  3. QVIO hard reset causing error with PX4 altitude for VIO
3 Posts 2 Posters 662 Views
  • Aaron PorterA Offline
    Aaron Porter
    I am having an issue with the QVIO service resetting periodically on my VOXL2. The I am not sure why this issue is occurring. I have the VOXL2 at a 90 degree roll which should explain the rpy_parent_to_child values. The Error can be seen when I run QVIO in the Voxl Terminal as seen below.
    voxl2:/$ voxl-qvio-server
    loading config file
    imu_name:                         imu_apps
    cam_name:                         tracking
    lens_cal_path:                    /data/modalai/opencv_tracking_intrinsics.yml
    cam_extrinsics_name:              tracking
    use_second_cam_if_stereo:         0
    odr_hz:                           30.000
    use_camera_height_bootstrap:      1
    camera_height_off_ground_m:        0.085
    enable_init_while_moving:         0
    cam_imu_timeshift_s:              -0.002
    cam_imu_timeshift_s_uncertainty:   0.001
    T_cam_wrt_imu_uncertainty:         0.001  0.001  0.001
    R_cam_to_imu_uncertainty:          0.005  0.005  0.005
    accl_fsr_ms2:                     156.000
    gyro_fsr_rad:                     34.000
    accl_noise_std_dev:                0.316
    gyro_noise_std_dev:                0.010
    cam_noise_std_dev:                100.000
    min_std_pixel_noise:               0.500
    fail_high_pixel_noise_points:      1.665
    limited_imu_bw_trigger:           25.000
    gps_imu_time_alignment_s:          0.000
    T_gps_wrt_imu:                     0.000  0.000  0.000
    enable_mapping:                   1
    enable_gps_vel:                   0
    auto-reset params:
    en_auto_reset:                    1
    auto_reset_max_velocity:          10.000
    auto_reset_max_v_cov_instant:      0.100
    auto_reset_max_v_cov:              0.010
    auto_reset_max_v_cov_timeout_s:    0.500
    auto_reset_min_features:          3
    auto_reset_min_feature_timeout_s:  1.000
    standby params:
    en_standby_mode:                  1
    standby_skip_frames:              1
    existing instance of qvio-server found, attempting to stop it
    setting scheduler
    INFO: set FIFO priority successfully!
    #0:
        parent:                imu_apps
        child:                 tracking
        T_child_wrt_parent:    0.063   0.022  -0.020
        RPY_parent_to_child:  45.0    90.0   180.0
        R_child_to_parent:    -0.000  -0.000   1.000
                              -0.707  -0.707  -0.000
                               0.707  -0.707   0.000
    tbc:   0.063  0.022 -0.020
    ombc:  2.504 -1.037  2.504 (axis angle)
    ombc: 45.000 90.000 180.000 (RPY deg)
    loading /data/modalai/opencv_tracking_intrinsics.yml
    using fisheye camera intrinsics:
    distortion: -0.018669 0.006158 0.000000 0.000000
    focal lengths: 286.505106 287.452901
    principle points: 318.695777 231.862595
    waiting for imu
    waiting for cam
    connected to imu server
    waiting for cpu_monitor
    connected to camera server
    Camera processing thread is now locked to the following cores: 7
    client "voxl-portal0" connected to overlay
    Client requested hard reset
    Thank you for your time,
    Aaron
      Aaron Porter
      So the issue seems to be that VOXL-vision-hub is requesting that QVIO be hard reset. I am not 100% sure why, the extrinsics file should be setup to a voxl that is rotated 90 degrees, VOXL-vision-hub however is asking tor a hard reset.
      A 1 Reply Last reply
      • Aaron PorterA Aaron Porter
        afdrus
        @Aaron-Porter I am facing the same issue, is it solved?
