A
ahmed-mustahid
@ahmed-mustahid
  • cannot connect to Seeker using usb: adb devices not found
    A ahmed-mustahid
    @tom I have tried the following steps, but still adb could not find the device
    1. I can see it using lsusb | grep Qual
    ➜  work lsusb | grep Qual
    Bus 003 Device 006: ID 05c6:900e Qualcomm, Inc. QUSB__BULK
    ➜  work cat /etc/udev/rules.d/51-android.rules
    SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="900e", MODE="0660", GROUP="plugdev", SYMLINK+="voxl%n"
    SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"
    sudo service udev restart
    ➜  work adb kill-server && adb start-server
    * daemon not running; starting now at tcp:5037
    * daemon started successfully
    1. adb still could not find the device
    ➜  work adb devices
    List of devices attached
    1. fastboot could not find it either
    ➜  work sudo fastboot device
    < waiting for any device >
    ^C
    1. just to try out, I made the SYMLINK+="voxl-fastboot%n" identical to that of SYMLINK+="voxl%n" and repeated the above steps.
    SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="900e", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"
    #SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"
    But adb could not recognise the device this time either.
    Is there any other way that I can use to make adb recognise the device?
    A ahmed-mustahid
    @Adrian-Hidalgo Thank you for the reply.
    Is it possible to switch it on without disassembling the seeker ?
    I have tried flipping the switch that you have shown in the image from outside the green cover. There was no click and sudo fastboot device was showing only < waiting for any device >.
    1. Is there any specific tool or some specific way to flip the switch ? Does it make a click when flipped ?
    2. Is it not possible to flip the switch without disassembling the device ? If so, would you let me know the tools with which I can disassmble it?
      Thank you
    A ahmed-mustahid
    I was trying to write a python script to automate the image flashing (using install.sh file proveided inside voxl_platform3.8) and package installation processes.
    I stopped the process installation process before completing and after this, adb could not find the device anymore.
    Previously, adb could always find the device.
    The python script for installation:
    In [3]: p = subprocess.Popen(['./install.sh'], cwd="/home/ahmed/work/modalAI/voxl_platform_3.8.0-0.7/", s
       ...: tdin=subprocess.PIPE, universal_newlines=True,shell=True)
    [INFO] adb installed
    In [4]: [INFO] fastboot installed
    ----Starting System Image Flash----
    This process will completely wipe your VOXL's file system but will
    preserve the /data/ partition which contains things like calibration,
    wifi config, and docker images.
    you can optionally wipe the /data/ parition, although we encourage
    you not to unless you have a good reason.
    1) preserve(recommended)
    2) wipe
    In [4]: p.communicate(input="1")
    [INFO] Rebooting into fastboot...
    [INFO] Waiting for fastboot...
    target reported max download size of 536870912 bytes
    sending 'aboot' (494 KB)...
    OKAY [  0.057s]
    writing 'aboot'...
    OKAY [  0.567s]
    finished. total time: 0.624s
    sending 'boot' (56090 KB)...
    OKAY [  2.930s]
    writing 'boot'...
    OKAY [  0.405s]
    finished. total time: 3.335s
    erasing 'system'...
    OKAY [  0.013s]
    sending sparse 'system' 1/4 (522964 KB)...
    ^C---------------------------------------------------------------------------
    I stopped the process using CTRL+C
    and now
    ➜  modalAI adb devices
    additionally, fastboot cannot detect it either.
    ➜  utils git:(main) ✗ sudo fastboot device
    [sudo] password for ahmed:
    I have tried looking into the https://docs.modalai.com/unbrick-voxl/ but I could not find any fastboot switch in my device.
    As reference,
    ![0_1666163268099_IMG_3738.jpg](Uploading 100%)
  • Change home position in Voxl-mapper
    A ahmed-mustahid
    From within a C/C++ application, you can use the pipe_client_send_control_cmd function to write a command in this format:
    I have looked for this function in the voxl-mapper gitlab master branch but was not able to find it. Has the name been changed in the latest master branch ?
    From within a python script or bash on voxl, you can simply echo/write to the control pipe yourself using the same syntax (and the pipe will be /run/mpa/plan_msgs/control).
    I have tried using voxl:~$ echo "-4.53 1.53" >> /run/mpa/plan_msgs/control (as per the plan_to: x_coord y_coord mentioned above) but there was no change in the voxl-portal.
    I also tried echo "plan_to: -4.53 1.53" >> /run/mpa/plan_msgs/control but it caused the voxl-mapper to abort. (x: -4.53 y:1.53 worked correctly when used from voxl-portal UI )
    voxl:~$ voxl-mapper
    Loading our own config file
    Loading extrinsics config file
    Trying to init tsdf server
    created tsdf server
    waiting for server at /run/mpa/vvpx4_body_wrt_fixed/
    waiting for server at /run/mpa/tof
    Connected to VIO server
    Initializing ESDF structs
    Connected to depth pipe
    ERROR fetching tf from tf ringbuffer
    there wasn't sufficient data in the buffer
    Client requested plan to location
    msg plan_to
    goal str  -4.53  1.53
    Aborted
    Would you let me know the correct method to input the location programmatically (bash, python, C++ etc) ?
    BTW, voxl-mapper output when PLAN_TO_POINT in voxl-portal UI is used (voxl-portal UI method works correctly):
    voxl:~$ voxl-mapper
    created tsdf server
    msg plan_to
    goal str  0.02459428645670414,-1.4353046417236328,0
    Using start pose of: x:  -0.32, y:   0.13, z:  -0.04
    Using goal pose of: x:   0.02, y:  -1.44, z:   0.00
    Starting RRTConnect planner
    ^C
    received SIGINT Ctrl-C
    Closing Pipes
    voxl:~$
    Thank you
  • Compile and test voxl-mapper code and visualize trajectory in voxl-mapper using docker containers only ?
    A ahmed-mustahid
    I have been trying to input a sequence of goal points programmatically by changing and then compiling the voxl-mapper code, instead of using voxl-portal and then clicking by mouse.
    Currently, in order to test how my modified code is behaving, I need to use the environment inside the seeker to run voxl-mapper by ssh ing into it.
    Is it possible to use only docker container to test the changed codes of voxl-mapper and then visualize it (the goal points and the trajectories) using voxl portal?
  • SLAM and voxl-mapper video details
    A ahmed-mustahid
    @modaltb @Matt-Turi Would you let me know what voxl-mapper config file you have been using to generate the map in the How a Drone Navigates Autonomously with SLAM and voxl-mapper
    youtube video?
  • voxl-portal does not show trajectory even though voxl-mapper computes it
    A ahmed-mustahid
    From the image in voxl-mapper gitlab, https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/raw/master/images/path_plan.png, it can be seen that voxl-portal shows the drone trajectory to the goal point.
    But while doing the same in voxl-portal v0.3.3 by means of voxl-mapper v0.1.5, no such trajectories (red and blue lines) is being shown even though the rrt calculation is being done:
    voxl:~$ voxl-mapper
    created tsdf server
    msg plan_to
    goal str  0.9140511155128479,1.140061616897583,0
    Using start pose of: x:  -0.04, y:  -0.06, z:  -0.02
    Using goal pose of: x:   0.91, y:   1.14, z:   0.00
    ERROR: End point is in collision
    msg plan_to
    goal str  -1.0398440317492224,-1.0579751735630827,-0.529482705573
    Using start pose of: x:  -0.02, y:  -0.07, z:  -0.02
    Using goal pose of: x:  -1.04, y:  -1.06, z:  -0.53
    RRT solution found in   2.85ms and took 800 attempts with 218 in tree
    Starting Informed RRT*
    Improved RRT solution found in 200.03ms and took 21692 attempts with 2223 in tree
    Selecting the goal point
    No trajectory is being shown in voxl-mapper after selecting Go
    My voxl-mapper conf
            "tof_pipe_0":   "/run/mpa/tof",
            "tof_0_enable": true,
            "tof_0_rate":   10,
            "tof_extrinsics_0_name":        "tof",
            "tof_1_pipe":   "/run/mpa/tof",
            "tof_1_enable": false,
            "tof_1_rate":   10,
            "tof_extrinsics_1_name":        "tof",
            "tof_2_pipe":   "/run/mpa/tof",
            "tof_2_enable": false,
            "tof_2_rate":   10,
            "tof_extrinsics_2_name":        "tof",
            "tof_3_pipe":   "/run/mpa/tof",
            "tof_3_enable": false,
            "tof_3_rate":   10,
            "tof_extrinsics_3_name":        "tof",
            "depth_pipe_0": "/run/mpa/dfs_point_cloud",
            "depth_pipe_0_enable":  false,
            "extrinsics0_name":     "stereo_l",
            "depth0_rate":  10,
            "depth_pipe_1": "/run/mpa/stereo_front_pc",
            "depth_pipe_1_enable":  false,
            "extrinsics1_name":     "stereo_front_l",
            "depth1_rate":  10,
            "depth_pipe_2": "/run/mpa/stereo_rear_pc",
            "depth_pipe_2_enable":  false,
            "extrinsics2_name":     "stereo_rear_l",
            "depth2_rate":  10,
            "depth_pipe_3": "/run/mpa/dfs_point_cloud",
            "depth_pipe_3_enable":  false,
            "extrinsics3_name":     "stereo_l",
            "depth3_rate":  10,
            "voxel_size":   0.20000000298023224,
            "voxels_per_side":      16,
            "esdf_save_path":       "/data/voxl-mapper/esdf_map",
            "tsdf_save_path":       "/data/voxl-mapper/tsdf_map",
            "mesh_save_path":       "/data/voxl-mapper/mesh",
            "esdf_max_distance":    2,
            "esdf_min_distance":    0.10000000149011612,
            "esdf_default_distance":        1,
            "esdf_inner_sphere_radius":     0.20000000298023224,
            "esdf_outer_sphere_radius":     0.600000023841858,
            "rrt_min_distance":     0.20000000298023224,
            "rrt_max_runtime_nanoseconds":  1000000000,
            "rrt_goal_threshold":   0.05000000074505806,
            "rrt_prune_iterations": 100,
            "rrt_send_tree":        false,
            "treat_unknown_as_occupied":    true,
            "loco_num_segments":    10,
            "loco_smoothness_cost_weight":  0.1,
            "loco_collision_cost_weight":   10,
            "loco_waypoint_cost_weight":    1,
            "loco_min_collision_sampling_dist":     0.1,
            "loco_add_waypoints":   false,
            "loco_scale_time":      true,
            "loco_split_at_collisions":     true,
            "loco_resample_trajectory":     true,
            "loco_resample_visibility":     false,
            "loco_verbose": false,
            "loco_optimize_time":   true,
            "loco_v_max":   1,
            "loco_a_max":   2,
            "loco_yaw_rate_max":    0.78539816339744828,
            "loco_sampling_dt":     0.1
    voxl-vision-px4 conf
            "config_file_version":  1,
            "qgc_ip":       "192.168.8.60",
            "en_secondary_qgc":     false,
            "secondary_qgc_ip":     "192.168.1.214",
            "qgc_udp_port_number":  14550,
            "udp_mtu":      512,
            "en_localhost_mavlink_udp":     true,
            "localhost_udp_port_number":    14551,
            "en_vio":       true,
            "en_voa":       true,
            "en_send_vio_to_qgc":   false,
            "en_send_voa_to_qgc":   false,
            "voa_upper_bound_m":    -0.15000000596046448,
            "voa_lower_bound_m":    0.15000000596046448,
            "en_set_clock_from_gps":        true,
            "en_force_onboard_mav1_mode":   true,
            "en_reset_px4_on_error":        true,
            "horizon_cal_tolerance":        0.300000011920929,
            "offboard_mode":        "trajectory",
            "follow_tag_id":        0,
            "figure_eight_move_home":       true,
            "en_tag_fixed_frame":   false,
            "fixed_frame_filter_len":       5,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
            "vio_pipe":     "qvio",
            "vio_warmup_s": 3,
            "send_odom_while_failed":       false,
            "collision_sampling_dt":        0.1,
            "max_lookahead_distance":       1,
            "voa_memory_s": 1,
            "voa_inputs":   [{
                            "enabled":      true,
                            "type": "point_cloud",
                            "input_pipe":   "dfs_point_cloud",
                            "frame":        "stereo_l"
                            "enabled":      true,
                            "input_pipe":   "stereo_front_pc",
                            "frame":        "stereo_front_l"
                            "enabled":      true,
                            "input_pipe":   "stereo_rear_pc",
                            "frame":        "stereo_rear_l"
                            "enabled":      true,
                            "type": "tof",
                            "input_pipe":   "tof",
                            "frame":        "tof"
                            "enabled":      true,
                            "type": "rangefinder",
                            "input_pipe":   "rangefinders",
                            "frame":        "body"
    and
    voxl:~$ voxl-version
    system-image: 3.8.0
    kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   0.7.0
    Packages:
    Repo: http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
    http://voxl-packages.modalai.com/stable/
    http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
    Last Updated: 2022-10-12 01:29:08
    List:
            apq8096-camera-server    0.9.1
            apq8096-dfs-server       0.3.1
            apq8096-imu-server       1.0.3
            apq8096-libpng           1.6.38-1
            apq8096-system-tweaks    0.1.2
            apq8096-tflite           2.8.3-1
            libapq8096-io            0.6.0
            libmodal-cv              0.2.3
            libmodal-exposure        0.0.7
            libmodal-json            0.4.3
            libmodal-pipe            2.6.0
            libvoxl-cutils           0.1.1
            voxl-camera-calibration  0.2.3
            voxl-ceres-solver        1.14.0-9
            voxl-cpu-monitor         0.2.6
            voxl-docker-support      1.2.4
            voxl-eigen3              3.4.0
            voxl-gphoto2-server      0.0.10
            voxl-jpeg-turbo          2.1.3-4
            voxl-libgphoto2          0.0.4
            voxl-libuvc              1.0.7
            voxl-logger              0.3.4
            voxl-mapper              0.1.5
            voxl-mavlink             0.1.0
            voxl-mavlink-server      0.2.0
            voxl-modem               0.16.1
            voxl-mongoose            7.7.0-1
            voxl-mpa-to-ros          0.3.6
            voxl-mpa-tools           0.7.5
            voxl-nlopt               2.5.0-4
            voxl-opencv              4.5.5-1
            voxl-portal              0.3.3
            voxl-qvio-server         0.8.2
            voxl-streamer            0.4.1
            voxl-suite               0.7.0
            voxl-tag-detector        0.0.4
            voxl-tflite-server       0.3.1
            voxl-utils               1.2.2
            voxl-uvc-server          0.1.2
            voxl-vision-px4          1.4.0
            voxl-voxblox             1.1.3
            voxl-vpn                 0.0.6
  • Building voxl-mapper from scratch. voxl-mapper: error while loading shared libraries: libceres.so.1: cannot open shared object file: No such file or directory
    A ahmed-mustahid
    I have been trying to install voxl mapper from scratch into voxl by building it from voxl-mapper gitlab master branch :
    1. Install dependencies
    voxl-cross:~/voxl-mapper(master)$ ./install_build_deps.sh apq8096 dev
    using apq8096 dev repo
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//Packages.gz.
    Updated source 'dev'.
    installing:
    libmodal-json
    libvoxl-cutils
    voxl-ceres-solver
    voxl-nlopt
    voxl-mpa-tools
    libmodal-pipe
    voxl-voxblox
    voxl-vision-px4
    voxl-mavlink
    voxl-eigen3
    Installing libmodal-json (0.4.3) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libmodal-json_0.4.3_202209281920.ipk.
    Configuring libmodal-json.
    Installing libvoxl-cutils (0.1.1) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libvoxl-cutils_0.1.1_202210072353.ipk.
    Configuring libvoxl-cutils.
    Installing voxl-ceres-solver (1.14.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-ceres-solver_1.14.0-9_202208221901.ipk.
    Configuring voxl-ceres-solver.
    Installing voxl-nlopt (2.5.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-nlopt_2.5.0-4_202210072358.ipk.
    Configuring voxl-nlopt.
    Done installing nlopt
    Installing voxl-mpa-tools (0.7.5) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-mpa-tools_0.7.5_202210072124.ipk.
    Configuring voxl-mpa-tools.
    Installing libmodal-pipe (2.6.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libmodal-pipe_2.6.0_202210052046.ipk.
    Configuring libmodal-pipe.
    Installing voxl-voxblox (1.1.3) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-voxblox_1.1.3_202209261707.ipk.
    Configuring voxl-voxblox.
    Done installing voxblox
    Installing voxl-vision-px4 (1.4.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-vision-px4_1.4.0_202210072317.ipk.
    Configuring voxl-vision-px4.
    //usr/local/var/lib/opkg/info/voxl-vision-px4.postinst: 10: //usr/local/var/lib/opkg/info/voxl-vision-px4.postinst: systemctl: not found
    Collected errors:
     * pkg_run_script: package "voxl-vision-px4" postinst script returned status 127.
     * opkg_configure: voxl-vision-px4.postinst returned 127.
    Installing voxl-mavlink (0.1.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-mavlink_0.1.0_202207052152.ipk.
    Configuring voxl-mavlink.
    Collected errors:
    Installing voxl-eigen3 (3.4.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-eigen3_3.4.0_202208222129.ipk.
    Configuring voxl-eigen3.
    Collected errors:
    Done installing dependencies
    which install dependencies with multiple errors.
    1. Build
    voxl-cross:~/voxl-mapper(master)$ ./build.sh apq8096
    -- The C compiler identification is GNU 4.9.3
    -- The CXX compiler identification is GNU 4.9.3
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 - skipped
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 - skipped
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/voxl-mapper/build64
    [  2%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/motion_defines.cpp.o
    [  5%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/polynomial.cpp.o
    [  8%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/rpoly_ak1.cpp.o
    [ 13%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/timing.cpp.o
    [ 13%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/segment.cpp.o
    [ 16%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/vertex.cpp.o
    [ 19%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory_sampling.cpp.o
    [ 22%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory.cpp.o
    [ 25%] Linking CXX shared library libmav_trajectory_generation.so
    [ 25%] Built target mav_trajectory_generation
    [ 27%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/yaw_policy.cpp.o
    [ 30%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/visibility_resampling.cpp.o
    [ 33%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/color_utils.cpp.o
    [ 36%] Linking CXX shared library libmav_planning_common.so
    [ 36%] Built target mav_planning_common
    [ 38%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/loco_smoother.cpp.o
    [ 41%] Building CXX object server/voxblox_planning_common/CMakeFiles/voxblox_planning_common.dir/src/path_shortening.cpp.o
    [ 50%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/polynomial_smoother.cpp.o
    [ 50%] Building CXX object server/voxblox_planning_common/CMakeFiles/voxblox_planning_common.dir/src/gain_evaluator.cpp.o
    [ 52%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/path_smoother_base.cpp.o
    [ 52%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/velocity_ramp_smoother.cpp.o
    [ 55%] Linking CXX shared library libvoxblox_planning_common.so
    [ 55%] Built target voxblox_planning_common
    [ 58%] Linking CXX shared library libmav_path_smoothing.so
    [ 58%] Built target mav_path_smoothing
    [ 61%] Building CXX object server/mav_local_planner/CMakeFiles/mav_local_planner.dir/src/conversions.cpp.o
    [ 63%] Linking CXX shared library libmav_local_planner.so
    [ 63%] Built target mav_local_planner
    [ 66%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/local_planners/global_smoother.cc.o
    [ 69%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/global_planners/rrt_connect.cc.o
    [ 72%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/local_planners/local_a_star.cc.o
    [ 77%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/main.cc.o
    [ 77%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/config_file.cc.o
    [ 80%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/obs_pc_filter.cc.o
    [ 83%] Building C object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/rc_transform.c.o
    [ 86%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/planner_utils.cc.o
    [ 88%] Building C object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/rc_transform_ringbuf.c.o
    [ 94%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/timing_utils.cc.o
    [ 94%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o
    [ 97%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_planner.cc.o
    [100%] Linking CXX executable voxl-mapper
    [100%] Built target voxl-mapper
    1. Inside voxl:
      a. Installed voxl related packages
    voxl:~$ opkg list-installed | grep voxl
    libvoxl-cutils - 0.1.1
    voxl-camera-calibration - 0.1.5
    voxl-ceres-solver - 1.14.0-7
    voxl-cpu-monitor - 0.2.6
    voxl-docker-support - 1.2.4
    voxl-gphoto2-server - 0.0.10
    voxl-jpeg-turbo - 2.1.3-4
    voxl-libgphoto2 - 0.0.4
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mapper - 0.1.5
    voxl-mavlink - 0.1.0
    voxl-mavlink-server - 0.1.1
    voxl-modem - 0.16.0
    voxl-mongoose - 7.6.0
    voxl-mpa-to-ros - 0.3.2
    voxl-mpa-tools - 0.7.2
    voxl-nlopt - 2.5.0-4
    voxl-opencv - 4.5.5-1
    voxl-portal - 0.2.8
    voxl-qvio-server - 0.4.6
    voxl-streamer - 0.3.1
    voxl-suite - 0.7.0
    voxl-tag-detector - 0.0.4
    voxl-tflite-server - 0.2.3
    voxl-utils - 1.1.4
    voxl-uvc-server - 0.1.1
    voxl-vision-px4 - 1.0.5
    voxl-voxblox - 1.0.4
    voxl-vpn - 0.0.6
    b.
    voxl:~$ opkg list-installed | grep libmo
    libmodal-cv - 0.1.0
    libmodal-exposure - 0.0.7
    libmodal-json - 0.4.2
    libmodal-pipe - 2.4.0
    libmount1 - 2.26.2-r0.3
    Finally inside voxl, when I execute voxl-mapper, I get the error
    voxl:~$ voxl-mapper -d
    Is it happening due to the errors that occured during dependency installation (Step 1) ? How can I resolve this error?
  • Why does voxl-inspect-pose -f fail when voxl-vision-px4 -b command is executed ?
    A ahmed-mustahid
    The following is my voxl version:
    system-image: 3.8.0
    hw version:   VOXL
    voxl-suite:   0.8.1
    0.7.0
    voxl related packages in opkg are:
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mapper - 0.0.7
    voxl-mavlink - 0.0.7
    voxl-modem - 0.15.1
    voxl-mpa-tools - 0.6.3
    voxl-portal - 0.2.8
    voxl-suite - 0.7.0
    voxl-utils - 1.1.1
    voxl-vpn - 0.0.6
    Initially I can view voxl-inspect-pose -f without any issue:
    voxl:~$ voxl-inspect-pose -f
    timestamp(ms)|     Position (m)     | Roll Pitch Yaw (deg) |    Velocity (m/s)    | angular rate (deg/s) |
          228543 |  -0.04  -0.03  -0.01 |   -2.2   15.6   -0.5 |  -0.00   0.00  -0.00 |  -0.13  -0.22  -0.04 |^C
    But after I execute voxl-vision-px4 -b, I get the following output:
    voxl:~$ voxl-vision-px4 -b
    detected platform APQ8096
    loading our own config file
    Parameters as loaded from config file:
    config file version:        1
    qgc_ip:                     192.168.8.60
    en_secondary_qgc:           0
    secondary_qgc_ip:           192.168.1.214
    qgc_udp_port_number:        14550
    udp_mtu:                    512
    en_localhost_mavlink_udp    1
    localhost_udp_port_number:  14551
    en_vio:                     1
    en_voa:                     1
    en_send_vio_to_qgc:         0
    en_send_voa_to_qgc:         0
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    en_set_clock_from_gps:      1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error:      1
    qvio_auto_reset_quality:    0.000500
    horizon_cal_tolerance:      0.300000
    offboard_mode:              trajectory
    follow_tag_id:              0
    figure_eight_move_home:     1
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    en_transform_mavlink_pos_setpoints_from_fixed_frame:0
    loading extrinsics config file
    exising instance of voxl-vision-px4 found, attempting to stop it
    starting geometry module
    starting px4 monitor
    starting px4 mavlink
    starting udp mavlink
    Adding manual QGC IP address to udp connection list: 192.168.8.60
    Added new UDP connection to 192.168.8.60
    starting px4 shell
    starting fixed pose input
    starting vio manager
    starting tag manager
    starting voa manager
    starting offboard trajectory
    starting control input pipe
    Init complete, entering main loop
    Connected to voxl-mavlink-server
    Detected PX4 Mavlink SYSID 1
    uart send msgid: 111 sysid:  1 compid:197
    Connected to voxl-qvio-server
    updating to use imu: imu1
    done updating transforms to use imu: imu1
    ERROR validating VIO data received through pipe: read partial packet
    read 156 bytes, but it should be a multiple of 324
    uart send msgid: 330 sysid:  1 compid:197
    uart send msgid:  84 sysid:  1 compid:197
    Connected to TOF
    ^C
    Starting shutdown sequence
    stopping control input
    stopping offboard trajectory
    exiting offboard trajectory thread
    stopping horizon_cal
    stopping voa manager
    exiting VOA thread
    stopping tag manager
    stopping vio manager
    stopping fixed pose in module
    stopping px4 shell module
    Stopping udp mavlink module
    exiting QGC udp listener thread
    exiting localhost udp listener thread
    udp_mavlink stopped
    Stopping uart mavlink module
    waiting for px4 mavlink timer thread to join
    Stopping px4 monitor
    closing remaining client pipes
    closing remaining server pipes
    Removing PID file
    exiting
    The error being:
    and voxl-inspect-pose -f shows nothing:
    Why is it happening?
  • Are "voxl-inspect-pose -f" (ie retrieval of pose data) and "voxl-inspect-qvio" (ie retrieval of qvio data) related to cpu temperature ?
    A ahmed-mustahid
    After installing voxl platform from scratch by flashing image, I can run voxl-mapper and both voxl-inspect-qvio and voxl-inspect-pose -f produce correct outputs.
    voxl:~$ voxl-inspect-qvio
    waiting for server
        T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
        0.01   -0.00   -0.01|   0.4    1.4    1.9| OKAY |
    and
          347449 |  -0.06  -0.02  -0.02 |   -0.2   14.4    1.2 |   0.00   0.00  -0.00 |   0.14   0.16  -0.19 |
    Naturally, voxl-mapper also produces proper indoor map
    In this case, the temperature is the following:
    voxl:~$ voxl-inspect-cpu
    2Name   Freq (MHz) Temp (C) Util (%)
    3-----------------------------------
    4cpu0        960.0     50.9    38.01
    5cpu1        960.0     50.9    34.56
    6cpu2       1113.6     51.5    27.29
    7cpu3       1248.0     51.8    22.64
    8Total                 51.8    30.63
    910s avg                       23.83
    10-----------------------------------
    11GPU           0.0     46.2     0.00
    12GPU 10s avg                    0.00
    13-----------------------------------
    14memory temp:       47.7 C
    15memory used:   797/3770 MB
    16-----------------------------------
    17Flags
    18CPU freq scaling mode: auto
    19GPU freq scaling mode: auto
    20-----------------------------------
    21^C
    22received SIGINT Ctrl-C
    23closing
    But after about half an hour, the voxl-inspect-qvio and voxl-inspect-pose -f stop working.
    1. voxl-inspect-qvio shows some values and shows okay status but don’t change even if drone is moved
    waiting for server
       -2.65   -2.16   -0.78| -17.2  -31.0   45.7| OKAY | ^C
    closing and exiting
    1. voxl-inspect-pose -f does not show anything
    1. In this (hot) case, the temperature is the following:
    cpu0       1593.6     83.2    58.73
    cpu1       1593.6     82.9    51.08
    cpu2        883.2     85.2    31.87
    cpu3        883.2     82.0    25.26
    Total                 85.2    41.73
    10s avg                       43.98
    GPU           0.0     75.2     0.00
    GPU 10s avg                    0.00
    memory temp:       77.8 C
    memory used:   998/3770 MB
    Flags
    ^C
    closing
    1. After cooling the seeker for 1 hour, voxl-inspect-qvio shows correct outputs when drone is moved, but voxl-inspect-pose -f does not work.
      In this (cool) case,
    4cpu0        960.0     41.9    37.47
    5cpu1        960.0     41.3    36.29
    6cpu2        729.6     45.1    29.53
    7cpu3        729.6     42.2    26.59
    8Total                 45.1    32.47
    910s avg                       31.86
    11GPU           0.0     37.6     0.00
    12GPU 10s avg                    0.00
    14memory temp:       39.7 C
    15memory used:   561/3770 MB
    17Flags
    21^C
    23closing
    and voxl-inspect-qvio works properly when the drone is moved
    waiting for server
       -0.07   -0.39   -0.02|  33.2  -39.0  -19.9| OKAY | ^C
    closing and exiting
    waiting for server
       -0.16   -0.54   -0.28| 110.8    7.6  -55.4| OKAY | ^C
    closing and exiting
    waiting for server
        0.39   -0.50    0.03|  69.5  -20.3   97.2| OKAY | ^C
    closing and exiting
    But, voxl-inspect-pose -f does not show anything
    voxl-inspect-pose -f start working only when image is flashed and voxl platform and packages including voxl-mapper are installed from scratch.
    If temperature was the issue, would not voxl-inspect-pose -f start working, after the seeker has been cooled?
    Could you let me know why such problem is occuring?
  • Issues with indoor mapping speed and path planning with voxl-mapper
    A ahmed-mustahid
    I have multiple questions regarding path planning with voxl-mapper:
    voxl-mapper version: 0.0.7
    My voxl-mapper config file is :
    voxl:~$ cat /etc/modalai/voxl-mapper.conf
     * This file contains configuration that's specific to voxl-mapper.
    	"tof_pipe":	"/run/mpa/tof",
    	"tof_enable":	true,
    	"tof_rate":	10,
    	"depth0_rate":	10,
    	"depth1_rate":	10,
    	"depth2_rate":	10,
    	"depth3_rate":	10,
    	"robot_radius":	0.3,
    	"esdf_save_path":	"/data/voxl_mapper/esdf_map",
    	"tsdf_save_path":	"/data/voxl_mapper/tsdf_map",
    	"mesh_save_path":	"/data/voxl_mapper/mesh.ply",
    	"esdf_max_distance":	4,
    	"esdf_default_distance":	2,
    	"rrt_min_distance":	0.2,
    	"rrt_use_first_solution":	false,
    	"rrt_treat_unknown_as_occupied":	true,
    	"loco_derivative_to_optimize":	3,
    	"loco_poly_degree":	10,
    	"loco_smoothness_cost_weight":	2.5,
    	"loco_collision_cost_weight":	14,
    	"loco_waypoint_cost_weight":	0,
    	"loco_min_collision_sampling_dist":	0.05,
    	"loco_add_waypoints":	true,
    voxl-vision-px4.conf file
    voxl:~$ cat /etc/modalai/voxl-vision-px4.conf
    	"udp_mtu":	512,
    	"en_vio":	true,
    	"en_voa":	true,
    	"qvio_auto_reset_quality":	0.00050000002374872565,
    	"follow_tag_id":	0,
    1. The following is the image provided in the gitlab repo:
      https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/raw/master/images/path_plan.png!alt text
      This map has generated both red and blue paths but none of my two maps shown below have blue path. Has the blue path been removed in the new voxl-mapper version?
    2. I am confused as to how I should select the goal point for the drone to fly to, because it is very hard to visualize exactly where the goal point selected in the voxl mapper is located in the room.
      Is it the right apporach to view the map from the top (i.e. from z axis pointing outward the screen: last image) and then select the "goal point"?
    3. In the last image (viewed from z axis) why does the voxl-mapper create a zig zag path, whereas a straight path is enough to reach the goal point?
    1. Current mapping speed is very slow. What parameter in the voxl-mapper config map can I change in order to incease the mapping speed?
  • Cannot build voxl-mapper in voxl-cross docker image: fatal error: voxblox/Eigen/Core: No such file or directory
    A ahmed-mustahid
    I intend to modify some codes in voxl-mapper and so would like to build it after the modification. I am building it following the instructions in the Build Instructions section in the voxl-mapper gitlab (i.e. in voxl-cross docker image).
    Therefore,following the instructions in voxl-mapper gitlab, I execute the following:
    1. Install the dependencies
    using apq8096 sdk-0.8 repo
    Downloading http://voxl-packages.modalai.com/dists/apq8096/sdk-0.8/binary-arm64//Packages.gz.
    Updated source 'sdk-0.8'.
    installing:
    libmodal-json
    libvoxl-cutils
    voxl-ceres-solver
    voxl-nlopt
    voxl-mpa-tools
    libmodal-pipe
    voxl-voxblox
    Package libmodal-json (0.4.2) installed in root is up to date.
    Package libvoxl-cutils (0.1.1) installed in root is up to date.
    Package voxl-ceres-solver (1.14.0-9) installed in root is up to date.
    Package voxl-nlopt (2.5.0-4) installed in root is up to date.
    Package voxl-mpa-tools (0.7.3) installed in root is up to date.
    Package libmodal-pipe (2.4.4) installed in root is up to date.
    Package voxl-voxblox (1.1.2) installed in root is up to date.
    1. Run the script for building
    -- Configuring done
    -- Generating done
    Consolidate compiler generated dependencies of target mav_trajectory_generation
    [  2%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/polynomial.cpp.o
    [  5%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/rpoly_ak1.cpp.o
    [  8%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/segment.cpp.o
    [ 11%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory_sampling.cpp.o
    [ 13%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory.cpp.o
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/src/polynomial.cpp:20:0:
    /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/polynomial.h:24:30: fatal error: voxblox/Eigen/Core: No such file or directory
     #include <voxblox/Eigen/Core>
    compilation terminated.
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/trajectory_sampling.h:24:0,
                     from /home/root/voxl-mapper/server/mav_trajectory_generation/src/trajectory_sampling.cpp:21:
    /home/root/voxl-mapper/server/mav_comm/mav_msgs/include/mav_msgs/eigen_mav_msgs.h:24:30: fatal error: voxblox/Eigen/Core: No such file or directory
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/src/segment.cpp:21:0:
    /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/segment.h:24:30: fatal error: voxblox/Eigen/Core: No such file or directory
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/src/vertex.cpp:21:0:
    /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/vertex.h:24:30: fatal error: voxblox/Eigen/Core: No such file or directory
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:173: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/vertex.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/vertex.cpp.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:159: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory_sampling.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory_sampling.cpp.o] Error 1
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:117: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/segment.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/segment.cpp.o] Error 1
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:89: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/polynomial.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/polynomial.cpp.o] Error 1
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/trajectory.h:25:0,
                     from /home/root/voxl-mapper/server/mav_trajectory_generation/src/trajectory.cpp:21:
    In file included from /home/root/voxl-mapper/server/mav_trajectory_generation/src/rpoly_ak1.cpp:47:0:
    /home/root/voxl-mapper/server/mav_trajectory_generation/include/mav_trajectory_generation/rpoly_ak1.h:20:30: fatal error: voxblox/Eigen/Core: No such file or directory
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:145: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory.cpp.o] Error 1
    server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/build.make:103: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/rpoly_ak1.cpp.o' failed
    make[2]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/rpoly_ak1.cpp.o] Error 1
    CMakeFiles/Makefile2:259: recipe for target 'server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/all' failed
    make[1]: *** [server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/all] Error 2
    Makefile:135: recipe for target 'all' failed
    make: *** [all] Error 2
    It seems that the main issue here is
    In the first step, where I install all the dependencies, it seems voxblox package was installed. But still this error shows up.
    As a reference, voxl-voxblox - 1.0.4 - voxblox library api seems to be installed.
    voxl-cross:~/voxl-mapper(master)$ opkg list
    apq8096-dfs-server - 0.3.0 - depth-from-stereo server for Modal Pipe Architecture
    apq8096-imu-server - 1.0.2 - VOXL IMU interface for Modal Pipe Architecture
    apq8096-libpng - 1.6.38-1 - 64-bit version of native libpng for voxl1
    apq8096-rangefinder-server - 0.1.2 - publishes rangefinder data
    apq8096-system-tweaks - 0.1.2 - ModalAI common on-target utilities for VOXL
    apq8096-tflite - 2.2.3-4 - Tensorflow Lite Build For VOXL
    libapq8096-io - 0.5.8 - ModalAI library allowing apps processor access to accessory serial ports
    libmodal-cv - 0.1.0 - ModalAI CV library
    libmodal-exposure - 0.0.7 - ModalAI Auto Exposure Library
    libmodal-json - 0.4.2 - Helper library for handling JSON config files
    libmodal-pipe - 2.4.0 - Interface for services to communicate over posix named pipes
    libmodal-pipe - 2.4.4
    librc-math - 1.1.8 - Math and Linear Algebra Routines for Robotics
    libvoxl-cutils - 0.1.1 - ModalAI's c utils
    mavlink-camera-manager - 0.1.0 - ModalAI implementation of the Mavlink camera protocol
    qualcomm-proprietary - 0.0.1
    voxl-camera-calibration - 0.2.2 - On-board camera calibration for VOXL
    voxl-camera-server - 1.1.0 - publishes camera frames over named pipe interface
    voxl-ceres-solver - 1.14.0-7 - ceres-solver for voxl
    voxl-ceres-solver - 1.14.0-9
    voxl-cpu-monitor - 0.2.6 - publishes CPU Data over MPA pipe and provides fan tools
    voxl-docker-support - 1.2.4 - tools to improve the usability of docker on VOXL
    voxl-gphoto2-server - 0.0.10 - Gstreamer-based application to pull raw video frames from PTP cameras
    voxl-jpeg-turbo - 2.1.3-4 - libjpeg_turbo build for voxl
    voxl-libgphoto2 - 0.0.4 - Library to control digital cameras over USB
    voxl-libuvc - 1.0.6 - cross-platform library for USB video devices
    voxl-logger - 0.3.2 - misc tools for modal pipe architecture
    voxl-mapper - 0.0.7 - voxl-mapper
    voxl-mavlink - 0.1.0 - mavlink headers
    voxl-mavlink-server - 0.1.3 - MPA interface for mavlink over UART or UDP
    voxl-modem - 0.16.0 - VOXL Modem Utils
    voxl-mongoose - 7.6.0 - mongoose build for voxl
    voxl-mpa-to-ros - 0.3.3 - ROSNode converting MPA pipes
    voxl-mpa-tools - 0.7.2 - misc tools for modal pipe architecture
    voxl-mpa-tools - 0.7.3
    voxl-nlopt - 2.5.0-4 - nlopt
    voxl-opencv - 4.5.5-1 - opencv built for VOXL
    voxl-portal - 0.2.8 - Debug web interface for VOXL
    voxl-qvio-server - 0.7.1 - publishes QVIO data over named pipe interface
    voxl-streamer - 0.3.6 - Gstreamer-based application to handle RTSP streaming
    voxl-suite - 0.8.1 - voxl-suite for APQ8096 VOXL
    voxl-tag-detector - 0.0.4 - Detect apriltags for MPA
    voxl-tflite-server - 0.2.7 - client of voxl-camera-server that does deep learning
    voxl-utils - 1.1.4 - ModalAI common on-target utilities for VOXL
    voxl-uvc-server - 0.1.1 - libuvc application to handle UVC camera frame output to MPA
    voxl-vision-px4 - 1.2.0 - Interface between VOXL's computer vision services and PX4
    voxl-voxblox - 1.1.2
    voxl-vpn - 0.0.6 - ModalNet VPN software
  • How to install .ipk package to build ROS nodes directly on VOXL?
    A ahmed-mustahid
    I have been following the instructions to build ROS nodes from this link. But I am not sure how I should install the .ipk package which is the prerequisite here.
  • Cannot open voxel-portal on two browser tabs simultaneously.
    A ahmed-mustahid
    I want to use voxel mapper for autonomous flight.
    I want to view from camera along with voxl-mapper to confirm that the map has been correctly constructed and the created path will not collide/scrape with any obstacle.
    But I cannot open voxl-portal in more than one tab. Is it not possible to do so?
  • Cannot run voxl-mapper: ERROR fetching tf from tf ringbuffer there wasn't sufficient data in the buffer
    A ahmed-mustahid
    I have been getting the following error when starting voxl-mapper in the terminal, even though as per the instructions, all the services (voxl-vision-px4, voxl-qvio-server, voxl-camera-server) are running.
    I wonder what might have been the problem in this case.
    root@apq8096:~# voxl-mapper
    created tsdf server
    root@apq8096:~# voxl-inspect-services
     Service Name         |  Enabled  |   Running   |  CPU Usage
     docker-autorun       | Disabled  | Not Running |
     docker-daemon        | Disabled  | Not Running |
     modallink-relink     | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |    33.2
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |  Enabled  |   Running   |     2.5
     voxl-imu-server      |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |  Enabled  |   Running   |     0.0
     voxl-modem           | Disabled  | Not Running |
     voxl-portal          |  Enabled  |   Running   |     2.5
     voxl-qvio-server     |  Enabled  |   Running   |    10.2
     voxl-streamer        | Disabled  | Not Running |
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-tflite-server   | Disabled  | Not Running |
     voxl-time-sync       | Disabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     2.5
     voxl-wait-for-fs     |  Enabled  |  Completed  |
    	"tof_enable":	true,
    	"tof_rate":	10,
    	"depth0_rate":	10,
    	"depth1_rate":	10,
    	"depth2_rate":	10,
    	"depth3_rate":	10,
  • voxl-mapper does not run: libgomp.so.1 does not exist
    A ahmed-mustahid
    I install voxl-mapper without any issue:
    root@apq8096:~# opkg install voxl-mapper
    Installing voxl-mapper (0.0.6) on root.
    Configuring voxl-mapper.
    Done installing voxl-mapper
    But I cannot run it due to the following error:
    voxl-mapper: error while loading shared libraries: libgomp.so.1: cannot open shared object file: No such file or directory
    I have not installed/removed any package before this.
    I have tried obtaining libgomp.so from here but could not install due to the absence of dpkg-deb. Even if I had dpkg-deb, I am not sure where I should install it so that the above error is resolved.
    My voxl version:
    root@apq8096:~# voxl-version
    system-image: 3.8.0
    hw version:   VOXL
    voxl-suite:   0.7.0
    Running services:
     voxl-camera-server   |  Enabled  |   Running   |    17.3
     voxl-dfs-server      | Disabled  | Not Running |
     voxl-portal          |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |  Enabled  |   Running   |     4.3
     voxl-vision-px4      |  Enabled  |   Running   |     2.1
    root@apq8096:~# cat /etc/opkg/opkg.conf
    ## This file has been automatically generated.
    ## Please use voxl-configure-opkg to modify it.
    dest root /
    option lists_dir /var/lib/opkg/lists
    arch all 1
    arch arm64 7
    src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
