  3. MCP2515 CAN device on VOXL2 J10 SPI + gpio
2 Posts 2 Posters 475 Views 1 Watching
  • Paul HandriganP Offline
    Paul Handrigan
    I have added a MCP2515 CAN controller to the SPI bus on J10 using GPIO_46/CS1 as the interrupt gpio pin. I have added the in tree driver into the kernel. I have requested gpio 46 as the interrupt pin, but it is not taking effect. However, when it does request the gpio, you can see contention on the pin.
    What do I need to do in order to configure GPIO_46 as an input gpio to use as an interrupt for this device? Below is the DT node that I am using.
    +&qupv3_se14_spi {
    •   status = "ok";
    •   can_spi: can@0 {
    •           compatible = "microchip,mcp2515";
    •           reg = <0>;
    •           interrupt-parent = <&tlmm>;
    •           interrupts = <46 0x8>;
    •           clocks = <&clk12M>;
    •           spi-max-frequency = <8000000>;
    Thanks in advance!
    Paul
    • Paul HandriganP Paul Handrigan
      +&qupv3_se14_spi {
      •   status = "ok";
      •   can_spi: can@0 {
      •           reg = <0>;
      Thanks in advance!
      Paul
      @Paul-Handrigan , please see this post, depending on which board you have (M0054 or M0154), it may not be possible to use GPIO 46 as input :
      https://forum.modalai.com/topic/4200/issue-reading-gpio-1146-pin-6-on-j10-on-voxl2
