Roy WoodR
Roy Wood
@Roy Wood
  • Does the Microhard Modem Add-on with USB Hub expose a viable UART to connect an External Flight Controller to VOXL 2?
    Roy WoodR Roy Wood
    @Vinny, great! Thanks!
  • TBS Crossfire on VOXL 2 IO
    Roy WoodR Roy Wood
    Does PX4 expect the radio link to come from the VOXL 2 IO expansion board or can the radio link be connected through a different connector, like "E" in the included diagram?
    VOXL 2 and VOXL 2 Mini voxl-2-io
    Roy WoodR Roy Wood
    The VOXL 2 is compatible with TBS Crossfire radio receivers through the UART on J19 connector; however, the UART is needed to connect to VOXL 2 IO expansion board. The VOXL 2 IO expansion board has a dedicated connector for Spektrum receivers. In the VOXL 2 documentation, both Spektrum and TBS Crossfire are connected to the UART on J19 connector. Does this imply that the dedicated connector for Spektrum receiver on the VOXL 2 IO expansion board can be used to connect to TBS Crossfire radio receivers?
    (VOXL 2 IO expansion board is necessary to connector to 6 external ESC's)
    Roy WoodR Roy Wood
    @Vinny, I am just planning at the moment. Where can I find an exposed 1.8V pin on the VOXL Microhard Modem Add-on with USB Hub?
    Roy WoodR Roy Wood
    @Vinny,
    Thank you for your response. I am interested in the HW option and soldering to the TP29/TP28 pads. Just to verify, those pads do exist on the most recent iteration of the VOXL Microhard Modem Add-on with USB Hub. On the item page, the image does not show TP29/TP28 pads (nor TP41/TP40, for that matter); however, on the Microhard Modem Add-on datasheet they are included. See attached.
    Item Page:
    Datasheet:
    Roy WoodR Roy Wood
    Reading the documentation, the connection to an external flight controller requires the VOXL 2 USB3.0 / UART Expansion Adapter; however, the connection between the VOXL 2 USB3.0 / UART Expansion Adapter and the VOXL 2 utilizes the same connector that would be used for Microhard Modem Add-on with USB Hub.
    Does the Microhard Modem Add-on with USB Hub expose a viable UART to connect an External Flight Controller to VOXL 2? Or is there another UART?
    The external flight controller is Pixhawk 2.1/Cube Orange+.
