Paul HandriganP
Paul Handrigan
@Paul Handrigan
  • MCP2515 CAN device on VOXL2 J10 SPI + gpio
    Paul HandriganP Paul Handrigan
    I have added a MCP2515 CAN controller to the SPI bus on J10 using GPIO_46/CS1 as the interrupt gpio pin. I have added the in tree driver into the kernel. I have requested gpio 46 as the interrupt pin, but it is not taking effect. However, when it does request the gpio, you can see contention on the pin.
    What do I need to do in order to configure GPIO_46 as an input gpio to use as an interrupt for this device? Below is the DT node that I am using.
    +&qupv3_se14_spi {
    •   status = "ok";
    •   can_spi: can@0 {
    •           compatible = "microchip,mcp2515";
    •           reg = <0>;
    •           interrupt-parent = <&tlmm>;
    •           interrupts = <46 0x8>;
    •           clocks = <&clk12M>;
    •           spi-max-frequency = <8000000>;
    Thanks in advance!
    Paul
