Chad SweetC
Chad Sweet
@Chad Sweet
  • Inquiry About Smart Modl AI Drone Simulation Tools
    Chad SweetC Chad Sweet
    @Muhammad-Faraz No, we do not have a simulator. VOXL 2 does run PX4 though, so the PX4 simulator might be relevant
    VOXL SDK and Software
  • voxl-2 - support MESSAGING PROTOCOLS IQUART, DroneCAN, CANOpen, Hobby Protocols
    @Suvasis-M https://docs.modalai.com/voxl2-mini-external-flight-controller/
    Flight Core and Legacy VOXL
  • ArduPilot on VOXL 2
    See topic: https://forum.modalai.com/topic/3640/ardupilot-on-voxl2
  • Sentinel Drone Rangefinder
    Hi Erik, thanks for pointing that out. It was a mistake, it has now been fixed as there are no CH-201 sensors
    Development Drones sentinel
  • VIO/VOA with ArduCopter
    @MattK The VOXL SDK is common between VOXL CAM, VOXL 1 and VOXL 2, so the same messages will be sent in the same manner between VOXL and the flight controller over mavlink
  • Unable to switch from Spektrum to Graupner HoTT -- No radios found in QGC
    @tpavlic here is the documented method for connecting Graupner
    https://docs.modalai.com/flight-core-connections/#graupner-receiver-optional
  • Guidelines for integrating VOXL2 Mythic M1076 Add-On Card
    @Jyotish-Kumar Mythic discontinued this product a while ago. It is not available or supported
  • Shipping to Australia
    We have not had a problem shipping directly to Australia.
    Development Drones starling
  • Help with Voxl2 PID Tune problem
    @bensusana which version of px4 are you running? PX4 changed the px4io protocol in 1.14 and that board will no longer work correctly. You should connect your csrf receiver directly to VOXL 2 if using PX4 1.14
  • voxl-px4 service
    @relevinsky it looks like you have corrupted flash
  • Reference frames extrinsics clarification
    @tiralonghipol yes, the ToF is rotated per the extrinsics. You will need to modify your urdf to match
  • voxl-dfs-server Crashes
    @esaldiran can you take a picture or draw a diagram of your setup? Have you changed any cabling? It has to be a specific way
  • Starling with Doodle Radio
    The website was incorrect, it has been fixed
    There is not a version of Startling pet support Doodle labs radios
    You may be able to design an adapter yourself, but it is not clear. The drone would fly appropriately with that much additional weight
  • Spare Starling V2 Lion Packs
    @cantfaxglitter sorry for the delay, we have posted here: https://www.modalai.com/products/3000mah-2s-7-4v-battery-for-starling
  • Most VOXL 2 hires-capable camera ports nonfunctional after SDK 1.0 flash
    For future reference, this is the doc to follow https://docs.modalai.com/voxl2-image-sensors/
  • I want to survey a drone with 5G enable and have some questions
    @Vivian said in I want to survey a drone with 5G enable and have some questions:
    XL2 use the same structure and OS? and from your
    Hi Vivian,
    Sorry for the slow reply. VOXL 2 uses the same chipset, operating system and SDK (VOXL SDK) as the Qualcomm Flight RB5. The VOXL 2 is a smaller and lighter footprint than the core components of the RB5 Flight, but it does not have built-in WiFi. Please check out https://docs.modalai.com/voxl2-d0006/ as a reference for an architecture with VOXL 2. Check out the developer bootcamp for details on how to get started
    Design Reviews and 3D Models system-review
  • AprilTags relocalization with tags on walls
    Here's the location database source code. You should be able to figure out how to configure from this
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector/-/blob/master/server/locations.c
  • Flight electronics with Voxl2
    Please refer to the Sentinel system architecture as a starting point - https://docs.modalai.com/voxl2-d0006/
  • Microhard modem serial communication
    No, you should run the Microhard communications through VOXL and then connect the pixhawk as an external flight controller https://docs.modalai.com/voxl2-external-flight-controller/
