  3. Using Qualcomm's camera subsystem on VOXL2
15 Posts 4 Posters 2.7k Views 2 Watching
  • P Offline
    P Offline
    paynej
    I've been working on another RB5 platform and am migrating to VOXL. I used a command similar to above:
    GST_DEBUG=3 gst-launch-1.0 -e qtiqmmfsrc camera=0 name=tracker ! video/x-h264,format=NV12,width=640,height=480,framerate=30/1 ! queue ! h264parse ! avdec_h264 ! videoconvert ! pngenc ! multifilesink enable-last-sample=false location="/data/misc/camera/cam0_img_%d_.png"
    I get images, yet they are greyscale instead of color. Any help would be great!
    Jeff
      Which camera config are you using? https://docs.modalai.com/voxl2-camera-configs/
      Are you sure it's not a monochrome image sensor you are using?
      • P Offline
        P Offline
        paynej
        wrote on last edited by paynej
        Should be hires and tracking only. I'm trying to use the color hires one. I noticed when using the voxl-streamer, that the tracking one is probably monochrome.
        An older /etc/modalai/voxl-camera-server.conf.save shows all 4 cameras, tracking, hires and stereo.
        Thanks for your reply. I hope to have this figured out soon.
        • P Offline
          P Offline
          paynej
          C11. I'm trying to use the color hires one. I noticed when using the voxl-streamer, that the tracking ones and stereo is monochrome.
          So now
          GST_DEBUG=3 gst-launch-1.0 -e qtiqmmfsrc camera=3 ! video/x-raw,format=NV12,width=640,height=480,framerate=2/1 ! queue  ! videoconvert ! jpegenc ! multifilesink enable-last-sample=false location="/data/misc/camera/cam0_img_%d_.jpg"
          is giving me no image.
          All other cameras (0,1,2,4,5) are working correctly with B/W
          If I enable voxl-camera-server and voxl-streamer-hires, then I get a RTSP color stream, so the HW seems good.
          • P Offline
            P Offline
            paynej
            I think I have the snapshot hires color working!  I was grabbing the first picture instead of the last.  The first one, the sensor must not be ready.
            • P Offline
              P Offline
              paynej
              Back again... 🙂
              I have my ML program running now with the qtiqmmfscrc pipeline and disabling voxl-camera-server. I'd like to run voxl-camera-server with just the tracking and stereo cameras so voxl-qvio-server will get data. I tried to remove just the hires camera from /etc/modalai/voxl-camera-server.conf but running voxl-camera-server aborts:
              rb5:/$ /usr/bin/voxl-camera-server -d 0
              No secondary id found for camera: tracking, assuming mono
              Secondary id found for camera: stereo_front, assuming stereo
              Secondary id found for camera: stereo_rear, assuming stereo
              ------ voxl-camera-server: Starting camera server
              Attempting to open the hal module
              SUCCESS: Camera module opened on attempt 0
              Aborted
              rb5:/$ more /etc/modalai/voxl-camera-server.conf
              	"version":	0.1,
              	"cameras":	[{
              			"name":	"tracking",
              			"enabled":	true,
              			"frame_rate":	30,
              			"type":	"ov7251",
              			"camera_id":	2,
              			"ae_desired_msv":	60,
              			"ae_filter_alpha":	0.600000023841858,
              			"ae_ignore_fraction":	0.20000000298023224,
              			"ae_slope":	0.05000000074505806,
              			"ae_exposure_period":	1,
              			"ae_gain_period":	1
              			"name":	"stereo_front",
              			"enabled":	true,
              			"frame_rate":	30,
              			"type":	"ov7251",
              			"camera_id":	0,
              			"camera_id_second":	1,
              			"ae_gain_period":	1
              			"name":	"stereo_rear",
              			"enabled":	true,
              			"frame_rate":	30,
              			"type":	"ov7251",
              			"camera_id":	5,
              			"camera_id_second":	4,
              			"ae_gain_period":	1
              Any advice? Thank you for your time.
                The Qualcomm HAL3 camera framework only allows one application to connect, which is why we created voxl-camera-server. What you want to do is not possible due to this limitation from Qualcomm
                • P Offline
                  P Offline
                  paynej
                  #13
                  Thank you for the reply. That makes sense.
                  What are the available outputs of voxl-camera-server? It looks like voxl-qvio-server uses a pipe. Wondering if I have another option to qtiqmmfscrc, rtsp and udp.
                  Thanks you, I appreciate you taking the time to reply.
                    that is documented here: https://docs.modalai.com/voxl-camera-server/#output-of-camera-server
                    • P Offline
                      P Offline
                      paynej
                      The Pipe API worked great! Thanks.
                      Can the hires camera output RBG instead of NV12 and can voxl-camera-server support that?
