
              has asked CMake to find a package configuration file provided by
              "px4_ros_com", but CMake did not find one.
              Could not find a package configuration file provided by "px4_ros_com" with
              any of the following names:
                px4_ros_comConfig.cmake
                px4_ros_com-config.cmake
              Add the installation prefix of "px4_ros_com" to CMAKE_PREFIX_PATH or set
              "px4_ros_com_DIR" to a directory containing one of the above files.  If
              "px4_ros_com" provides a separate development package or SDK, be sure it
              has been installed.
            Failed   <<< voxl_mpa_to_ros2 [13.9s, exited with code 1]
            Summary: 2 packages finished [48.6s]
              1 package failed: voxl_mpa_to_ros2
              1 package had stderr output: voxl_mpa_to_ros2
            • Z
              @Darshit-Desai said in VOXL2 mpatoros2 build:
              Ah I see - please use the staging apt repo when you do the install_dep.sh file.
              D 1 Reply Last reply 31 Jan 2024, 17:03 Reply Quote 0
              • D
                @Zachary-Lowell-0 It still fails to build the package, do I need to switch the branch in git repo too, or just mention it inside the emulator as shown in the install_deps command
                qrb5165-emulator:~(dev)(0.0.2)$ ./install_build_deps.sh qrb5165 staging | tee install_commang.log
                using qrb5165 staging debian repo
                Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ InRelease
                Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Release
                Ign:3 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Packages
                Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Translation-en
                Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Packages [20.7 kB]
                Fetched 20.7 kB in 1s (16.1 kB/s)
                installing:
                libmodal-json
                libmodal-pipe
                libvoxl-cutils
                voxl-ros2-foxy
                Ign:3 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ InRelease
                Hit:4 http://packages.ros.org/ros2/ubuntu bionic InRelease
                Ign:6 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Release
                Ign:8 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Packages
                Ign:10 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Translation-en
                Hit:8 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Packages
                libvoxl-cutils is already the newest version (0.1.1-202210072352).
                voxl-ros2-foxy is already the newest version (0.0.1-202310061042).
                libmodal-pipe is already the newest version (2.10.0-202311162306).
                libmodal-json is already the newest version (0.4.3-202209281920).
                Finished <<< voxl_offboard_figure8 [3.50s]
                Finished <<< voxl_msgs [33.0s]
                  has been installed.
                Summary: 2 packages finished [48.8s]
                • Z
                  Did you do the git submodule update --init --recursive in the repository - it doesn't look like you pulled down all the repositories from the gitlab.
                  D 1 Reply Last reply 31 Jan 2024, 18:57 Reply Quote 0
                  • D
                    @Zachary-Lowell-0 I think that was what was wrong earlier, Now it's building, I will let you know how this goes
                    Starting >>> camera_calibration_parsers
                    Starting >>> image_transport
                    Starting >>> px4_msgs
                    Finished <<< voxl_offboard_figure8 [3.65s]
                    [Processing: camera_calibration_parsers, image_transport, px4_msgs, voxl_msgs]
                    Finished <<< voxl_msgs [41.4s]
                    Finished <<< camera_calibration_parsers [43.9s]
                    Starting >>> camera_info_manager
                    [Processing: camera_info_manager, image_transport, px4_msgs]
                    Finished <<< camera_info_manager [32.8s]
                    Finished <<< image_transport [1min 19s]
                    Starting >>> image_common
                    Finished <<< image_common [11.6s]
                    [Processing: px4_msgs]
                    [13min 47.8s] [6/9 complete] [px4_msgs:build 88% - 13min 45.5s]
                    D 1 Reply Last reply 31 Jan 2024, 19:11 Reply Quote 0
                    • D
                      @Zachary-Lowell-0 it finished with some errors, Do you think it is fine to proceed to the next step?
                      Finished <<< px4_msgs [25min 29s]
                      Starting >>> px4_ros_com
                      [Processing: px4_ros_com]
                      Finished <<< px4_ros_com [38.3s]
                      [Processing: voxl_mpa_to_ros2]
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/camera_interface.h:38:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/camera_interface.cpp:37:
                      /home/root/colcon_ws/install/image_transport/include/image_transport/image_transport.h:41:89: note: #pragma message: Warning: This header is deprecated. Use 'image_transport.hpp' instead
                       #pragma message ("Warning: This header is deprecated. Use 'image_transport.hpp' instead")
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/stereo_interface.h:38:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:36:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/camera_interface.h:39:0,
                      /home/root/colcon_ws/install/image_transport/include/image_transport/publisher.h:41:83: note: #pragma message: Warning: This header is deprecated. Use 'publisher.hpp' instead
                       #pragma message ("Warning: This header is deprecated. Use 'publisher.hpp' instead")
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/point_cloud_interface.h:39:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/point_cloud_interface.cpp:36:
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/generic_interface.h: In static member function 'static void GenericInterface::_interface_dc_cb(int, void*)':
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/generic_interface.h:166:38: warning: unused parameter 'ch' [-Wunused-parameter]
                           static void _interface_dc_cb(int ch, void* context){
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/all_interfaces.h:37:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp:36:
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/all_interfaces.h:38,
                      /home/root/colcon_ws/install/image_transport/include/image_transport/image_transport.h: At global scope:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interface_manager.h:37:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/mpa_ros_node.cpp:41:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/camera_interface.h:41:0,
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/imu_interface.h:40:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/imu_interface.cpp:34:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/pose_vel_6dof_interface.h:43:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/pose_vel_6dof_interface.cpp:34:
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp: In function 'int findPipes(InterfaceListNode*, rclcpp::Node::SharedPtr)':
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp:111:5: warning: this 'for' clause does not guard... [-Wmisleading-indentation]
                           for(tail = head; tail->next != NULL; tail = tail->next);
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp:113:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'for'
                        FILE *fp = popen("voxl-list-pipes --mode-types", "r");
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/ai_detection_interface.h:37:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/ai_detection_interface.cpp:34:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/stereo_interface.h:39:0,
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/qvio_interface.h:42:0,
                                       from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/qvio_interface.cpp:34:
                      In file included from /home/root/colcon_ws/src/voxl_mpa_to_ros2/include/voxl_mpa_to_ros2/interfaces/stereo_interface.h:41:0,
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp: In constructor 'StereoInterface::StereoInterface(rclcpp::Node::SharedPtr, const char*)':
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:44:1: warning: '%s' directive writing up to 95 bytes into a region of size 64 [-Wformat-overflow=]
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:52:12: note: 'sprintf' output between 6 and 101 bytes into a destination of size 64
                           sprintf(frameName, "%s/left", m_pipeName);
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:56:12: note: 'sprintf' output between 7 and 102 bytes into a destination of size 64
                           sprintf(frameName, "%s/right", m_pipeName);
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp: In member function 'virtual void StereoInterface::AdvertiseTopics()':
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:70:6: warning: '%s' directive writing up to 95 bytes into a region of size 64 [-Wformat-overflow=]
                       void StereoInterface::AdvertiseTopics(){
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:76:12: note: 'sprintf' output between 6 and 101 bytes into a destination of size 64
                           sprintf(topicName, "%s/left", m_pipeName);
                      /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/stereo_interface.cpp:79:12: note: 'sprintf' output between 7 and 102 bytes into a destination of size 64
                           sprintf(topicName, "%s/right", m_pipeName);
                      Finished <<< voxl_mpa_to_ros2 [42.5s]
                      Summary: 9 packages finished [26min 52s]
                      Done Building!
                      Also the next step deb file generation worked, according to the website here it says to use command apt install which I think is after I scp the .deb package on starling, does the deploy_to_voxl.sh script work which is already there in voxl_mpa_to_ros2 repo?
                      qrb5165-emulator:~(dev)(0.0.2)$ ./make_package.sh
                      Package Name:  voxl-mpa-to-ros2
                      version Number:  0.0.2
                      starting building Debian Package
                      dpkg-deb: building package 'voxl-mpa-to-ros2' in 'voxl-mpa-to-ros2_0.0.2_arm64.deb'.
                      DONE
                      After doing all the above steps and using dpkg inside voxl2 to install the made mpatoros2 deb it still doesn't work. When pressing tab to auto complete it shows nothing and when I explicitly copy and paste the command it gives this error
                      D 1 Reply Last reply 31 Jan 2024, 20:51 Reply Quote 0
                      • D
                        @Zachary-Lowell-0 I tried to build and deploy the package the second time it shows an error for ros2 foxy, Here's the complete terminal history
                        Fetched 20.7 kB in 1s (16.6 kB/s)
                        Reading package lists... Done
                        installing:
                        libmodal-json
                        libmodal-pipe
                        libvoxl-cutils
                        voxl-ros2-foxy
                        Get:1 http://packages.ros.org/ros/ubuntu bionic InRelease [4680 B]
                        Get:2 http://packages.ros.org/ros2/ubuntu bionic InRelease [4680 B]
                        Ign:4 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ InRelease
                        Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
                        Ign:9 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ Translation-en
                        Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [83.3 kB]
                        Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
                        Get:12 http://packages.ros.org/ros/ubuntu bionic/main arm64 Packages [793 kB]
                        Get:13 http://packages.ros.org/ros2/ubuntu bionic/main arm64 Packages [660 kB]
                        Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 Packages [1845 kB]
                        Get:15 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Translation-en [554 kB]
                        Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 Packages [1718 kB]
                        Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe Translation-en [421 kB]
                        Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 Packages [1559 kB]
                        Get:19 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 Packages [1173 kB]
                        Get:20 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Translation-en [308 kB]
                        Fetched 9365 kB in 7s (1308 kB/s)
                        Need to get 20.4 MB of archives.
                        Get:1 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ libmodal-json 0.4.3 [44.1 kB]
                        Get:2 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ libmodal-pipe 2.10.0 [86.6 kB]
                        Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ libvoxl-cutils 0.1.1 [6228 B]
                        Get:4 http://voxl-packages.modalai.com ./dists/qrb5165/staging/binary-arm64/ voxl-ros2-foxy 0.0.1 [20.3 MB]
                        Fetched 20.4 MB in 2s (10.5 MB/s)
                        (Reading database ... 118745 files and directories currently installed.)
                        Preparing to unpack .../libmodal-json_0.4.3_arm64.deb ...
                        Unpacking libmodal-json (0.4.3) ...
                        Preparing to unpack .../libmodal-pipe_2.10.0_arm64.deb ...
                        Unpacking libmodal-pipe (2.10.0) ...
                        Preparing to unpack .../libvoxl-cutils_0.1.1_arm64.deb ...
                        Unpacking libvoxl-cutils (0.1.1) ...
                        Preparing to unpack .../voxl-ros2-foxy_0.0.1_arm64.deb ...
                        Unpacking voxl-ros2-foxy (0.0.1) ...
                        Setting up libvoxl-cutils (0.1.1) ...
                        Setting up libmodal-json (0.4.3) ...
                        Setting up libmodal-pipe (2.10.0) ...
                        Setting up voxl-ros2-foxy (0.0.1) ...
                        Suggested packages:
                          libeigen3-doc libmrpt-dev
                          libeigen3-dev
                        0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
                        Need to get 810 kB of archives.
                        After this operation, 7128 kB of additional disk space will be used.
                        Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 libeigen3-dev all 3.3.4-4 [810 kB]
                        Fetched 810 kB in 1s (593 kB/s)
                        Selecting previously unselected package libeigen3-dev.
                        (Reading database ... 137052 files and directories currently installed.)
                        Preparing to unpack .../libeigen3-dev_3.3.4-4_all.deb ...
                        Unpacking libeigen3-dev (3.3.4-4) ...
                        Setting up libeigen3-dev (3.3.4-4) ...
                        The directory '/home/root/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
                        The directory '/home/root/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
                        Collecting pip
                          Downloading https://files.pythonhosted.org/packages/a4/6d/6463d49a933f547439d6b5b98b46af8742cc03ae83543e4d7688c2420f8b/pip-21.3.1-py3-none-any.whl (1.7MB)
                            100% |################################| 1.7MB 474kB/s
                        Installing collected packages: pip
                          Found existing installation: pip 9.0.1
                            Not uninstalling pip at /usr/lib/python3/dist-packages, outside environment /usr
                        Successfully installed pip-21.3.1
                        Collecting colcon-common-extensions
                          Downloading colcon_common_extensions-0.3.0-py3-none-any.whl (6.5 kB)
                        Collecting lark
                          Downloading lark-1.1.9-py3-none-any.whl (111 kB)
                             |################################| 111 kB 6.2 MB/s
                        Collecting colcon-devtools
                          Downloading colcon_devtools-0.2.5-py3-none-any.whl (10 kB)
                        Collecting colcon-powershell
                          Downloading colcon_powershell-0.4.0-py3-none-any.whl (13 kB)
                        Collecting colcon-cd
                          Downloading colcon_cd-0.1.1-py3-none-any.whl (3.6 kB)
                        Collecting colcon-ros
                          Downloading colcon_ros-0.4.1-py3-none-any.whl (28 kB)
                        Collecting colcon-core
                          Downloading colcon_core-0.15.2-py3-none-any.whl (130 kB)
                             |################################| 130 kB 20.4 MB/s
                        Collecting colcon-package-selection
                          Downloading colcon_package_selection-0.2.10-py3-none-any.whl (16 kB)
                        Collecting colcon-parallel-executor
                          Downloading colcon_parallel_executor-0.3.0-py3-none-any.whl (10.0 kB)
                        Collecting colcon-python-setup-py
                          Downloading colcon_python_setup_py-0.2.8-py3-none-any.whl (11 kB)
                        Collecting colcon-library-path
                          Downloading colcon_library_path-0.2.1-py3-none-any.whl (4.9 kB)
                        Collecting colcon-notification
                          Downloading colcon_notification-0.2.15-py3-none-any.whl (63 kB)
                             |################################| 63 kB 17.3 MB/s
                        Collecting colcon-package-information
                          Downloading colcon_package_information-0.3.3-py3-none-any.whl (15 kB)
                        Collecting colcon-argcomplete
                          Downloading colcon_argcomplete-0.3.3-py3-none-any.whl (6.9 kB)
                        Collecting colcon-output
                          Downloading colcon_output-0.2.13-py3-none-any.whl (14 kB)
                        Collecting colcon-metadata
                          Downloading colcon_metadata-0.2.5-py3-none-any.whl (19 kB)
                        Collecting colcon-recursive-crawl
                          Downloading colcon_recursive_crawl-0.2.3-py3-none-any.whl (8.3 kB)
                        Collecting colcon-test-result
                          Downloading colcon_test_result-0.3.8-py3-none-any.whl (8.5 kB)
                        Collecting colcon-zsh
                          Downloading colcon_zsh-0.5.0-py3-none-any.whl (10 kB)
                        Collecting colcon-cmake
                          Downloading colcon_cmake-0.2.28-py3-none-any.whl (26 kB)
                        Collecting colcon-bash
                          Downloading colcon_bash-0.5.0-py3-none-any.whl (11 kB)
                        Collecting colcon-defaults
                          Downloading colcon_defaults-0.2.8-py3-none-any.whl (10.0 kB)
                        Collecting pytest-rerunfailures
                          Downloading pytest_rerunfailures-10.3-py3-none-any.whl (11 kB)
                        Collecting pytest-cov
                          Downloading pytest_cov-4.0.0-py3-none-any.whl (21 kB)
                        Collecting EmPy<4
                          Downloading empy-3.3.4.tar.gz (62 kB)
                             |################################| 62 kB 11.9 MB/s
                          Preparing metadata (setup.py) ... done
                        Collecting pytest-repeat
                          Downloading pytest_repeat-0.9.1-py2.py3-none-any.whl (4.3 kB)
                        Collecting packaging
                          Downloading packaging-21.3-py3-none-any.whl (40 kB)
                             |################################| 40 kB 19.9 MB/s
                        Collecting importlib-metadata
                          Downloading importlib_metadata-4.8.3-py3-none-any.whl (17 kB)
                        Collecting distlib
                          Downloading distlib-0.3.8-py2.py3-none-any.whl (468 kB)
                             |################################| 468 kB 17.6 MB/s
                        Collecting pytest
                          Downloading pytest-7.0.1-py3-none-any.whl (296 kB)
                             |################################| 296 kB 9.9 MB/s
                        Collecting PyYAML
                          Downloading PyYAML-6.0.1-cp36-cp36m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (669 kB)
                             |################################| 669 kB 12.8 MB/s
                        Collecting notify2
                          Downloading notify2-0.3.1-py2.py3-none-any.whl (8.0 kB)
                        Collecting catkin-pkg>=0.4.14
                          Downloading catkin_pkg-1.0.0-py3-none-any.whl (75 kB)
                             |################################| 75 kB 16.1 MB/s
                        Collecting colcon-pkg-config
                          Downloading colcon_pkg_config-0.1.0-py3-none-any.whl (4.5 kB)
                        Collecting pyparsing
                          Downloading pyparsing-3.1.1-py3-none-any.whl (103 kB)
                             |################################| 103 kB 20.0 MB/s
                        Collecting docutils
                          Downloading docutils-0.18.1-py2.py3-none-any.whl (570 kB)
                             |################################| 570 kB 19.1 MB/s
                        Collecting python-dateutil
                          Downloading python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
                             |################################| 247 kB 18.1 MB/s
                        Collecting typing-extensions>=3.6.4
                          Downloading typing_extensions-4.1.1-py3-none-any.whl (26 kB)
                        Collecting zipp>=0.5
                          Downloading zipp-3.6.0-py3-none-any.whl (5.3 kB)
                        Collecting iniconfig
                          Downloading iniconfig-1.1.1-py2.py3-none-any.whl (5.0 kB)
                        Collecting py>=1.8.2
                          Downloading py-1.11.0-py2.py3-none-any.whl (98 kB)
                             |################################| 98 kB 20.8 MB/s
                        Collecting pluggy<2.0,>=0.12
                          Downloading pluggy-1.0.0-py2.py3-none-any.whl (13 kB)
                        Collecting attrs>=19.2.0
                          Downloading attrs-22.2.0-py3-none-any.whl (60 kB)
                             |################################| 60 kB 17.4 MB/s
                        Collecting tomli>=1.0.0
                          Downloading tomli-1.2.3-py3-none-any.whl (12 kB)
                        Collecting coverage[toml]>=5.2.1
                          Downloading coverage-6.2-cp36-cp36m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (204 kB)
                             |################################| 204 kB 16.8 MB/s
                        Building wheels for collected packages: EmPy
                          Building wheel for EmPy (setup.py) ... done
                          Created wheel for EmPy: filename=empy-3.3.4-py3-none-any.whl size=30432 sha256=7aaac4f46269440080b5fd1597ad075e270550f0906429e1e9fecd21b7b8c56f
                          Stored in directory: /tmp/pip-ephem-wheel-cache-aly7of64/wheels/db/22/d4/99f3395c08193a04ea67564f4f4f86b8d342a5538372227492
                        Successfully built EmPy
                        Installing collected packages: zipp, typing-extensions, pyparsing, importlib-metadata, tomli, py, pluggy, packaging, iniconfig, coverage, attrs, pytest, pytest-rerunfailures, pytest-repeat, pytest-cov, EmPy, distlib, colcon-core, python-dateutil, docutils, colcon-test-result, colcon-library-path, PyYAML, notify2, colcon-recursive-crawl, colcon-python-setup-py, colcon-pkg-config, colcon-package-information, colcon-cmake, catkin-pkg, colcon-zsh, colcon-ros, colcon-powershell, colcon-parallel-executor, colcon-package-selection, colcon-output, colcon-notification, colcon-metadata, colcon-devtools, colcon-defaults, colcon-cd, colcon-bash, colcon-argcomplete, lark, colcon-common-extensions
                        Successfully installed EmPy-3.3.4 PyYAML-6.0.1 attrs-22.2.0 catkin-pkg-1.0.0 colcon-argcomplete-0.3.3 colcon-bash-0.5.0 colcon-cd-0.1.1 colcon-cmake-0.2.28 colcon-common-extensions-0.3.0 colcon-core-0.15.2 colcon-defaults-0.2.8 colcon-devtools-0.2.5 colcon-library-path-0.2.1 colcon-metadata-0.2.5 colcon-notification-0.2.15 colcon-output-0.2.13 colcon-package-information-0.3.3 colcon-package-selection-0.2.10 colcon-parallel-executor-0.3.0 colcon-pkg-config-0.1.0 colcon-powershell-0.4.0 colcon-python-setup-py-0.2.8 colcon-recursive-crawl-0.2.3 colcon-ros-0.4.1 colcon-test-result-0.3.8 colcon-zsh-0.5.0 coverage-6.2 distlib-0.3.8 docutils-0.18.1 importlib-metadata-4.8.3 iniconfig-1.1.1 lark-1.1.9 notify2-0.3.1 packaging-21.3 pluggy-1.0.0 py-1.11.0 pyparsing-3.1.1 pytest-7.0.1 pytest-cov-4.0.0 pytest-repeat-0.9.1 pytest-rerunfailures-10.3 python-dateutil-2.8.2 tomli-1.2.3 typing-extensions-4.1.1 zipp-3.6.0
                        D 1 Reply Last reply 31 Jan 2024, 20:53 Reply Quote 0
                        • D
                          @Zachary-Lowell-0 Part 2 of the tee log
                          Finished <<< voxl_offboard_figure8 [3.55s]
                          Finished <<< voxl_msgs [40.9s]
                          Finished <<< camera_calibration_parsers [43.8s]
                          Finished <<< image_transport [1min 16s]
                          Finished <<< camera_info_manager [32.9s]
                          Finished <<< px4_msgs [24min 59s]
                          Finished <<< px4_ros_com [38.0s]
                                           from /home/root/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp:3@Darshit-Desai 6:
                          Finished <<< voxl_mpa_to_ros2 [40.3s]
                          Summary: 9 packages finished [26min 19s]
                          Done Building!
                          DONE
                          qrb5165-emulator:~(dev)(0.0.2)$ ./deploy_to_voxl.sh
                          searching for ADB device
                          checking VOXL for dpkg/opkg
                          dpkg detected
                          voxl-mpa-to-ros2_0.0.2_arm64.deb: 1 file pushed. 5.4 MB/s (13614708 bytes in 2.419s)
                          (Reading database ... 101749 files and directories currently installed.)
                          Preparing to unpack .../voxl-mpa-to-ros2_0.0.2_arm64.deb ...
                          Unpacking voxl-mpa-to-ros2 (0.0.2) over (0.0.2) ...
                          dpkg: voxl-mpa-to-ros2: dependency problems, but configuring anyway as you requested:
                           voxl-mpa-to-ros2 depends on voxl-microdds-agent; however:
                            Package voxl-microdds-agent is not installed.
                           voxl-mpa-to-ros2 depends on voxl-ros2-foxy; however:
                            Package voxl-ros2-foxy is not installed.
                          Setting up voxl-mpa-to-ros2 (0.0.2) ...
                          DONE
                          D 1 Reply Last reply 1 Feb 2024, 06:20 Reply Quote 0
                          • D
                            @Zachary-Lowell-0 I used this method this time using the dev branch (https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/master?ref_type=heads#build-instructions-if-running-directly-on-target-voxl2) after building and deploying using the emulator method, I also installed voxl-ros2-foxy voxl-microdds since the emulator build wasn't transferring that to voxl2 os. I know that this might be obsolete but this is the only one that is working
                            Here's the result from colcon building the package in colcon_ws of this repo https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2.git
                            It has worse publish rate and I checked my network wifi which had no load
                            swarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 topic hz /hires_small_grey
                            average rate: 2.077
                            	min: 0.341s max: 0.726s std dev: 0.17387s window: 3
                            average rate: 2.360
                            	min: 0.339s max: 0.726s std dev: 0.13672s window: 6
                            average rate: 2.474
                            	min: 0.339s max: 0.726s std dev: 0.11510s window: 9
                            average rate: 2.550
                            	min: 0.339s max: 0.726s std dev: 0.10185s window: 12
                            average rate: 2.165
                            	min: 0.339s max: 1.393s std dev: 0.27509s window: 14
                            average rate: 2.257
                            	min: 0.339s max: 1.393s std dev: 0.25294s window: 17
                            average rate: 2.322
                            	min: 0.339s max: 1.393s std dev: 0.23513s window: 20
                            average rate: 2.375
                            	min: 0.339s max: 1.393s std dev: 0.22066s window: 23
                            average rate: 2.322
                            	min: 0.339s max: 1.393s std dev: 0.21999s window: 25
                            average rate: 2.370
                            	min: 0.339s max: 1.393s std dev: 0.20941s window: 28
                            ^Cswarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 topic hz /hires_small_color
                            average rate: 1.369
                            	min: 0.701s max: 0.774s std dev: 0.03163s window: 3
                            average rate: 1.356
                            	min: 0.701s max: 0.774s std dev: 0.02594s window: 5
                            average rate: 1.030
                            	min: 0.701s max: 2.141s std dev: 0.52354s window: 6
                            average rate: 0.994
                            	min: 0.701s max: 2.141s std dev: 0.49773s window: 8
                            ^Cswarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 run hz /tof_pc
                            Package 'hz' not found
                            swarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 run topic hz /tof_pc
                            Package 'topic' not found
                            swarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 topic hz /tof_pc
                            average rate: 4.068
                            	min: 0.190s max: 0.409s std dev: 0.08262s window: 5
                            average rate: 3.965
                            	min: 0.190s max: 0.409s std dev: 0.08435s window: 9
                            average rate: 4.188
                            	min: 0.190s max: 0.409s std dev: 0.07035s window: 14
                            average rate: 3.739
                            	min: 0.180s max: 0.613s std dev: 0.11593s window: 18
                            average rate: 3.923
                            	min: 0.180s max: 0.613s std dev: 0.10555s window: 23
                            average rate: 4.037
                            	min: 0.180s max: 0.613s std dev: 0.09716s window: 28
                            average rate: 4.007
                            	min: 0.180s max: 0.613s std dev: 0.09788s window: 32
                            average rate: 3.972
                            	min: 0.180s max: 0.613s std dev: 0.09670s window: 36
                            ^Cswarm_researchers@swarm-Alienware-Aurora-R16:~$ ros2 topic echo /tof_pc
                            header:
                              stamp:
                                sec: 0
                                nanosec: 2784441627
                              frame_id: world
                            height: 1
                            width: 38528
                            fields:
                            - name: x
                              offset: 0
                              datatype: 7
                              count: 1
                            - name: y
                              offset: 4
                              datatype: 7
                              count: 1
                            - name: z
                              offset: 8
                              datatype: 7
                              count: 1
                            is_bigendian: false
                            point_step: 12
                            row_step: 462336
                            data:
                            - 0
                            - 0
                            Basically all zeroes
                            It also fails when I try to subscribe to hires_large topics
                            voxl2:~$ ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
                            Found new interface: hires_large_color
                            Found new interface: hires_large_encoded
                            Found new interface: hires_large_grey
                            Found new interface: hires_small_color
                            Found new interface: hires_small_encoded
                            Found new interface: hires_small_grey
                            Found new interface: hires_snapshot
                            Found new interface: qvio_overlay
                            Found new interface: tof_conf
                            Found new interface: tof_depth
                            Found new interface: tof_ir
                            Found new interface: tracking
                            Found new interface: imu_apps
                            Found new interface: tof_pc
                            Found new interface: voa_pc_out
                            Found new interface: vvhub_body_wrt_fixed
                            Found new interface: vvhub_body_wrt_local
                            Interface hires_small_grey now publishing
                            ERROR: invalid metadata, magic number=1347375700, expected 1448040524
                            most likely client fell behind and pipe overflowed
                            Interface hires_small_grey ceasing to publish
                            Interface tof_conf now publishing
                            Interface hires_small_color now publishing
                            Interface tof_conf ceasing to publish
                            Interface hires_small_color ceasing to publish
                            Interface tof_depth now publishing
                            Interface tof_depth ceasing to publish
                            Interface qvio_overlay now publishing
                            Interface qvio_overlay ceasing to publish
                            Interface tof_ir now publishing
                            Interface tof_ir ceasing to publish
                            ERROR: invalid metadata, magic number=-1701011557, expected 1448040524
                            Interface tof_pc now publishing
                            Interface tof_pc ceasing to publish
                            • Z
                              @Darshit-Desai I am a bit lost as to why having wifi would matter in this instance. When you run voxl-inspect-cam -a what is the output? Are all the cameras actively streaming at 30 FPS from camera server?
                              1 out of 13
