Samuel BryanS
Samuel Bryan
@Samuel Bryan
  • Connecting to Q Ground Control in Station Mode
    Samuel BryanS Samuel Bryan
    How do I connect to Q Ground Control when the M500 is in Station Wifi Mode? I have the primary ground control IP address set to my laptop, which connected to the network the M500 is connected to.
    Development Drones m500
  • Tracking Camera Stream
    What is the best way to stream the tracking camera? I need to stream it through an rtsp python script. I tried changing voxl-streamer.conf and voxl-mavcam-manager.conf to stream the camera, those didn't work. I ran the command voxl-streamer -i tracking, and it connected to my script, it connected to the camera, then disconnected (this script worked fine with the hires camera).
  • Pictures from Stereo Camera
    @Alex-Kushleyev Thanks for the reply. We tried this on our voxl1, but it didn't work. We get an error saying "Invalid option -- "d"". Is there a way to get this working on voxl1 on the m500?
    I want to take pictures from the stereo cameras. Is there a way to do this through voxl-send-command or any other terminal command?
  • Voxl Docker Mavsdk Python
    @tom I thought it was, it appears it isn't. How do I connect it to the internet?
    I was trying to build the python mavsdk voxl docker image for my Modal M500 on a voxl one with Voxl SDK 1.2.0 installed https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python However when I run build.sh, I get the following error:
    ./build-image.sh
    Image: voxl-mavsdk-python:v1.1
    Waiting for device...
    Checking for docker support...
    -> Docker support not detected, running docker support on target...
    /bin/sh: voxl-configure-docker-support.sh: not found
    Building image: voxl-mavsdk-python:v1.1
    Dockerfile: 1 file pushed. 0.3 MB/s (811 bytes in 0.002s)
    takeoff_and_land2.py: 1 file pushed. 0.4 MB/s (941 bytes in 0.002s)
    offboard_position_ned2.py: 1 file pushed. 1.8 MB/s (2227 bytes in 0.001s)
    start-mavsdk-server.sh: 1 file pushed. 0.1 MB/s (109 bytes in 0.001s)
    Sending build context to Docker daemon 8.192 kB
    Step 1 : FROM arm64v8/ubuntu:bionic
    Pulling repository docker.io/arm64v8/ubuntu
    Error while pulling image: Get https://index.docker.io/v1/repositories/arm64v8/ubuntu/images: dial tcp: lookup index.docker.io on 8.8.8.8:53: dial udp 8.8.8.8:53: connect: network is unreachable
    The drone is connected to the computer via USB and I have a connection via adb shell. Anyone know how to fix this?
  • Cant Connect to Q Ground Control after SDK Update
    @Eric-Katzfey I am using SoftAP mode in Wifi.
    I recently updated the Voxl SDK on my Modal M500 from 0.9.5 to 1.2.0, and now the aircraft won't connect to Q Ground Control. When I open Q Ground Control, it says disconnected. The aircraft still connects to my laptop via wifi and I can SSH into the aircraft from a terminal.
  • Modal M500 Voxl Streamer
    @Eric-Katzfey Do you have a list of voxl-send-command commands, or is it listed in the documentation somewhere?
    I was able to get the SDK upgraded to Voxl 1.2.0. However now it won't communicate with Q Ground Control. When I open it, it shows that it is disconnected despite there being a wifi connection between between the laptop and the M500. It connects to the laptop fine and I can SSH into the aircraft. Is there a setting somewhere on the aircraft that I have to change for it to connect with QGC again?
  • Voxl Docker Python
    I am trying to get the voxl-docker python script from this page: https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python
    But when I try to run the pull command, I get this error:
    docker pull gcr.io/modalai-public/voxl-mavsdk-python:v1.1
    Error response from daemon: unable to ping registry endpoint
    https://gcr.io/v0/
    v2 ping attempt failed with error: Get
    https://gcr.io/v2/:
    dial tcp: lookup gcr.io on 8.8.8.8:53: dial udp 8.8.8.8:53: connect: network is unreachable
    v1 ping attempt failed with error: Get
    https://gcr.io/v1/_ping:
    I am running this on a Modal M500 with Voxl 1 and Docker is installed and setup. What would be causing this error?
  • VOXL Web Portal
    Is there anyway to modify the VOXL Web Portal?
    @Eric-Katzfey I tried update it with the latest SDK but it says it is out of space. I have a Windows machine, are there instructions for installing the latest SDK onto the Modal M500?
    @Eric-Katzfey I tried that command, but I got the error "Unable to find valid pipe that accepts control commands at: hires_snapshot". I am using voxl-suite 0.9.4, with system image 4.0.0.
    I need to take screenshots off the hires camera feed from the M500 every quarter second and save the screenshots to my computer. Is there a way to modify the voxl streamer script or another script on board the aircraft to do this?
