Federico WyrwalF
Federico Wyrwal
@Federico Wyrwal
  • ESC issue: rotors not spinning
    Federico WyrwalF Federico Wyrwal
    @Alex-Kushleyev
    The drone was untouched between the first and the next flight. To me the ESC looks clean and I detached and reattached the UART cable.
    The 4 leds on the ESC first flash at high frequency then the come the sounds, then those leds flash another 4 times then they remain off. I see the same behavior and sound on our healthy drone.
    The drone will be sent back for inspection today!
    Thanks for the reply!
  • EIS merge
    I have the starling 2 drone with voxl2 and sdk 1.5. I have the imx412 sensor mounted. The EIS requires a config file that unfortunately does not match the available resolutions for my hires sensor: 4056x3040. Is there a way around this?
    Another valid configuration exists for 1024x768
    We had an initial successful testing of our brand new starling 2 drone. By the next flight we were unable to arm. After some debugging it was clear the esc is unresponsive. How should we proceed?
    voxl-esc spin logs:
    Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.19.125 aarch64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/advantage
     * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
       just raised the bar for easy, resilient and secure K8s cluster deployment.
       https://ubuntu.com/engage/secure-kubernetes-at-the-edge
    This system has been minimized by removing packages and content that are
    not required on a system that users do not log into.
    To restore this content, you can run the 'unminimize' command.
    Last login: Fri Aug 15 14:53:00 2025 from 192.168.5.14
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          MRB-D0014-4-V1-C27-T7-M22-X0
    voxl-suite:   1.5.0
    current IP:   wlan0: ***
    voxl2:~$ voxl-esc spin
    enabling bridge
    detected voxl-px4 is enabled
    detected voxl-px4 is running, stopping it now
    Sending kill slpi command!
    bridge enabled
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.9
    VOXL Platform: M0054
    INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
    Updated baud rate to 230400
    WARNING: No ESC(s) detected
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000
    ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
    ERROR: not all ESCs found
    FAILED to ping ESCs when calling spin script
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
    voxl-mpa logs:
    voxl2:~$ voxl-configure-mpa
                   Welcome to voxl-configure-mpa!
    VOXL is currently thinks it is in the following hardware:
    family code:   MRB-D0014 (starling-2 (D0014))
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    27
    modem config:  22 (M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS)
    tx config:     7 (elrs_beta_fpv)
    extras config: 0 (none)
    If this doesn't look right, quit and run voxl-configure-sku to
    set it correctly. Then run voxl-configure-mpa again.
    Continue? y/n: y
    Continuing
    No handling specified for Modem Num: 22
    No handling specified for Misc Num: 0
    No custom voxl-streamer mods for: 27
    No custom modem mods for: 22
    About to Execute:
    systemctl enable voxl-wait-for-fs
    systemctl start voxl-wait-for-fs
    systemctl disable voxl-static-ip
    voxl-configure-extrinsics D0014_Starling_2
    voxl-configure-vio-cams tracking_front_down_rear
    voxl-configure-cameras 27
    voxl-configure-cpu-monitor factory_enable
    voxl-configure-qvio disable
    voxl-configure-dfs factory_disable
    voxl-configure-tag-detector factory_disable
    voxl-configure-tflite factory_disable
    voxl-configure-vision-hub factory_enable
    voxl-configure-mavlink-server factory_enable
    voxl-configure-portal enable
    voxl-configure-lepton disable
    voxl-configure-lepton-tracker disable
    voxl-configure-uvc disable
    voxl-configure-streamer factory_enable
    voxl-configure-modem disable
    voxl-configure-mavcam factory_enable
    voxl-configure-rangefinders 1_downward_on_m0173
    voxl-configure-vtx --disable
    voxl-configure-vrx --disable
    voxl-configure-state-estimator disable
    voxl-configure-osd disable
    voxl-configure-imu factory_enable
    voxl-configure-flow-server disable
    voxl-configure-feature-tracker disable
    voxl-configure-open-vins factory_enable
    systemctl stop voxl-px4
    systemctl disable voxl-px4
    sleep 3
    voxl-esc setup_d0014_starling_2
    voxl-elrs configure
    rm -f /data/px4/param/parameters
    voxl-configure-px4 crsf_gps_noapm
    systemctl stop voxl-mavlink-server
    sleep 1
    voxl-configure-px4-params --non-interactive --platform MRB-D0014
    set_px4_conf_param RC CRSF_RAW
    executing: systemctl enable voxl-wait-for-fs
    Success!
    executing: systemctl start voxl-wait-for-fs
    Success!
    executing: systemctl disable voxl-static-ip
    Success!
    executing: voxl-configure-extrinsics D0014_Starling_2
    wiping old extrinsic config file
    copying /usr/share/modalai/extrinsic_configs/D0014_Starling_2.conf to /etc/modalai/extrinsics.conf
    done configuring extrinsics
    you can check what was set by running voxl-inspect-extrinsics --all
    Success!
    executing: voxl-configure-vio-cams tracking_front_down_rear
    wiping old vio-cam config file
    copying /usr/share/modalai/vio_cam_configs/tracking_front_down_rear.conf to /etc/modalai/vio_cams.conf
    done configuring vio-cams
    you can check what was set by running voxl-inspect-vio-cams
    Success!
    executing: voxl-configure-cameras 27
    Camera Configuration: 27
    camera server config helper list:
    tracking_front:ar0144:0:rotate:
    hires:imx412:1:
    tracking_rear:ar0144:2:rotate:
    tof:pmd-tof-liow2:3:
    tracking_down:ar0144:4:
    driver binary list:
    /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_0.bin
    /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_1.bin
    /usr/share/modalai/chi-cdk/ar0144-fsin/com.qti.sensormodule.ar0144_fsin_2.bin
    /usr/share/modalai/chi-cdk/irs2975c/com.qti.sensormodule.irs2975c_3.bin
    /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_6.bin
    calling camera-server-config-helper tracking_front:ar0144:0:rotate: hires:imx412:1: tracking_rear:ar0144:2:rotate: tof:pmd-tof-liow2:3: tracking_down:ar0144:4:
    detected system image 1.8.4
    using new imx412 defaults
    MISP awb str: auto
    Setting MISP AWB to Auto
    MISP channels enabled in defaults : 0
    ERROR: object missing misp_channels
    ERROR:   Reading config file: multiple cameras with id: 0
    FAILED TO WRITE CONFIG TO DISK
    camera-server-config-helper failed on attempt 1
    MISP awb str: auto
    MISP awb str: auto
    MISP awb str: auto
    successfully wrote this camera config to disk:
    configuration for 5 cameras:
    cam #0
        sensor type:         ar0144
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           1
        en_rotate2:          1
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 12000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    cam #1
        sensor type:         imx412
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4056
        large_video_height:  3040
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         1
        snap_width:          4056
        snap_height:         3040
        exif_focal_length:   3.100000
        exif_focal_len_35mm_format:17
        exif_fnumber:        1.240000
        ae_mode:             isp
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ar0144
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           1
        en_rotate2:          1
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #3
        sensor type:         pmd-tof-liow2
        isEnabled:           1
        camId:               3
        camId2:              -1
        fps:                 10
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           240
        pre_height:          1629
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        msv_exposure_min_us: 0
        msv_exposure_max_us: 6000
        gain_min           : 0
        gain_max           : 0
        standby_enabled:     0
        decimator:           5
    cam #4
        sensor type:         ar0144
        isEnabled:           1
        camId:               4
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    fsync_en:            0
    fsync_gpio:          109
    camera_server_config_helper is done
    camera-server-config-helper succeeded on attempt 2
    setting gpio pin 109 for fsync
    enabling fsync pin
    copying required camera drivers in place
    enabling voxl-camera-server
    Done Configuring Cameras
    Please power cycle VOXL to load new drivers
    camera server will start on next reboot
    Success!
    executing: voxl-configure-cpu-monitor factory_enable
    wiping old config file
    Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
    enabling  voxl-cpu-monitor systemd service
    Done configuring voxl-cpu-monitor
    Success!
    executing: voxl-configure-qvio disable
    disabling voxl-qvio-server systemd service
    stopping voxl-qvio-server systemd service
    Done configuring voxl-qvio-server
    Success!
    executing: voxl-configure-dfs factory_disable
    Creating new config file: /etc/modalai/voxl-dfs-server.conf
    disabling voxl-dfs-server systemd service
    stopping voxl-dfs-server systemd service
    Done configuring voxl-dfs-server
    Success!
    executing: voxl-configure-tag-detector factory_disable
    Creating new config file: /etc/modalai/voxl-tag-detector.conf
    disabling voxl-tag-detector systemd service
    stopping voxl-tag-detector systemd service
    Done configuring voxl-tag-detector
    Success!
    executing: voxl-configure-tflite factory_disable
    Creating new config file: /etc/modalai/voxl-tflite-server.conf
    The config file was modified during parsing, saving the changes to disk
    disabling voxl-tflite-server systemd service
    stopping voxl-tflite-server systemd service
    Done configuring voxl-tflite-server
    Success!
    executing: voxl-configure-vision-hub factory_enable
    Created new json file: /etc/modalai/voxl-vision-hub.conf
    The JSON config file data was modified during parsing, saving the changes to disk
    enabling  voxl-vision-hub systemd service
    Done configuring voxl-vision-hub
    service will start on next reboot
    Success!
    executing: voxl-configure-mavlink-server factory_enable
    Created new json file: /etc/modalai/voxl-mavlink-server.conf
    enabling  voxl-mavlink-server systemd service
    Done configuring voxl-mavlink-server
    Success!
    executing: voxl-configure-portal enable
    enabling  voxl-portal systemd service
    Done configuring voxl-portal
    Success!
    executing: voxl-configure-lepton disable
    disabling voxl-lepton-server systemd service
    stopping voxl-lepton-server systemd service
    Done configuring voxl-lepton-server
    Success!
    executing: voxl-configure-lepton-tracker disable
    disabling voxl-lepton-tracker systemd service
    stopping voxl-lepton-tracker systemd service
    Done configuring voxl-lepton-tracker
    Success!
    executing: voxl-configure-uvc disable
    disabling voxl-uvc-server systemd service
    stopping voxl-uvc-server systemd service
    Done configuring voxl-uvc-server
    Success!
    executing: voxl-configure-streamer factory_enable
    Creating new config file: /etc/modalai/voxl-streamer.conf
    writing /etc/modalai/voxl-streamer.conf to disk
    parsed config file
    enabling  voxl-streamer systemd service
    Done configuring voxl-streamer, it will start on next reboot
    Success!
    executing: voxl-configure-modem disable
    disabling voxl-modem systemd service
    stopping voxl-modem systemd service
    Done configuring voxl-modem
    Success!
    executing: voxl-configure-mavcam factory_enable
    Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
    writing /etc/modalai/voxl-mavcam-manager.conf to disk
    enabling  voxl-mavcam-manager systemd service
    Done configuring voxl-mavcam-manager
    It will start automatically on the next reboot
    Success!
    executing: voxl-configure-rangefinders 1_downward_on_m0173
    creating new config file for 1 downward TOF without multiplexer
    DONE
    enabling  voxl-rangefinder-server systemd service
    Done configuring voxl-rangefinder-server
    Success!
    executing: voxl-configure-vtx --disable
    Disabling voxl-vtx systemd service
    Detected kernel version: 4.19.125
    Default 88XXau kernel module already loaded
    Success!
    executing: voxl-configure-vrx --disable
    Success!
    executing: voxl-configure-state-estimator disable
    disabling voxl-state-estimator systemd service
    stopping voxl-state-estimator systemd service
    Done configuring voxl-state-estimator
    Success!
    executing: voxl-configure-osd disable
    disabling voxl-osd systemd service
    stopping voxl-osd systemd service
    Done configuring voxl-osd
    Success!
    executing: voxl-configure-imu factory_enable
    Creating new config file: /etc/modalai/voxl-imu-server.conf
    enabling  voxl-imu-server systemd service
    Done configuring voxl-imu-server
    Success!
    executing: voxl-configure-flow-server disable
    disabling voxl-flow-server systemd service
    stopping voxl-flow-server systemd service
    Done configuring voxl-flow-server
    Success!
    executing: voxl-configure-feature-tracker disable
    disabling voxl-feature-tracker systemd service
    stopping voxl-feature-tracker systemd service
    Done configuring voxl-feature-tracker
    Success!
    executing: voxl-configure-open-vins factory_enable
    /usr/bin/voxl-configure-open-vins: line 1: #!/bin/bash: No such file or directory
    Setting printing level to: SILENT
    Creating new config file: /etc/modalai/voxl-open-vins-server.conf
    QUIT REQUESTED
    Exiting Cleanly
    enabling  voxl-open-vins-server systemd service
    Please recycle power to reflect changes
    Done configuring voxl-open-vins-server
    Success!
    executing: systemctl stop voxl-px4
    Success!
    executing: systemctl disable voxl-px4
    Success!
    executing: sleep 3
    Success!
    executing: voxl-esc setup_d0014_starling_2
    enabling bridge
    bridge enabled
    [INFO] Setting CPU to performance mode
    [INFO] Scanning for ESC...
    successfully pinged ESCs
    [ERROR] Unknown board detected:
    disabling bridge
    bridge disabled
    first try failed, executing a second time: voxl-esc setup_d0014_starling_2
    enabling bridge
    bridge enabled
    disabling bridge
    bridge disabled
    FAILED TO EXECUTE: voxl-esc setup_d0014_starling_2
    executing: voxl-elrs configure
    Uploading config!
    Selected firmware image:
    BETAFPV 900MHz RX | v3.2.1.2
    ELRS Receiver "BETAFPV 900RX" already up to date!
    Setting pwm channels...
    Success!
    Success!
    executing: rm -f /data/px4/param/parameters
    Success!
    executing: voxl-configure-px4 crsf_gps_noapm
    enabling  voxl-px4 systemd service
    Done configuring voxl-px4
    Success!
    executing: systemctl stop voxl-mavlink-server
    Success!
    executing: sleep 1
    Success!
    executing: voxl-configure-px4-params --non-interactive --platform MRB-D0014
    [INFO] Voxl-px4 not currently running.
    [INFO] Starting voxl-px4 service...
    [INFO] Voxl-px4 started successfully!
    This process will do the following:
    1. Load the following param files:
    platforms/VOXL_2_defaults.params
    platforms/D0014_Starling_2.params
    EKF2_helpers/vio_gps_baro.params
    EKF2_helpers/exposed_baro.params
    battery_helpers/Amprius_18650_2s.params
    other_helpers/starling_2_indoor_position.params
    radio_helpers/Commando_8.params
    2. Restore calibration params
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/VOXL_2_defaults.params
    [INFO] Scanning currently loaded parameters...
    The following parameters about to be loaded differ from those currently loaded:
    	NAME    		CURRENT    	NEW
    [1]	IMU_GYRO_RATEMAX    	400.0		800.0
    [2]	CBRK_SUPPLY_CHK    	0.0		894281.0
    [3]	COM_ARM_SDCARD    	1.0		0.0
    [4]	COM_CPU_MAX    		95.0		-1.0
    [5]	MAV_TYPE    		0.0		2.0
    [6]	SYS_AUTOSTART    	0.0		4001.0
    [7]	SDLOG_PROFILE    	1.0		129.0
    [8]	EKF2_REQ_SACC    	0.5		1.5
    [9]	EKF2_REQ_GPS_H    	10.0		5.0
    [10]	COM_KILL_DISARM    	5.0		0.0
    [INFO] Setting params...
    [INFO] PX4 parameter configuration successful!
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/D0014_Starling_2.params
    	NAME    		CURRENT    	NEW
    [1]	BAT_AVRG_CURRENT    	15.0		4.3
    [2]	MPC_THR_HOVER    	0.5		0.34
    [3]	THR_MDL_FAC    		0.0		0.9
    [4]	VOXL_ESC_RPM_MIN    	5500.0		2000.0
    [5]	MPC_THR_MAX    		1.0		0.6
    [6]	MPC_THR_MIN    		0.12		0.07
    [7]	MPC_MANTHR_MIN    	0.08		0.07
    [8]	VOXL_ESC_FUNC1    	0.0		102.0
    [9]	VOXL_ESC_FUNC2    	0.0		103.0
    [10]	VOXL_ESC_FUNC3    	0.0		101.0
    [11]	VOXL_ESC_FUNC4    	0.0		104.0
    [12]	VOXL_ESC_BAUD    	250000.0	2000000.0
    [13]	VOXL_ESC_CONFIG    	0.0		1.0
    [14]	VOXL_ESC_VLOG    	0.0		1.0
    [15]	EKF2_IMU_POS_X    	0.0		0.0043
    [16]	EKF2_IMU_POS_Y    	0.0		0.0073
    [17]	EKF2_IMU_POS_Z    	0.0		-0.016
    [18]	CA_ROTOR_COUNT    	0.0		4.0
    [19]	CA_ROTOR0_PX    	0.0		0.085
    [20]	CA_ROTOR0_PY    	0.0		0.0625
    [21]	CA_ROTOR1_PX    	0.0		-0.085
    [22]	CA_ROTOR1_PY    	0.0		-0.0625
    [23]	CA_ROTOR2_PX    	0.0		0.085
    [24]	CA_ROTOR2_PY    	0.0		-0.0625
    [25]	CA_ROTOR3_PX    	0.0		-0.085
    [26]	CA_ROTOR3_PY    	0.0		0.0625
    [27]	CA_ROTOR2_KM    	0.05		-0.05
    [28]	CA_ROTOR3_KM    	0.05		-0.05
    [29]	IMU_DGYRO_CUTOFF    	30.0		60.0
    [30]	IMU_ACCEL_CUTOFF    	30.0		80.0
    [31]	IMU_GYRO_CUTOFF    	40.0		80.0
    [32]	IMU_GYRO_DNF_EN    	0.0		1.0
    [33]	MC_ROLL_CUTOFF    	0.0		30.0
    [34]	MC_PITCH_CUTOFF    	0.0		30.0
    [35]	MC_YAW_CUTOFF    	0.0		10.0
    [36]	MC_ROLL_P    		6.5		16.0
    [37]	MC_ROLLRATE_P    	0.15		0.072
    [38]	MC_ROLLRATE_I    	0.2		0.171
    [39]	MC_ROLLRATE_D    	0.003		0.0009
    [40]	MC_PITCH_P    		6.5		16.0
    [41]	MC_PITCHRATE_P    	0.15		0.097
    [42]	MC_PITCHRATE_I    	0.2		0.228
    [43]	MC_PITCHRATE_D    	0.003		0.0011
    [44]	MC_YAWRATE_P    	0.2		0.15
    [45]	MC_YAWRATE_I    	0.1		0.5
    [46]	MC_ROLLRATE_MAX    	220.0		130.0
    [47]	MC_PITCHRATE_MAX    	220.0		130.0
    [48]	MC_YAWRATE_MAX    	200.0		150.0
    [49]	MPC_TKO_RAMP_T    	3.0		1.0
    [50]	COM_SPOOLUP_TIME    	1.0		2.0
    [51]	LNDMC_ROT_MAX    	20.0		30.0
    [52]	LNDMC_TRIG_TIME    	1.0		0.5
    [53]	COM_DISARM_LAND    	2.0		0.1
    [54]	COM_DISARM_PRFLT    	10.0		20.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/vio_gps_baro.params
    	NAME    		CURRENT    	NEW
    [1]	EKF2_RNG_DELAY    	5.0		50.0
    [2]	EKF2_HGT_REF    	1.0		0.0
    [3]	EKF2_EV_QMIN    	0.0		1.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/exposed_baro.params
    	NAME    		CURRENT    	NEW
    [1]	EKF2_BARO_NOISE    	3.5		3.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/battery_helpers/Amprius_18650_2s.params
    	NAME    		CURRENT    	NEW
    [1]	BAT1_N_CELLS    	0.0		2.0
    [2]	BAT1_R_INTERNAL    	0.005		0.022
    [3]	BAT1_CAPACITY    	-1.0		3950.0
    [4]	BAT1_V_CHARGED    	4.05		4.1
    [5]	BAT1_V_EMPTY    	3.6		2.8
    [6]	BAT_CRIT_THR    	0.07		0.1
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/other_helpers/starling_2_indoor_position.params
    	NAME    		CURRENT    	NEW
    [1]	MPC_YAW_EXPO    	0.6		0.3
    [2]	MPC_XY_MAN_EXPO    	0.6		0.45
    [3]	MPC_Z_MAN_EXPO    	0.6		0.1
    [4]	MPC_JERK_MAX    	8.0		40.0
    [5]	MPC_TILTMAX_AIR    	45.0		30.0
    [6]	MPC_ACC_HOR_MAX    	5.0		1000.0
    [7]	MPC_ACC_UP_MAX    	4.0		3.0
    [8]	MPC_HOLD_MAX_XY    	0.8		0.0
    [9]	MPC_HOLD_MAX_Z    	0.6		0.0
    [10]	MPC_VEL_MANUAL    	10.0		3.0
    [11]	MPC_XY_VEL_MAX    	12.0		3.0
    [12]	MPC_XY_CRUISE    	5.0		3.0
    [13]	MPC_Z_VEL_MAX_DN    	1.5		1.0
    [14]	MPC_Z_V_AUTO_DN    	1.5		1.0
    [15]	MPC_Z_VEL_MAX_UP    	3.0		1.0
    [16]	MPC_Z_V_AUTO_UP    	3.0		1.0
    [17]	MPC_LAND_SPEED    	0.7		1.0
    [18]	MPC_XY_P    		0.95		3.5
    [19]	MPC_XY_VEL_P_ACC    	1.8		3.0
    [20]	MPC_XY_VEL_I_ACC    	0.4		0.1
    [21]	MPC_XY_VEL_D_ACC    	0.2		0.0
    [22]	MPC_Z_P    		1.0		5.0
    [23]	MPC_Z_VEL_P_ACC    	4.0		8.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
    	NAME    		CURRENT    	NEW
    [1]	RC_CHAN_CNT    		0.0		16.0
    [2]	RC_MAP_ROLL    		0.0		1.0
    [3]	RC_MAP_PITCH    	0.0		2.0
    [4]	RC_MAP_THROTTLE    	0.0		3.0
    [5]	RC_MAP_YAW    		0.0		4.0
    [6]	RC_MAP_KILL_SW    	0.0		5.0
    [7]	RC_MAP_FLTMODE    	0.0		6.0
    [8]	COM_FLTMODE1    	-1.0		0.0
    [9]	COM_FLTMODE2    	-1.0		0.0
    [10]	COM_FLTMODE3    	-1.0		2.0
    [11]	COM_FLTMODE4    	-1.0		2.0
    [12]	COM_FLTMODE5    	-1.0		7.0
    [13]	COM_FLTMODE6    	-1.0		7.0
    [14]	RC5_MAX    		2000.0		1988.0
    [15]	RC5_MIN    		1000.0		1011.0
    [16]	RC6_MAX    		2000.0		1988.0
    [17]	RC6_MIN    		1000.0		1011.0
    [18]	RC7_MAX    		2000.0		1988.0
    [19]	RC7_MIN    		1000.0		1011.0
    [20]	RC8_MAX    		2000.0		1988.0
    [21]	RC8_MIN    		1000.0		1011.0
    [INFO] Loading file: /data/px4/param/parameters_gyro.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_GYRO0_ID    	0.0		2490378.0
    [2]	CAL_GYRO0_PRIO    	-1.0		50.0
    [3]	CAL_GYRO0_XOFF    	0.0		0.0005
    [4]	CAL_GYRO0_YOFF    	0.0		0.0129
    [5]	CAL_GYRO0_ZOFF    	0.0		0.0078
    [INFO] Trimming duplicate parameters...
    [INFO] Loading file: /data/px4/param/parameters_acc.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_ACC0_ID    		0.0		2490378.0
    [2]	CAL_ACC0_PRIO    	-1.0		50.0
    [3]	CAL_ACC0_XOFF    	0.0		0.0067
    [4]	CAL_ACC0_YOFF    	0.0		0.0747
    [5]	CAL_ACC0_ZOFF    	0.0		0.0884
    [INFO] Loading file: /data/px4/param/parameters_level.cal
    	NAME    		CURRENT    	NEW
    [1]	SENS_BOARD_X_OFF    	0.0		-0.3481
    [2]	SENS_BOARD_Y_OFF    	0.0		0.087
    [INFO] Loading file: /data/px4/param/parameters_mag.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_MAG0_ID    		0.0		527625.0
    [2]	CAL_MAG0_PRIO    	-1.0		75.0
    [3]	CAL_MAG0_XOFF    	0.0		0.0741
    [4]	CAL_MAG0_YOFF    	0.0		0.0822
    [5]	CAL_MAG0_ZOFF    	0.0		0.1073
    [6]	CAL_MAG0_XSCALE    	1.0		1.0064
    [7]	CAL_MAG0_YSCALE    	1.0		1.0357
    [8]	CAL_MAG0_ZSCALE    	1.0		0.9691
    [9]	CAL_MAG0_XODIAG    	0.0		-0.0151
    [10]	CAL_MAG0_YODIAG    	0.0		-0.0273
    [11]	CAL_MAG0_ZODIAG    	0.0		0.0054
    [12]	CAL_MAG0_ROT    	-1.0		0.0
    [INFO] Loading file: /data/px4/param/parameters_rc.cal
    [INFO] No difference in parameters was detected.
    [INFO] Loading file: /data/px4/param/parameters_baro_tc.cal
    	NAME    		CURRENT    	NEW
    [1]	TC_B_ENABLE    		0.0		1.0
    [2]	TC_B0_ID    		0.0		12018473.0
    [3]	TC_B0_TREF    		40.0		62.77
    [4]	TC_B0_TMIN    		5.0		55.48
    [5]	TC_B0_TMAX    		75.0		70.07
    [6]	TC_B0_X0    		0.0		0.0957
    [7]	TC_B0_X1    		0.0		-2.9135
    [INFO] Done configuring for platform MRB-D0014
    [INFO] make sure to fully power cycle VOXL before flying.
    Success!
    executing: set_px4_conf_param RC CRSF_RAW
    Success!
             FAILED TO EXECUTE the following steps:
          Encountered Problems Configuring MPA Services :-/
            Some Services may not start up on next reboot
    Calibration File Status:
    Present /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_front_intrinsics.yml
    Present /data/modalai/opencv_tracking_down_intrinsics.yml
    Present /data/modalai/opencv_tracking_rear_intrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Present /data/px4/param/parameters_level.cal
    Present /data/px4/param/parameters_baro_tc.cal
    Present /data/px4/param/parameters_mag.cal
    All Required Calibration Files Present
                    PLEASE POWER CYCLE YOUR VOXL
