<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MCP2515 CAN device on VOXL2 J10 SPI + gpio]]></title><description><![CDATA[<p dir="auto">I have added a MCP2515 CAN controller to the SPI bus on J10 using GPIO_46/CS1 as the interrupt gpio pin.  I have added the in tree driver into the kernel.  I have requested gpio 46 as the interrupt pin, but it is not taking effect.  However, when it does request the gpio, you can see contention on the pin.</p>
<p dir="auto">What do I need to do in order to configure GPIO_46 as an input gpio to use as an interrupt for this device?  Below is the DT node that I am using.</p>
<p dir="auto">+&amp;qupv3_se14_spi {</p>
<ul>
<li>
<pre><code>  status = "ok";
</li>
<li>
<pre><code>  can_spi: can@0 {
</li>
<li>
<pre><code>          compatible = "microchip,mcp2515";
</li>
<li>
<pre><code>          reg = &lt;0&gt;;
</li>
<li>
<pre><code>          interrupt-parent = &lt;&amp;tlmm&gt;;
</li>
<li>
<pre><code>          interrupts = &lt;46 0x8&gt;;
</li>
<li>
<pre><code>          clocks = &lt;&amp;clk12M&gt;;
</li>
<li>
<pre><code>          spi-max-frequency = &lt;8000000&gt;;
</li>
<li>
<pre><code>  };
</li>
</ul>
<p dir="auto">+};</p>
<p dir="auto">Thanks in advance!<br />
Paul</p>
]]></description><link>https://forum.modalai.com/topic/4238/mcp2515-can-device-on-voxl2-j10-spi-gpio</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 21:40:17 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4238.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Mar 2025 16:45:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MCP2515 CAN device on VOXL2 J10 SPI + gpio on Fri, 07 Mar 2025 17:13:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul-handrigan" aria-label="Profile: Paul-Handrigan">@<bdi>Paul-Handrigan</bdi></a> , please see this post, depending on which board you have (M0054 or M0154), it may not be possible to use GPIO 46 as input :</p>
<p dir="auto"><a href="https://forum.modalai.com/topic/4200/issue-reading-gpio-1146-pin-6-on-j10-on-voxl2">https://forum.modalai.com/topic/4200/issue-reading-gpio-1146-pin-6-on-j10-on-voxl2</a></p>
]]></description><link>https://forum.modalai.com/post/21285</link><guid isPermaLink="true">https://forum.modalai.com/post/21285</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Fri, 07 Mar 2025 17:13:30 GMT</pubDate></item></channel></rss>
