    VOXL 2 not responding to ADB, not going to Fastboot, not showing up in lsusb
    • Jyotish KumarJ
      Jyotish Kumar
      Hello, Greetings for the day.
      My VOXL 2, which was earlier accessible through ssh. Didn't connect to network after reboot this time.
      Upon inspection, the device is not appearing in ADB Devices either.
      Trying to put the device into Fastboot mode is not successful either. When holding the SW1 for extended time, every 15 seconds the led blinks twice, but the device is never put into fastboot mode.
      All indicator LEDs on the voxl indicate a normal boot, picture of the current state of LEDs is attached below:
      Output of lsusb doesn't recognize voxl as connected, the output is attached for reference:
      kyouma@Amadeus:~$ lsusb
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 003: ID 0408:5365 Quanta Computer, Inc. HP TrueVision HD Camera
      Bus 003 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 001 Device 003: ID 0bda:2852 Realtek Semiconductor Corp. Bluetooth Radio
      When trying to put the board in QDL mode it does get recognized in the system as follows:
      Bus 002 Device 004: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
      I have followed the VOXL 2 QDL Flashing guide and the process ends as expected with the last few lines of the output being as follows:
      <data>
      <log value="INFO: Calling handler for patch" /></data>
      LOG: INFO: Calling handler for patch
      <data>
      <data><setbootablestoragedrive value="1"/></data>
      <data>
      <log value="INFO: Calling handler for setbootablestoragedrive" /></data>
      LOG: INFO: Calling handler for setbootablestoragedrive
      <data>
      <log value="INFO: Using scheme of value= 1" /></data>
      LOG: INFO: Using scheme of value= 1
      <data>
      partition 1 is now bootable
      <data>
      <data>
      After powering it down, and switching the SW2 back to off position, and connecting power and USB, nothing has changed. I am unable to see the device in adb devices or in fastboot devices and it is not showing up in ```
      lsusb
      Kindly help me debug this issue. The Voxl 2 is being powered by the supplied power module 2. I have tried other similar power modules and usb cables too with no success.
      Thank you,
      Yours sincerely,
      Jyothish Kumar J.
        tom admin @Jyotish Kumar
        @Jyotish-Kumar After QDL you may have to use the fastboot button to force it into fastboot:
        press and hold button
        connect power
        connect usb
        continue holding button for 5 seconds
        release button
        device should now be in fastboot
        Jyotish KumarJ 1 Reply Last reply Reply Quote 0
        • Jyotish KumarJ
          Jyotish Kumar @tom
          @tom Hi Tom, Thank you for your reply.
          No luck. I have tried to put it into fastboot mode as advised by you, still computer is not detecting any new usb devices. fastboot devices still shows nothing. same with ```
          adb devices
            @Jyotish-Kumar I would try another USB-C cable if possible. We've seen issues with USB-C to USB-C cables in the past (not sure if that's what you're using or not)
            • Jyotish KumarJ
              Jyotish Kumar @tom
              @tom The usb cables I am using are good quality Type C to Type A cables.
              I have tried changing the USB cable to another one. I have also tried using another Power module. Currently my Voxl doesn't have any addon boards connected to it. Just the Voxl2, Power module and USB cable.
              Thank you for your reply. Could something else be wrong here?
              Yours sincerely,
              Jyothish.
                @Jyotish-Kumar There could've been an ESD issue induced by not having the board on an ESD mat or not using proper ESD protection, check out https://www.modalai.com/pages/rma
