    How to check which version of sdk is running?
    FAQs
    • K
      Kyuhyong You
      I could not find command to check the version of sdk.
      Below is the info from sdb shell
      system-image: 1.6.2-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
      hw version:   M0054
      voxl-suite:
      current IP: eth0:
      T 1 Reply Last reply 20 Nov 2023, 18:42 Reply Quote 0
      • T
        tom admin @Kyuhyong You
        @Kyuhyong-You There might be some mismatching going on there. It looks like you have the system image from SDK 1.0.0.
        You can see more info with voxl-version
        K 1 Reply Last reply 20 Nov 2023, 23:53 Reply Quote 0
        • K
          Kyuhyong You @tom
          @tom I see.
          I updated flash with the latest sdk image and now I can see the version number.
          $ voxl-version
          system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
          kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
          hw version:   M0054
          voxl-suite:   1.1.0
          Packages:
          Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
          Last Updated: 2023-11-20 08:24:30
          List:
          	libmodal-cv                 0.4.0
          	libmodal-exposure           0.1.0
          	libmodal-journal            0.2.2
          	libmodal-json               0.4.3
          	libmodal-pipe               2.9.2
          	libqrb5165-io               0.4.2
          	libvoxl-cci-direct          0.2.1
          	libvoxl-cutils              0.1.1
          	mv-voxl                     0.1-r0
          	qrb5165-bind                0.1-r0
          	qrb5165-dfs-server          0.2.0
          	qrb5165-imu-server          1.0.0
          	qrb5165-rangefinder-server  0.0.4
          	qrb5165-slpi-test-sig       01-r0
          	qrb5165-system-tweaks       0.2.3
          	qrb5165-tflite              2.8.0-2
          	voxl-bind-spektrum          0.1.0
          	voxl-camera-calibration     0.5.1
          	voxl-camera-server          1.8.7
          	voxl-configurator           0.4.4
          	voxl-cpu-monitor            0.4.7
          	voxl-docker-support         1.3.0
          	voxl-elrs                   0.1.3
          	voxl-esc                    1.3.4
          	voxl-feature-tracker        0.3.2
          	voxl-flow-server            0.3.3
          	voxl-gphoto2-server         0.0.10
          	voxl-jpeg-turbo             2.1.3-5
          	voxl-lepton-server          1.2.0
          	voxl-libgphoto2             0.0.4
          	voxl-libuvc                 1.0.7
          	voxl-logger                 0.3.5
          	voxl-mavcam-manager         0.5.3
          	voxl-mavlink                0.1.1
          	voxl-mavlink-server         1.3.1
          	voxl-microdds-agent         2.4.1-0
          	voxl-modem                  1.0.8
          	voxl-mongoose               7.7.0-1
          	voxl-mpa-to-ros             0.3.7
          	voxl-mpa-to-ros2            0.0.1
          	voxl-mpa-tools              1.1.2
          	voxl-opencv                 4.5.5-2
          	voxl-portal                 0.6.2
          	voxl-px4                    1.14.0-2.0.55
          	voxl-px4-imu-server         0.1.2
          	voxl-px4-params             0.2.7
          	voxl-qvio-server            0.9.4
          	voxl-remote-id              0.0.9
          	voxl-streamer               0.7.4
          	voxl-suite                  1.1.0
          	voxl-tag-detector           0.0.4
          	voxl-tflite-server          0.3.1
          	voxl-utils                  1.3.3
          	voxl-uvc-server             0.1.6
          	voxl-vision-hub             1.7.1
          	voxl2-system-image          1.7.1-r0
          	voxl2-wlan                  1.0-r0
          I also tried to install ros2 as described in https://docs.modalai.com/ros2-installation-voxl2/
          by running ./installROS2.sh and I got following error while building the foonathan_memory.
          CMake Error at CMakeLists.txt:7 (cmake_minimum_required):
            CMake 3.11 or higher is required.  You are running version 3.10.2
          make[2]: *** [foo_mem-ext-prefix/src/foo_mem-ext-stamp/foo_mem-ext-configure] Error 1
          make[1]: *** [CMakeFiles/foo_mem-ext.dir/all] Error 2
          make: *** [all] Error 2
          Failed   <<< foonathan_memory_vendor [0.54s, exited with code 2]
          It looks like it requires to update Cmake.
          Do you have any suggestions?
          T 2 Replies Last reply 21 Nov 2023, 00:04 Reply Quote 0
          • T
            @Kyuhyong-You I believe those docs need some updating. You should be able get all the necessary packages installed via the following:
            apt install voxl-ros2-foxy
            apt install voxl-microdds-agent
            apt install voxl-mpa-to-ros2
            K 1 Reply Last reply 21 Nov 2023, 01:20 Reply Quote 0
            • T
              @Kyuhyong-You If you're still having issues it's easier to get our whole team's eyes on the issue if you open a brand new thread with the question
              • K
                Kyuhyong You @tom
                Wow I didn't know there is dedicated apt package to install ros-foxy and why the guide leads to install ros via script.
                Anyway thanks for the comment and I will try to install as you mentioned.
                1 out of 6
