    Mag Not Getting Detected on VOXL2 (sdk 1.0.0)
    • John Nomikos 0J
      John Nomikos 0
      Good afternoon,
      I've been having an issue where the mag is not being detected on the GPS + MAG module I have connected to a VOXL2.
      The GPS is a MATEK NEO-M9N and the mag is an IST8308.
      I tried changing the settings in voxl-px4.conf to HOLYBRO. That did not fix the problem.
      Whenever I am on QGC with SYS_HAS_MAG set to 1, it will give me the warning "Compass sensor 0 is missing". Attempts to calibrate the mag fail.
      Entering the command,
      gives this output:
      This gives the same output regardless if the gps module in voxl-px4.conf is set to HOLYBRO, MATEK or NONE
      Also checking the status of ist8310 gives this output:
      I've tried this with two separate GPS+MAG boards.
      This is the specific model:
      mRo GPS u-Blox Neo-M9N – IST8308
      https://mrobotics.io/docs/mro-gps-u-blox-neo-m9n-ist8308-ultra-robust/
        Eric Katzfey ModalAI Team @John Nomikos 0
        @John-Nomikos-0 Yes, the ist8310 magnetometer driver does not work with the ist8308 magnetometer. The ist8308 magnetometer driver needs to be added to the build and started instead of the ist8310 driver. The newest px4 release has the ist8308 magnetometer driver built in so it's just a matter of switching to that and then modifying the start line in voxl-px4-start to specify ist8308 instead of ist8310. The newest release is here: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/voxl-px4_1.14.0-2.0.43_arm64.deb
        John Nomikos 0J 2 Replies Last reply Reply Quote 1
        • John Nomikos 0J
          John Nomikos 0 @Eric Katzfey
          @Eric-Katzfey Thank you so much for the help! Going to do that right now
          • John Nomikos 0J
            @Eric-Katzfey I did what you suggested and it works! Thank you again!
