B
Byron_Ch
@Byron_Ch
Qisda Forum
  • VOXL 2 SD2 power domain
    B Byron_Ch
    Hi Vinny,
    Got it, this schematic will be helpful to me, thank a lot.
  • VOXL 2 2nd USB2.0 available?
    B Byron_Ch
    Hi Vinny,
    Got it, very thank.
    B Byron_Ch
    Hi Modal AI team,
    We will implement FLIR Boson 640 and MH pMDDL2450 by MH add-on USB Hub in VOXL2 platform, there are both USB2.0 interface (FLIR Boson 640 Video stream is USB3.0 and command is USB2.0). except J3 pin 12/14 USB2.0, does VOXL 2 have 2nd USB2.0 available? or I can use one of USB2.0 downstream ports of USB controller in MH add-on USB Hub?
  • eFuse rating
    B Byron_Ch
    Hi Modal AI team,
    Power Input/Output Important Note:
    VDCIN_5V is input and the output of the eFuse is VDC_5V_LOCAL, could i know the eFuse rating? Thanks.
    B Byron_Ch
    Hi Modal AI team,
    Could I know VOXL 2 SD2 power domain? VREG_L9C_2P96 or VREG_3P3V_LOCAL?
  • Connection form VOXL 2 J3 to MH add-on with USB Hub
    B Byron_Ch
    We plan make an extension board that connect from VOXL 2 J3 to MH add-on with USB Hub, as below picture show, I just link the signals which marked "Green" and ignore others except DC5V/GND, right?
  • Is pMDDL2450 compatible with pDDL2450 to fit Microhard Modem Add-on with USB Hub
    B Byron_Ch
    Hi Modal AI team,
    Can I use pMDDL2450 at Microhard Modem Add-on with USB Hub? thanks.
  • M0015 3D file
    B Byron_Ch
    Hi Vinny,
    Got it, very thank.
  • M0015 3D file
    B Byron_Ch
    Hi Vinny,
    Our ME find it is not real 3D file only as 2D block as below jpg, ME need to design waterproof for housing, colud i have real 3D file as M0014? Thanks.M0015.jpg
  • M0015 3D file
    B Byron_Ch
    Hi Vinny,
    I got it, thanks.
  • Extra LEDs and Buzzer control from VOXL 2 J3/J5
    B Byron_Ch
    Hi Venny,
    Very thanks.
    B Byron_Ch
    Hi Modal AI team,
    I have an extension board that connect from VOXL2 J3/J5 to control extra LEDs and a buzzer, what GPIOs can control LEDs and any PWM output can control buzzer?
  • M0015 3D file
    B Byron_Ch
    Hi Vinny,
    thanks.
  • M0015 3D file
    B Byron_Ch
    Hi Modal AI team.
    Could I have a web link to download M0015 3D file? Very thank.
  • M0010/M0076/M0084 schematic
    B Byron_Ch
    Hi Modal AI team,
    We plan to make our flex cable between VOXL 2 J6/J7/J8 and image sensors (stereo/tracking/hires), to make sure connection accurately, Could you please provide M0010/M0076/M0084 schematic to me? very thank.
  • Stereo module setting distance
    B Byron_Ch
    Hi, ModalAI team,
    if we don't use M0010 stereo Flex for M0015 stereo module (use other transfer FPC Flex), the distance between left camera and right camera is fix or a range? how much this range?
