José QuintanillaJ
José Quintanilla
@José Quintanilla
Regular
  • Is it possible to do a multiple camera streaming in the VOXL m500?
    José QuintanillaJ José Quintanilla
    I'mt trying to use a multiple camera streaming because I want to use the Hires to take pictures and the stereo cameras to calculate the distance, I tried to use the dfs service but couldn't obtain the distances using code, if any one know how to obtain the sensor data using python or to do the multiple streaming I would appreciate it
  • How can I update or install python libraries inside my VOXL m500
    Im trying to update the mavsdk library and to install the serial library
    Does anyone now how to do it?
  • How can I update the mavsdk library inside the drone
    How can I upgrade the mavsdk library, I want to use the distance sensor to measure the value of the stereo camera, is there any other way to obtain the distance value of the stereo cameras, so I can use it in a python code?
  • How can I copy a file from my drone to my computer?
    I tried to do it with adb shell but I didn't really understand how to do it so I'm trying to do it through wifi
    voxl:~$ cd
    .cache/         .config/        .profile.d/     .ros/           .ssh/           codigos_python/
    voxl:~$ cd /data/
    voxl:/data$ ls
    FTM_AP             dnsmasq_d.leases  mobileap_cfg.xml      volumes
    adb_devid          docker            modalai               voxl-docker-mavsdk-python-master
    audio              graph             network               voxl-docker-mavsdk-python-master.tar
    build-image.sh     iproute2          overlay               voxl-docker-mavsdk-python-master.tar.gz
    configs            l2tp_cfg.xml      persist               voxl-docker-mavsdk-python-master.tgz
    containers         linkgraph.db      repositories-overlay  voxl-logger
    data               logs              tmp                   voxl-mavsdk-python-v1-1-placa2.tar
    db                 lost+found        tombstones            voxl-suite-offline-packages
    dhcpcd-wlan0.info  misc              trust                 web_root
    dnsmasq.conf       mjrn              usb
    voxl:/data$ scp /data/voxl-mavsdk-python-v1-1-placa2.tar dron@192.168.8.11:~/home/Desktop/Dron
    Can someone help me?
  • I cant use pip to install a library on my m500
    @tom Thanks
    @tom Oh okay, let me try
    I'm following this guide: https://docs.modalai.com/flight-core-pwm-esc-calibration/#procedure and I should be able to install a library on voxl, I'm connected in station mode, but I don't now what else to do
  • Can I send data through the j1006 port and read it with python?
    @tom I was able to pug the hardware to the expansion board that goes to the j13 port of the voxl flight,
    lsusb the one im using is the Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
    the success connection of the hardware
    the setup
    @tom the one included with m500 i think is the flight core v1, I'm currently using the expansion board that was included with the drone and I was able to detect the usb port, but know I need to install the serial library in the drone but I don't know how to install python libraries
    I currently made a code to emulate a distance sensor, and I can read the usb port of my laptop to get the data of a nodemcu and a potentiometer, I want to try this inside the drone, so I can see if using a ultrasonic sensor is viable, I don't have the necessary cable at the moment to connect the nodemcu to the J10 port that has i2c and uart communication
    this is my code
    import serial
    ser = serial.Serial('/dev/ttyUSB0')
    print(ser.name)
    while True:
     line = ser.readline()
     decoded_data = line.decode('utf-8')
     print(decoded_data)
    Does anyone know if this would work?
  • Error while voxl-logger --cam stereo -cam dfs_disparity
    I'm trying to use the obstacle avoidance for a proyect but I got some errors, the more recent one is this one
    I try following this guide:https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/
    But I couldn't get through this part: Debugging Collision Prevention
    But even though I decided to enable the voa to qgc and my drone keeps connecting and disconnecting and when I activate the obstacle avoidance its says I have an error in the pre arm check and the obstacle avoidance it's not ready
  • pre-arm check failed after enable the dfs service
    I enable the dfs service so I can keep my drone at a certain distance during a proyect, but when I was trying to arm the drone, the qgc show me the alert avoiding system not ready pre-arm check failed, and I noticed that the configuration inside the drone said "send voa to qgc false", and then I change it but it didnt affect the message
    QGC_main
    QGC_safety
    QGC_parameters
  • How can I trouble shoot my stereo cameras?
    My stereo cameras aren't working and y can configure the cameras on the m500 configuration, only hires and tracking
  • Can you connect a ultrasoninc sensor to a VOXL?
    @Eric-Katzfey Now that you mention that posibility, hoy can I send data through i2c?
    Does anyone know if its possible to communicate a ultrasonic sensor directly to the voxl board ?
  • Which 4g module can I use on the m500?
    I'll be flying the drone in Mexico
    I want to know the right model for the drone
  • How can I use MAVLINK to obtain odometry values
    @tom @Chad-Sweet
  • Incoherence in the vi extrinsics.conf for my m500
    first we detected this problem
    then we followed this topic, then when we checked the vi extrinsics.conf ith showed us the following info
    can someone help @tom
