Sarah McMahonS
Sarah McMahon
@Sarah McMahon
  • Unable to Generate the Mavsdk Docker on a M500
    Sarah McMahonS Sarah McMahon
    @Zachary-Lowell-0 I encountered an issue with the threading during the download process, which caused it to take about 9 hours. The main problem arose when running deploy-to-voxl.sh—the drone ran out of storage after pushing the tar file, preventing the image from being loaded into Docker. While attempting to free up space, I mistakenly ran the wrong opkg command and deleted all opkg packages, making it impossible to SSH or ADB into the drone. Do you have any suggestions for a potential fix? I noticed the USB Expander and Debug Add-On Board might be helpful, but I couldn't find it available for purchase on the website.
    I’ve recently started working with the Modal AI M500 drone and am encountering issues while trying to build Docker images on the drone. Specifically, I am having trouble with both the Mavsdk and Mavsdk-Python images.
    Issue 1: Pulling Docker Image
    When attempting to pull the Python Docker image (modalai-public/voxl-mavsdk-python), I receive the following error:
    Error: Status 405 trying to pull repository modalai-public/voxl-mavsdk-python: "v1 Registry API is disabled. If you are not explicitly using the v1 Registry API, it is possible your v2 image could not be found. Verify that your image is available, or retry with dockerd --disable-legacy-registry. See https://cloud.google.com/container-registry/docs/support/deprecation-notices"
    Issue 2: Building Docker Image on Drone
    I also tried building the Docker image directly on my computer while connected to the drone via ADB, but encountered this error:
    Image: voxl-mavsdk-python:v1.1
    Waiting for device...
    Checking for docker support...
    -> Docker support not detected, running docker support on target...
    /bin/sh: voxl-configure-docker-support.sh: not found
    Building image: voxl-mavsdk-python:v1.1
    Dockerfile: 1 file pushed. 0.3 MB/s (802 bytes in 0.002s)
    takeoff_and_land2.py: 1 file pushed. 0.4 MB/s (941 bytes in 0.002s)
    offboard_position_ned2.py: 1 file pushed. 0.8 MB/s (2227 bytes in 0.003s)
    start-mavsdk-server.sh: 1 file pushed. 0.0 MB/s (109 bytes in 0.007s)
    Sending build context to Docker daemon 8.192 kB
    Step 1 : FROM ubuntu:bionic
    Pulling repository docker.io/library/ubuntu
    Error: Status 410 trying to pull repository library/ubuntu: "<html>\r\n<head><title>410 Gone</title></head>\r\n<body>\r\n<center><h1>410 Gone</h1></center>\r\n<hr><center>openresty</center>\r\n</body>\r\n</html>\r\n"
    Additional Information
    Docker Version: 1.9.0 on the VOXL
    Drone Firmware Version: - I just updated it to the newest SDK version 1.2.
    Could someone please assist me with these issues? Any guidance or suggestions would be greatly appreciated.
    Thank you!
    Development Drones m500
    Error: Status 405 trying to pull repository modalai-public/voxl-mavsdk-python: "v1 Registry API is disabled. If you are not explicitly using the v1 Registry API, it is possible your v2 image could not be found. Verify that your image is available, or retry with `dockerd --disable-legacy-registry`. See https://cloud.google.com/container-registry/docs/support/deprecation-notices"
    Step 1 : FROM ubuntu:22.04
    • Docker Version: 1.9.0 on the VOXL
    • Drone Firmware Version: - I just updated it to the newest SDK version 1.2.
    Thank you!
  • docker pull returns 410 Gone
    Did you find a solution I have just run into the same error?
  • Connect station mode
    Hi, were you able to find a solution I ran into the same problem.
    FAQs
