  3. ADB Device Offline
ADB Device Offline
10 Posts 5 Posters 2.9k Views 2 Watching
  • Jonathan EriksonJ Offline
    Jonathan Erikson
    I recently encountered an issue with the VOXL drone when trying to connect to it over a USB connection using adb. Everything had been working just fine and then one day, I booted the drone up to begin working on it and it told me that it couldn't connect because the device was "offline". I've tried unplugging the drone and using a different USB cable but nothing has fixed this issue yet. Here is a photo of the issue I'm facing:
    I've even tried to flash the system using the debug board, but get the same error that it can't because the device is "offline".
    I'm not really sure what to do at this point, any insight on how I might fix this issue would be great!
    Best,
    Jonathan Erikson
    • T Offline
      T Offline
      tb_temp2
      Hi @Jonathan-Erikson ,
      Seems like you are following the correct path, we've found that in some cases, we need to quickly turn the fastboot switch off after bootup.
      It's captured here towards the bottom: https://docs.modalai.com/unbrick-voxl/
      Note, you can ommit -f to try to preserve the data directory:
      Let us know how it goes, thanks!
        Jonathan Erikson
        I did attempt this as well and it still gives me the same error message that the device is "offline". After that, it gets stuck "Waiting for fastboot...", similar to the image above.
        • modaltbM Offline
          modaltbM Offline
          modaltb
          OK, one last idea is power, how is this being powered? I've had some issues with low battery causing ADB issues as the VOXL can brown out if it's not getting enough current on bootup (inrush up to 6A).
          Jonathan EriksonJ 1 Reply Last reply
          • modaltbM modaltb
            Jonathan Erikson
            @modaltb
            I took this idea and tried to boot the drone using a LiPo battery but am still having the same issue unfortunately. Originally, I was just using a standard 12V 3A wall plug, similar to the one available on the modalai website.
            • modaltbM Offline
              modaltbM Offline
              modaltb
              OK let's get an RMA going. I just sent out a google form that we use to collect data (address, shopify number, etc.). Let us see what we can figure out on our end and not waste anymore of your time.
              • ryan_meagherR Offline
                ryan_meagher
                This has happened to me before. I don't know what caused it but what fixed this for me was to run
                $adb kill-server
                $adb start-server
                $adb reconnect device
                modaltbM 1 Reply Last reply
                • ryan_meagherR ryan_meagher
                  $adb kill-server
                  $adb start-server
                  modaltbM Offline
                  modaltbM Offline
                  modaltb
                  @ryan_meagher Thanks for the feedback!
                  • G Offline
                    G Offline
                    Gaurav Borade
                    • G Offline
                      G Offline
                      Gaurav Borade
                      Hi, I am facing the same issue
                      Also, I don't have a USB Expander and Debug Add-On Board (https://docs.modalai.com/usb-expander-and-debug-manual/)
                      Is there any other way so we can Force VOXL into Fastboot Mode. (like any onboard button/ any other technic) please let me know.
