N
noda-wills
@noda-wills
  • ESC Calibration and Potential Motor Failure
    N noda-wills
    @Alex-Kushleyev
    Thanks for the advice! Sorry for the delay in following up. Dan and I are on the same team and I currently have the physical drone in my possession.
    I've attached a video of what the motor spinning actually looks and sounds like. The motor you see is actually a replacement, and the behavior is the same. It appears we may actually have an ESC issue or an issue at the connection point between the motor wires and ESC.
    The video shown is the result of running:
    voxl2:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-spin.py --id 1 --power 15
    Modal AI Starling 2 Max - Motor Spin Test Video
    When running the voxl-esc-verify-params.py script, the output shows that params are all matching:
    voxl2:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-verify-params.py
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.9
    VOXL Platform: M0054
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
    INFO: Params from ID 0 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
    INFO: Params from ID 1 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
    INFO: Params from ID 2 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
    INFO: Params from ID 3 match ../voxl-esc-params/D0012_Starling_MAX/esc_params_m0129_f2203_5_1500kv_7x3.7x3.xml
    INFO: Success! Params in all ESCs are valid and identical.
    Any thoughts on next steps here?
    ESCs, Sensors and Accessories power-module
