Ruijie GengR
Ruijie Geng
@Ruijie Geng
  • Stream the video data via WIFI
    Ruijie GengR Ruijie Geng
    May I ask can we stream the video data via WIFI and let others view the stream through the internet?
  • Example to stream video via ffmpeg
    Hello, I can use FFmpeg to stream the data from /opt/frame0. And I can view something on my laptop. But the stream is something with green background. Do you meet a similar issue before?
    Does something wrong with my camera or the type of visual stream is not correct?
    VOXL SDK and Software
    Sorry for the late reply. I try the code again, the bug is gone. I can open /dev/frame0 correctly.
    Thank you very much
    I meet another question that I try to run hello_hal3_camera -l /dev/frame0 before starting docker, but gives the error
    ~ # hello_hal3_camera -l /dev/frame0
    Camera id: 0
    Image width: 640
    Image height: 480
    Number of frames to dump: 0
    Frame FIFO: /dev/frame0
    Camera mode: preview
    SUCCESS: Camera module opened
    Camera Id: 0 Facing: 0
    Camera Id: 1 Facing: 1
    Error: Could not open named FIFO /dev/frame0
    Camera Id: 2 Facing: 1
    Camera HAL3 test is now running
    Thank you! I will have a trial to do that!
    In this documentation(https://docs.modalai.com/docker-on-voxl/#access-to-mipi-cameras), last part, I get this code
    ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 <output options>
    I already set up the docker with roskinetic-xenial_v1_0. Would you like to give an example to use FFmpeg? I want to stream the visual data and view such data on my laptop.
    I tried to save the video locally. but the system give me error
    ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 output.mov
    /opt/frame0: Is a directory
    Thank you!
