Karteek GandiboyinaK
Karteek Gandiboyina
@Karteek Gandiboyina
  • Ublox zed f9p GPS not connecting
    Karteek GandiboyinaK Karteek Gandiboyina
    @emarcphera @Eric-Katzfey thank you so much after upgrading to voxl-mainline im getting GPS readingScreenshot from 2026-02-28 01-45-10.png
    VOXL SDK and Software
    @Eric-Katzfey
    if [ "$GPS" != "NONE" ]; then
            # On M0052 the GPS driver runs on the apps processor
            if [ $PLATFORM = "M0052" ]; then
                gps start -d /dev/ttyHS2
            # On M0054 and M0104 the GPS driver runs on SLPI DSP
            else
                qshell gps start -d 6
            fi
    fi
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [logger] logger started (mode=all)
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] Got ack to initial CFG_VALSET!
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Accel
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Attitu
    Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Compas
    Its the same even without the baudrate. I will try the PX4-mainline option.
    I used this "https://forum.modalai.com/topic/3257/voxl2-gps-taking-long-time-to-connect-sometimes-never-connects" but it did not help. @Alex-Kushleyev @Eric-Katzfey
    HI,
    Im trying to connect ublox zed f9p 15b(https://www.u-blox.com/en/product/zed-f9p-module). im using voxl2 dev kit.
    i connected the gps to j19 pin (uart at pin 2,3) there seems to be no issue with the connection. but im not getting any gps message published
    tarling-px4-dev-kit (D0011):/$ journalctl -b -u voxl-px4
    -- Logs begin at Mon 2025-11-17 07:25:30 UTC, end at Thu 2026-02-26 20:09:53 UTC. --
    Feb 23 22:58:05 m0054 systemd[1]: Starting px4...
    Feb 23 22:58:07 m0054 systemd[1]: Started px4.
    Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Reading from /etc/modalai/voxl-px4.conf
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Found DSP signature file
    Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Daemon mode enabled
    Feb 23 22:58:07 m0054 voxl-px4[2203]: *************************
    Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRFRAME=MULTICOPTER
    Feb 23 22:58:07 m0054 voxl-px4[2203]: GPS=AUTODETECT
    Feb 23 22:58:07 m0054 voxl-px4[2203]: RC=SPEKTRUM
    Feb 23 22:58:07 m0054 voxl-px4[2203]: ESC=VOXL_ESC
    Feb 23 22:58:07 m0054 voxl-px4[2203]: POWER MANAGER=VOXLPM
    Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRSPEED SENSOR=NONE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: DISTANCE SENSOR=NONE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: OSD=DISABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: DAEMON_MODE=ENABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: SENSOR_CAL=ACTUAL
    Feb 23 22:58:07 m0054 voxl-px4[2203]: ARTIFACT_MODE=DISABLE
    Feb 23 22:58:07 m0054 voxl-px4[2203]: EXTRA STEPS:
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] mlockall() enabled. PX4's virtual address space is lock
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] assuming working directory is rootfs, no symlinks neede
    Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [muorb] Got muorb init command
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Sending initialization request
    Feb 23 22:58:07 m0054 voxl-px4[2203]: Got topic data before configuration complete
    Feb 23 22:58:08 m0054 voxl-px4[2203]: *************************
    Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRFRAME: MULTICOPTER
    Feb 23 22:58:08 m0054 voxl-px4[2203]: GPS: AUTODETECT
    Feb 23 22:58:08 m0054 voxl-px4[2203]: RC: SPEKTRUM
    Feb 23 22:58:08 m0054 voxl-px4[2203]: ESC: VOXL_ESC
    Feb 23 22:58:08 m0054 voxl-px4[2203]: POWER MANAGER: VOXLPM
    Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRSPEED SENSOR: NONE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: DISTANCE SENSOR: NONE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: OSD: DISABLE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: ARTIFACT_MODE: DISABLE
    Feb 23 22:58:08 m0054 voxl-px4[2203]: EXTRA STEPS:
    Feb 23 22:58:08 m0054 voxl-px4[2203]: Running on M0054
    Feb 23 22:58:09 m0054 voxl-px4[2203]: INFO  [param] selected parameter default file /data/px4/param/param
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] BSON document size 2241 bytes, decoded 2241 byte
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Starting IMU driver with no rotation
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icm42688p start -s'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13807556, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13847307, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread runnin
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb protobuf initalize method succeeded
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread test_MUORB
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb test passed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ______  __   __    ___
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | ___ \ \ \ / /   /   |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | |_/ /  \ V /   / /| |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: |  __/   /   \  / /_| |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: | |     / /^\ \ \___  |
    Feb 23 22:58:10 m0054 voxl-px4[2203]: \_|     \/   \/     |_/
    Feb 23 22:58:10 m0054 voxl-px4[2203]: px4 starting.
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic log_message
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] Starting param sync THREAD
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [parameters] Starting param sync THREAD
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] before starting the qshell_entry task
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread qshell
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell entry.....
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] after starting the qshell_entry task
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Init app map initialized
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_requ
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic parameter_update
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request)
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_r
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icm42688p'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-s'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] ICM42688P::probe successful!
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] on SPI bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icm42688p #0 on SPI bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] >>> ICM42688P this: b26012d8
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic qshell_retval
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic imu_server
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icp101xx'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-I'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '5'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icp101xx #0 on I2C bus 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb]  address 0x63
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceINFO  [qshell] Send cmd: 'temper
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13882130, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for qmc5883l magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] cmd returned with: -1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13922352, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [qshell] Command failed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8310 magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13958469, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8308 magnetometer
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13998516, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'gps start -d 6 -b 115200'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 14028093, local time:
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ncp5623c RGB LED
    Feb 23 22:58:10 m0054 voxl-px4[2203]: Node(qshell_req) as advertised in process_remote_topic
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: temperature_compensation star
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_correction
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: temperature_compensati
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-R'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '10'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-X'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg6 = '1'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [drivers__device] i2c probe failed
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8310'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8308'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '12'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
    Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: gps start -d 6 -b 115200
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'gps'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-d'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '6'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-b'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '115200'
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread gps
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with ti
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: gps start -d 6 -b 1152
    Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: land_detector start mu
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_land_detected
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: manual_control start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'manual_control'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: manual_control start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic manual_control_setpoint
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: control_allocator start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'control_allocator'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic control_allocator_status
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(control_allocator_status) as advert
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_motors
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos_trim
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: control_allocator star
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: load_mon start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'load_mon'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: load_mon start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic cpuload
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: rc_update start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'rc_update'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: rc_update start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: commander start
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'commander'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread commander
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_commander w
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic led_control
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [commaINFO  [qshell] Send cmd: 'commander start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16635298, local time:
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'flight_mode_manager start'
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16765888, local time:
    Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADC
    Feb 23 22:58:19 m0054 voxl-px4[2203]: nder] LED: open /dev/led0 failed (22)
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic tune_control
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: commander start
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic event
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic mavlink_log
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Accel 0 un
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Se
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic health_report
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failsafe_flags
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_armed
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_control_mode
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failure_detector_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_command
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: flight_mode_manager st
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [dataman] data manager file '/data/px4/dataman' size is 78666
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic transponder_report
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic position_setpoint_tri
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic telemetry_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] partner IP: 127.0.0.1
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic timesync_status
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_controls_status_0
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(vehicle_command_ack) as adv
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 145
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advert
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [px4] Startup script returned successfully
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [logger] logger started (mode=all)
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Attitude f
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
    Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
    this is the log, i see that the gps is recognized by the voxl but it resets for some reason.
    #!/bin/sh
    # PX4 commands need the 'px4-' prefix in bash.
    # (px4-alias.sh is expected to be in the PATH)
    . px4-alias.sh
    echo -e "\n*************************"
    echo "AIRFRAME: $AIRFRAME"
    echo "GPS: $GPS"
    echo "RC: $RC"
    echo "ESC: $ESC"
    echo "POWER MANAGER: $POWER_MANAGER"
    echo "AIRSPEED SENSOR: $AIRSPEED_SENSOR"
    echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
    echo "OSD: $OSD"
    echo "ARTIFACT_MODE: $ARTIFACT_MODE"
    echo "EXTRA STEPS:"
    for i in "${EXTRA_STEPS[@]}"
    do
            echo -e "\t$i"
    done
    echo -e "*************************\n"
    # In order to just exit after starting the uorb / muorb modules define
    # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
    # This is useful for testing / debug where you may want to start drivers
    # and modules manually from the px4 command shell
    if [ ! -z $MINIMAL_PX4 ]; then
        /bin/echo "Running minimal script"
        exit 0
    fi
    # Figure out what platform we are running on.
    PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
    RETURNCODE=$?
    if [ $RETURNCODE -ne 0 ]; then
        # If we couldn't get the platform from the voxl-platform utility then check
        # /etc/version to see if there is an M0052 substring in the version string. If so,
        # then we assume that we are on M0052.
        VERSIONSTRING=$(</etc/version)
        M0052SUBSTRING="M0052"
        if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
            PLATFORM="M0052"
        fi
    fi
    # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
        /bin/echo "Running on M0052"
    elif [ $PLATFORM = "M0054" ]; then
        /bin/echo "Running on M0054"
    elif [ $PLATFORM = "M0104" ]; then
        /bin/echo "Running on M0104"
    else
        /bin/echo "Error, cannot determine platform!"
        exit 0
    fi
    # Sleep a little here. A lot happens when the uorb and muorb start
    # and we need to make sure that it all completes successfully to avoid
    # any possible race conditions.
    /bin/sleep 1
    param select /data/px4/param/parameters
    # Load in all of the parameters that have been saved in the file
    param load
    # IMU (accelerometer / gyroscope)
    if [ "$PLATFORM" == "M0104" ]; then
        /bin/echo "Starting IMU driver with rotation 12"
        qshell icm42688p start -s -R 12
    else
        /bin/echo "Starting IMU driver with no rotation"
    fi
    # Start Invensense ICP 101xx barometer built on to VOXL 2
    qshell icp101xx start -I -b 5
    qshell temperature_compensation start
    # Auto detect the magnetometer. If one or both of these devices
    # are not connected it will fail but not cause any harm.
    # Rotation 10 = ROLL_180_YAW_90
    /bin/echo "Looking for qmc5883l magnetometer"
    qshell qmc5883l start -R 10 -X -b 1
    /bin/echo "Looking for ist8310 magnetometer"
    qshell ist8310 start -R 10 -X -b 1
    /bin/echo "Looking for ist8308 magnetometer"
    # Rotation 12 = PITCH_180
    qshell ist8308 start -R 12 -X -b 1
    # GPS and magnetometer
                gps start -d /dev/ttyHS2 -b 115200
            else
                qshell gps start -d 6 -b 115200
            fi
    fi
    starling-px4-dev-kit (D0011):/$ px4-listener vehicle_gps_position
    TOPIC: vehicle_gps_position
    starling-px4-dev-kit (D0011):/$ px4-listener sensor_gps
    never published
    this is usr/bin/voxl-px4-start i updated the baudrate to match with my gps ublox baud rate but the problem remains same. Please help
