Hersch NathanH
Hersch Nathan
@Hersch Nathan
  • Unable to use voxl-inspect-battery
    Hersch NathanH Hersch Nathan
    Hi all,
    when I run
    I get the following error
    waiting for PX4 /run/mpa/vvpx4_sys_status/
    even though voxl-px4 and voxl-mavlink-server are enabled
    If anyone has any advise please let me know.
    voxl2:~$ voxl-inspect-services
    docker-autorun | Disabled | Not Running |
    docker-daemon | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Running | 0.0
    voxl-cpu-monitor | Enabled | Running | 0.0
    voxl-imu-server | Enabled | Running | 0.0
    voxl-mavlink-server | Enabled | Running | 0.0
    voxl-modem | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.0
    voxl-px4-imu-server | Disabled | Not Running |
    voxl-px4 | Enabled | Running | 0.0
    voxl-qvio-server | Enabled | Running | 0.0
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Disabled | Not Running |
    voxl-static-ip | Disabled | Not Running |
    voxl-streamer | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-wait-for-fs | Enabled | Completed |
    VOXL SDK and Software
  • Using voxl-opencv in python
    I am trying to import opencv in python on my voxl2.
    In a python3 enviroment when I run
    import cv
    I get the module not found error. How do I access opencv on voxl2?
    Thank you for your help.
  • How to compile and deploy a custom voxl- script to Sentinel
    @tom Thank you so much for you help! I got my code to deploy to the voxl! Now on to bug fixing!
    edit - here is the output from running the following clear && ./clean.sh && ./install_build_deps.sh qrb5165 dev && ./build.sh qrb5165 && ./make_package.sh deb && ./deploy_to_voxl.sh ssh 10.3.141.30
    using qrb5165 dev debian repo
    Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ InRelease
    Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Release
    Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages [98.6 kB]
    Fetched 98.6 kB in 1s (108 kB/s)
    Reading package lists... Done
    installing:
    libmodal-json
    libmodal-pipe
    libvoxl-cutils
    voxl-mavlink
    Building dependency tree
    The following NEW packages will be installed:
    libmodal-json:arm64 libmodal-pipe:arm64 libvoxl-cutils:arm64
    voxl-mavlink:arm64
    0 upgraded, 4 newly installed, 0 to remove and 69 not upgraded.
    Need to get 675 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-json 0.4.3-202209281920 [43.8 kB]
    Get:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-pipe 2.8.5-202306211619 [84.5 kB]
    Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libvoxl-cutils 0.1.1-202210072352 [6228 B]
    Get:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ voxl-mavlink 0.1.1-202305011701 [541 kB]
    Fetched 675 kB in 1s (704 kB/s)
    debconf: unable to initialize frontend: Dialog
    debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 4.)
    debconf: falling back to frontend: Readline
    Selecting previously unselected package libmodal-json:arm64.
    (Reading database ... 30768 files and directories currently installed.)
    Preparing to unpack .../libmodal-json_0.4.3-202209281920_arm64.deb ...
    Unpacking libmodal-json:arm64 (0.4.3-202209281920) ...
    Selecting previously unselected package libmodal-pipe:arm64.
    Preparing to unpack .../libmodal-pipe_2.8.5-202306211619_arm64.deb ...
    Unpacking libmodal-pipe:arm64 (2.8.5-202306211619) ...
    Selecting previously unselected package libvoxl-cutils:arm64.
    Preparing to unpack .../libvoxl-cutils_0.1.1-202210072352_arm64.deb ...
    Unpacking libvoxl-cutils:arm64 (0.1.1-202210072352) ...
    Selecting previously unselected package voxl-mavlink:arm64.
    Preparing to unpack .../voxl-mavlink_0.1.1-202305011701_arm64.deb ...
    Unpacking voxl-mavlink:arm64 (0.1.1-202305011701) ...
    Setting up voxl-mavlink:arm64 (0.1.1-202305011701) ...
    Setting up libvoxl-cutils:arm64 (0.1.1-202210072352) ...
    Setting up libmodal-json:arm64 (0.4.3-202209281920) ...
    Setting up libmodal-pipe:arm64 (2.8.5-202306211619) ...
    Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
    Done installing dependencies
    -- The C compiler identification is GNU 7.5.0
    -- The CXX compiler identification is GNU 7.5.0
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-7 - skipped
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-7 - skipped
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    -- processor: aarch64
    -- librc_math: LIBRC_MATH_SO-NOTFOUND
    -- libmodal_pipe: /usr/lib64/libmodal_pipe.so
    -- libmodal_json: /usr/lib64/libmodal_json.so
    -- libturbojpeg.so: LIBJPEG_TURBO_SO-NOTFOUND
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/cross-workspace/voxl-recorder-battery/build
    [ 25%] Building CXX object tools/CMakeFiles/voxl-record-battery.dir/voxl-record-battery.cpp.o
    [ 50%] Building C object lib/CMakeFiles/voxl_common_config.dir/voxl_common_config.c.o
    [ 75%] Linking C shared library libvoxl_common_config.so
    [ 75%] Built target voxl_common_config
    In file included from /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:52:0:
    /home/root/cross-workspace/voxl-recorder-battery/tools/log_defs.h: In function 'void _rotation_to_tait_bryan_xyz_intrinsic(float ()[3], float, float*, float*)':
    /home/root/cross-workspace/voxl-recorder-battery/tools/log_defs.h:158:19: warning: implicit conversion from 'float' to 'double' to match other operand of binary expression [-Wdouble-promotion]
    if(fabs(R[0][2]) < 0.9999999){
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: In function 'int _start_csv(int)':
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:227:66: warning: unknown conversion type character ')' in format [-Wformat=]
    fprintf(fd, "i,timestamp(ns),,Voltage(V),Charge(%),Current(A)\n");
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:205:6: warning: unused variable 'i' [-Wunused-variable]
    int i;
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:209:7: warning: unused variable 'raw_path' [-Wunused-variable]
    char raw_path[512];
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: In function 'int _parse_opts(int, char**)':
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:201:1: warning: control reaches end of non-void function [-Wreturn-type]
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp: At global scope:
    /home/root/cross-workspace/voxl-recorder-battery/tools/voxl-record-battery.cpp:82:13: warning: 'note' defined but not used [-Wunused-variable]
    static char note[MAX_NOTE_LEN] = "na";
    [100%] Linking CXX executable voxl-record-battery
    [100%] Built target voxl-record-battery
    Package Name: voxl-recorder-battery
    version Number: 0.0.2
    Consolidate compiler generated dependencies of target voxl-record-battery
    [ 50%] Built target voxl-record-battery
    Consolidate compiler generated dependencies of target voxl_common_config
    [100%] Built target voxl_common_config
    Install the project...
    -- Install configuration: ""
    -- Installing: ../pkg/data/usr/bin/voxl-record-battery
    -- Installing: ../pkg/data/usr/lib64/libvoxl_common_config.so
    -- Installing: ../pkg/data/usr/include/voxl_common_config.h
    starting building Debian Package
    dpkg-deb: building package 'voxl-recorder-battery' in 'voxl-recorder-battery_0.0.2_arm64.deb'.
    DONE
    searching for ssh device
    checking VOXL for dpkg/opkg
    dpkg detected
    (Reading database ... 121951 files and directories currently installed.)
    Preparing to unpack .../voxl-recorder-battery_0.0.2_arm64.deb ...
    Unpacking voxl-recorder-battery (0.0.2) over (0.0.1) ...
    @tom The only error I get is when I try to call the code from the terminal on the Sentinel. See below:
    voxl2:~$ voxl-recorder-battery
    -bash: voxl-recorder-battery: command not found
    Would it be useful for me to post my code?
    @tom
    Thank you so much for your help. I was able to build, make, and deploy my package with Voxl-Cross. However, I can not seem to get it to run from the command line.
    I wrote it similar to voxl-logger and voxl-inspect-battery. Do you have any advice?
  • Has anyone added LoRa to the VOXL2?
    @Chad-Sweet Thank you for getting back to me.
    The radio we are leaning to use has an SPI interface. However, I am not opposed to switching radios if there is an easier to use I/O on the VOXL.
    We are leaning to using Adafruit RFM95W based on the SX1276 LoRa® module with SPI interface.
    Hi all,
    The project I am working on wants to use LoRa or LoRaWAN to transfer data from the Ubuntu on the Sentinel to a computer running Ubuntu. What is the best way to add this functionality to the Sentinel?
    My current thoughts are to do one of the following
    Create a custom PCB and use the built in I2C or UART connectors to communicate with it.
    Use a USB dongle. (The downside is we would loose wifi connectivity, which I do not think my team is willing to do.)
    Attach a Raspberry Pi and let it connect to the Sentinel via wifi and translate packages to LoRa
    Hey all,
    I have written a voxl-record-battery script to record battery information to a csv file. I have based it off of VOXL Inspect Battery. How do I compile and deploy this code to a Sentinel?
    The code is written in C++ and I have the voxl-docker installed.
    Thank you for you help.
